  1. Jan 25, 2022 at 6:58 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    All this engineering talk and I just went at my shit like hur dur this looks strong.
  2. Jan 25, 2022 at 7:00 AM
    17taco4x4
    17taco4x4 FZJ80
    Orlando
    Porter, TX
    1997 Land Cruiser
    1997tacomav6[QUOTED] likes this.
  3. Jan 25, 2022 at 7:01 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    For the most part I design by eye anyway haha, if it looks strong and feels strong it's typically okay. But feeling the frame all stripped down where you can move everything a lot by hand... makes you wonder where things should go not to hurt anything. I'm dealing with space constraints, otherwise it would probably be easier to just plate everything haha. But Dan raises a great point of how much you can stiffen it before tearing/cracking becomes the new issue.
  4. Jan 25, 2022 at 7:12 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
  5. Jan 25, 2022 at 7:14 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I figured all the other companies that advertise fully boxed frames can't be wrong, right? :p
  6. Jan 25, 2022 at 7:35 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    It's not hard to install just tight. I did have to have help to push down on the collar thing a ma jigger.
    Mine has popped out of first like 2 or 3 times. But it could have been beacouse I had pressure on the stick.if you use the provided new upper stick the throw is actually the same length. Or it feels like it. but the stick is higher and there way more positive feeling.
  7. Jan 25, 2022 at 7:39 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I mean, 1st gen frames would never crack. :anonymous:
    That being said, I actually don't think I have any behind the front suspension. A closer look is in order this spring.
    unstpible, drr, jubei and 2 others like this.
  8. Jan 25, 2022 at 7:39 AM
    Speedytech7
    Does the rear axle count? :bananadead:
  9. Jan 25, 2022 at 7:40 AM
    Squeaky Penguin
    Brett
    No, not the frame.
  10. Jan 25, 2022 at 7:45 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    1st gen frames are totally super strong, especially the rear
    Burro, Reh5108, cynicalrider and 3 others like this.
  11. Jan 25, 2022 at 7:49 AM
    Speedytech7
    That's a hell of bend. That section is double wall on mine now... but I gotta ask, what did that cause I can't imagine it was just the drivetrain haha
    unstpible likes this.
  12. Jan 25, 2022 at 7:53 AM
    slander
    Hickory, NC
    Taking this line:
    Had the winch stalled out pulling the front down, and I was flooring it in double low to get out, I was wedged in there pretty good.
  13. Jan 25, 2022 at 7:54 AM
    Speedytech7
    Ah gotcha, bummer about the frame but looks like an awesome time was had either way. I'm sure you'll get it all fixed up, might even yank out most of the way
    unstpible and slander[QUOTED] like this.
  14. Jan 25, 2022 at 7:57 AM
    slander
    Hickory, NC
    Heres how we fixed it and I drove it home:
    That trail is my nemesis! I flopped on that same line when I was IFS. I am going to get some rear frame rails made from a local race frame shop, chop the ass end off and burn them in. 2x4 mandrel bent tube!!
    unstpible, BYJOSHCOOK, jubei and 2 others like this.
  15. Jan 25, 2022 at 7:58 AM
    Speedytech7
    That's the way to go.... I have regrets about not chopping my frame off and rebuilding it when I tore it down
  16. Jan 25, 2022 at 7:58 AM
    slander
    Hickory, NC
    I'll have less than 4ft of original frame when it's all said and done as I frame chopped the front of the truck when I did my SAS lol! I'm glad that didn't fail!!
  17. Jan 25, 2022 at 8:18 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    So in your mofesional opinion, what would an ideal balance of reinforcement be for the rear frame?
    I have both the outboard frame plate kit and the boxing kit from trail-fail.
    Planning on doing the boxing kit, but that in addition to the outboard plate kit does seem a bit excessive. But idk, @Squeaky Penguin and a few others I've seen have that combo and haven't seem to have any failure on the rear of their frames from it being too stiff/rigid or anything
  18. Jan 25, 2022 at 8:20 AM
    RobZ9132
    RobZ9132 Well-Known Member
    Somewhere in NC
    2004 Double Cab TRD
    Finished up the radiator (Denso), upper and lower hoses (OEM), thermostat (OEM, jiggle valve at 6 o'clock) and energy suspension steering rack bushings last night. I was changing the radiator earlier this week and noticed the passenger steering bushing didn't look quite right while I was under the truck, pulled the cover and realized it was FUBAR. It was a fairly straightforward process! Truck drives SO much nicer!
    Not too bad for 227k miles!
    SwampYota and unstpible like this.
  19. Jan 25, 2022 at 9:06 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I’m just spouting the theory here, I’m not a vehicle frame designer or anything like that.
    I agree, catastrophic frame failure seems to be rare (other than rust issues), so the boxing kit and frame plates seems to be belt and suspenders. Boxing the frame has some other benefits as I mentioned, it’s just harder to do for most folks who haven’t stripped it all the way down like @Speedytech7
    If you’re inclined to do the boxing, I’d probably go that route and leave it at that. If you’re going balls to the wall like @slander , you might look into wrapping your box plating over the top and bottom flanges to increase bending resistance, although the most efficient way to do that is to increase the depth (height) of the frame itself. Not very practical or easy though.
  20. Jan 25, 2022 at 9:08 AM
    Squeaky Penguin
    Brett
    FWIW, I have that combo simply because I plated the frame years before I boxed it. Might have just boxed it if I was starting a fresh build.
    Also, my frame might be slightly bent just in front of the front leaf hanger as the gap at the top of the bed is bigger than at the bottom. But who knows given how messed up my bed mounts, and probably cab mounts, are.
    *I'm very much not an engineer. :rofl:
