  1. Feb 9, 2022 at 4:01 PM
    Lil Puke
    Lil Puke Well-Known Member
    Oregon
    ‘99 Taco
    crumbs between seat cushions, junk in glove box, center console mostly full
    image.jpgI have a set of stock UCA’s with fresh Energy Suspension bushings if you’re interested.
    unstpible likes this.
  2. Feb 9, 2022 at 6:05 PM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    I was going to post them this weekend. Throw me an offer and see if we can work it out. I have all of the brackets and bolts with it as they all came out
  3. Feb 9, 2022 at 6:20 PM
    Jase
    Jase Well-Known Member
    jase
    Oregon
    2004 4x4 DC
    Rebuilt / frame swap at 200K
    That worked, ty!
    SwampYota and Digiratus[QUOTED] like this.
  4. Feb 9, 2022 at 6:49 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    installed my inside cover for my dometic fan
  5. Feb 9, 2022 at 6:56 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sexy sexy toolbox lights
    SwampYota, MadNachos and jubei like this.
  6. Feb 9, 2022 at 7:41 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    To answer your question. Here’s a pic for you. I think it should be fine. I only had contact with the front lower corner of the flare & bed. I ended up just mounting the oem rear mudflaps temporarily till I get some husky liners to fit in permanently. Last thing I want to do is shoot in salty slush into that back corner and start the rusting..
    I know someone on 37’s with this bumper and he didn’t cut the wing back at all.
    unstpible and jubei[QUOTED] like this.
  7. Feb 9, 2022 at 8:01 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Have you cycled your suspension? Depending on the length of your shackles, it looks like you are going to interfere with the bumper at full stuff.
    jubei likes this.
  8. Feb 9, 2022 at 8:14 PM
    Godzilla619
    Godzilla619 Well-Known Member
    David
    San Diego
    2000 Black Taco prerunner v6
    Mid travel
    I Scored a Draw tite tow hitch for a whopping $20. :yes:354D4A75-635A-46C1-BF95-203F51304BC0.jpg
  9. Feb 9, 2022 at 8:19 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    How much for the shoes?
    Das it mang and Lil Puke[QUOTED] like this.
  10. Feb 9, 2022 at 8:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I agree.
  11. Feb 9, 2022 at 8:37 PM
    Rhodes
    Edmonton
    01 Dbl Cab
    I’ve got 1/2” lift shackles. It’s goin on the jackstands tomorrow and will tuck it fully. I was limited in time with watching the 3 year old today, so I dealt with cutting where I know I would contact.
    it’s tough to tell from the picture, but I have faith. Bad angle, plus that bulky mud flap.
    drr[QUOTED] and Blackdawg like this.
  12. Feb 9, 2022 at 8:38 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Run it, flex it, trim it. The rear is hard to flex in a garage and trim it all. Just run it and when it runs, make note and cut it later. Not the end of the world.
    unstpible and Rhodes like this.
  13. Feb 9, 2022 at 8:44 PM
    YotaGangYotaGang
    Covina
    are the 1/2” shackles to give you an additional 1/2” lift or if you lifted it 1/2” ? thx
  14. Feb 9, 2022 at 8:49 PM
    Rhodes
    Edmonton
    01 Dbl Cab
    Dakar leafs gave me just over 2” and I added the 1/2 arb lift shackles since a buddy had them lying around.
    Double checked coastal site and saw this. I know everyone’s geometry is different, but I feel like I should just be able to squeak through. Worst case once on the trail I’d remove the mud flap and gain over 1/2” there.
    unstpible and jubei like this.
  15. Feb 9, 2022 at 8:52 PM
    Rhodes
    Edmonton
    01 Dbl Cab
    100% agree.. we’ve got massive snow piles from grading my street, so I was trying to ride up and stuff it as much as possible there.. I’ve gone back 3 times to fire up the ol zipdisk and take a bit more off the front of the rear flares/ bedside. Then back… my neighbour thinks I’m crazy.
    Front I’ll do proper like everyone mentioned. Remove the coilover and cycle. Cut. Cycle. If it clears, cut another 1” back… start welding.
  16. Feb 9, 2022 at 9:00 PM
    m3bassman
    Green truck
    You've got a good plan. I wouldn't add the 1inch though. As it stands, you'll be cutting back to the lower door hinge just to clear what you have. You shouldn't have to worry about the pedal box area since you don't have a clutch. I would pull your suspension and bump stops for when you cycle at full lock. After all my work the only place I rub is the frame and full stuff on things like woops and whiskey ditches because I left my bumps on :anonymous:
    unstpible and Rhodes[QUOTED] like this.
  17. Feb 9, 2022 at 9:06 PM
    Rhodes
    Edmonton
    01 Dbl Cab
    10-4! Thanks for the advice. I’m not the most mechanically inclined person, but reading all this gold on here has helped greatly since day1 of owning this truck.
  18. Feb 9, 2022 at 9:08 PM
    m3bassman
    Green truck
    If you get stuck with tubbing tag me here or in a dm. Happy to help, was a learning experience myself.
  19. Feb 9, 2022 at 9:14 PM
    Lil Puke
    Oregon
    ‘99 Taco
    You kidding me, sell my church shoes? :D
  20. Feb 9, 2022 at 11:15 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    can concurr that you should take your bumps off when clearancing. I run into the same thing with rubbing in higher speed situations when turning slightly
    unstpible and m3bassman[QUOTED] like this.
