  1. Feb 20, 2022 at 5:46 AM
    Taco Roofer
    Taco Roofer Well-Known Member
    Noah
    Southern Oregon
    2004 Tacoma 4dr 4x4
    The work beast and weekend warrior rig.
    Test fit some new wheels and tires yesterday. Just got tired of SCS playing games with their wheel releases so went with some 17x8.5 Icons and the Geolandar for tread. Everyone and their dog has SCS wheels now where I live and I think these Icons looks way better.
    Also did the full 3k service, changing fluids and greasing her up again since I've been wheeling the shit out it lately.
    Gained a significant lift from the new wheel tire setup which is a bonus! Any opinions?
  2. Feb 20, 2022 at 7:06 AM
    foothill96tacoma
    foothill96tacoma Well-Known Member
    Yes, but did you 3D print your filter? Create a LED-illuminated, liquid-cooled, methanol-injected system for it?
  3. Feb 20, 2022 at 7:08 AM
    2pei
    2pei Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    no, got it at wal mart. .....but i did prime it!
  4. Feb 20, 2022 at 9:03 AM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
    After my fun week in the Kofa National Wildlife refuge I noticed torn inner boots on both my CV axles.
    They are both from CVJ and, if I remember correctly, they offered an option for "good, better or best" boots and I chose "best" so it is somewhat disappointing that they both tore at essentially the same time. After a quick Q&A session here I felt okay driving the 700+ miles home before replacing them. I just got two replacements through my buddy's shop at his cost ($100ea) and installed them yesterday. I have "helped" (watched with a beer in one hand and lots of dumb questions) on this job before but never done it myself so this was slower than I'd like to admit but a good learning experience and really pretty straight-forward to do (although I am glad I was doing this on nice, flat, clean concrete rather than out in the middle of nowhere).
    I didn't bleed and only spilled a beer once so I consider that a win-win.
    I wanted to tighten everything to exact torque specs but buddy (who races KOH and Baja) laughed and said "tight" is right. We compromised - I torqued the 4 steering knuckle to lower ball joint bolts to the correct 58 ft/lbs but just ugga-dugged the axle bolt on with an air ratchet and called it good. No new and/or ugly vibrations or noises on the test drive so I now am happy.
    Got the reboot kit that @turbodb recommended which I will use soon enough to reboot one of the axles and have it with me as a spare but for now it is Miller Time (just kidding, I have better taste in beer than that).
  5. Feb 20, 2022 at 9:32 AM
    Civi
    Civi Active Member
    Carlos
    2004 Impulse Red Dbl TRD 2wd
    265/70R17, Helo Rims, leveling kit, smoked rear lights, led light bar, double din JVC, backup camera, led interior lights, red rock pod lights, led headlights
    Looks good. I'm learning the same painful lesson. Looking for an access or Truxedo roll up. Keep reading about people buying them in the $200's but everything I see is closer to $400. Granted not as bad as those buying $1k+ tops
  6. Feb 20, 2022 at 9:44 AM
    Civi
    Civi Active Member
    Carlos
    Sooo, when I bought my truck it was daylight and although the seller showed me that he had installed rock pod lights there were a number of higher priority things I wanted to make sure were right. Wasn't until 3 nights later when I actually tried to turn them on that I discovered he somehow wired them to the headlights. So every time I turn my headlights on look like this. Yesterday finally found the control module and disconnected them till I can get them wired to a rocker switch
  7. Feb 20, 2022 at 10:07 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I bought a cheapie roll-up from eBay for about $150 new.
    The build quality is decent. The fitment isn't great, but I was willing to make it work for the price.
    The included clamps seemed to be the wrong size. They contacted the vertical part of the bed rail before reaching the horizontal part. I re-used the clamps from the cover I was replacing, which were of a similar design but without the clearance issue. I think I could have made the original clamps work but this was easier.
    The latch is a pain to get to catch. The side rails tend to twist down (maybe I don't have them installed quite right?) and need to be pushed up from the inside when latching. It's especially bad when things are cold and stiff. I haven't had any issues with the latch slipping once it's closed, at least.
    So yeah... it's not great, but it's only $150.
    This is the exact listing that I bought from. There are others that are selling similar/identical products: https://www.ebay.com/itm/173594364403
  8. Feb 20, 2022 at 10:47 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I had the same experience with the cvj "orange/red" boots. Too thin and brittle IMO. Not worth the upgraded price.
    The good news is you have a set of OEM axles now as spares. Reboot them. A messy but not that hard job that will cost about $50/kit.
  9. Feb 20, 2022 at 10:58 AM
    Civi
    Civi Active Member
    Carlos
    Thanks, appreciate the advice. Will check that out. Still trying to figure out if can keep the stock bedliner.
  10. Feb 20, 2022 at 11:46 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Looks great, what size tires?
    Taco Roofer[QUOTED] likes this.
  11. Feb 20, 2022 at 12:17 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I think the geolanders are a pretty underrated tire, they look badass. Side question.. is your grill color matched white? I see your side maker lights are. I got a chrome grill right now and I’m torn between going black or color match white. If you got a picture that’d be great.
  12. Feb 20, 2022 at 2:43 PM
    ijm01PR
    ijm01PR Well-Known Member
    Alex
    Indiana
    01 DC Prerunner (4x4 TBD)
    Ome 881s w/ 5100s and jba ucas 2” pro comp AAL with 5100s in the rear
    Started hacking into the roof for the 4 runner map light. Shoutout to @unstpible and @nzbrock for the idea.
    Never been so meticulous with a knife in my life. Have made about 1200 cuts. Luckily the bracket and mirror bolt right up.
    ireymon, OldTacoDD, seen20 and 9 others like this.
  13. Feb 20, 2022 at 2:47 PM
    ak97taco
    ak97taco Well-Known Member
    Keegan
    Williston, ND
    2016 Tacoma DCSB
    Exterior 2.5" leveling kit Rocktrix 17" wheels 285/65/17 Yokohama Geolandar's Leer shell Diode Dynamic fogs Morimoto XB Amber headlights Alpharex taillights Body Armor Hiline bumper Prinsu roof rack TRD Pro Grille Caliraised LED 42" amber light bar 2 - bumper light bars and 2 pods behind grille Overland Equipped aux power tray Meso Customs puddle pods with switch Interior LED light kit Meso Customs stealth pro shift knob Oostroma dual latching relay for shift knob Clazzio leather seat covers Clazzio seat warmers Quick charge USBs Dual, amber & white lightbar switch from Cali Raised N2 Designs remote start with app Meso customs interior black out kit AJT Designs interior black out kit Taco Garage DSM phone mount
    Took my tonneau cover off and got a camper shell :cool:20220220_150017.jpg
  14. Feb 20, 2022 at 2:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So... What did you do to your 1st gen today?
  15. Feb 20, 2022 at 2:55 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Took my camper shell off to get it ready for paint, kinda miss the open bed look
    Q0ORCdyP4SYZrKL-9_MYsYhAJOId2nC2TIHnpXlE_040879605edf3277e57ea442591a17c1be3402b8.jpg
    lCGK2H-VlJJkgU6YAs9AsP9pCYDszjbJWDghEOyk_fa7169acb6f5b5c740514e46aabb61e3968a1945.jpg
  16. Feb 20, 2022 at 3:00 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Nice! I should really get one of those brackets. I just epoxied a nut to the roof and it's somehow held up for years.
    ijm01PR[QUOTED] likes this.
  17. Feb 20, 2022 at 3:06 PM
    ijm01PR
    Alex
    Indiana
    Sweet. Yea at the LKQ, I almost didn’t leave with the bracket thinking it wouldnt be compatible but it bolted right up just gotta splice the wire now. Are the bulbs 3175s like the taco?
  18. Feb 20, 2022 at 3:25 PM
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
    Installed a tonneau cover for a 3rd gen on my 1st gen, paid $450 from Amazon.
    Also utilizes a bed rail from 2nd gen frontier to make it work.
  19. Feb 20, 2022 at 7:20 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Wooweee busy weekend, certainly felt like it took more time then I would’ve expected
    • Installed backup cam
    • Flushed & replaced power steering fluid
    • Rust mitigation and removal - prep for weld
    • Replaced lazy driver side seat belt
  20. Feb 20, 2022 at 7:59 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Did Stop Tech braided steel brake hoses. Took forever. One of the hose clips went flying and I must have spent 90 minutes searching for it. Still need to bleed the brakes, I just ran out of time and patience today.
