  1. Feb 20, 2022 at 9:45 PM
    foothill96tacoma
    foothill96tacoma Well-Known Member
    What did you replace it with?
  2. Feb 20, 2022 at 9:48 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    A belt out of a parted out Taco from another TW member - works like new - still have the old one may try the re-tension trick and pass it on
  3. Feb 20, 2022 at 10:15 PM
    Funch
    Funch Well-Known Member
    Replace LED lights with halogens (orsams nightbreakers)
    cleaned up the engine bay with a nice rub down
  4. Feb 20, 2022 at 11:32 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well I've done the daily mod, long ago actually. But I did the next most important mod, the shop mod.
  5. Feb 20, 2022 at 11:37 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Congrats!
    Speedytech7[QUOTED] likes this.
  6. Feb 20, 2022 at 11:39 PM
    Speedytech7
    Thanks! How did the land scouting go BTW?
  7. Feb 20, 2022 at 11:44 PM
    Empty_Lord
    Dan
    I liked it enough to look into it more. I’m waiting to hear from the county about building what I want before I give an offer though.
  8. Feb 21, 2022 at 4:27 AM
    Phessor
    Phessor Well-Known Member
    Very nice, I'm still working out on the driveway...
  9. Feb 21, 2022 at 5:17 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’m biased, but I’d say go for the color match.
    I had to sand and paint the chrome trim on the corner lights, but I love the way it turned out.
  10. Feb 21, 2022 at 9:08 AM
    roboturner
    Colorado
    How long ago did you do that & how's it holding up? any good tips for painting the chrome?
  11. Feb 21, 2022 at 9:10 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Looks like a great space to work in. Is that black panel like a story board?
  12. Feb 21, 2022 at 9:59 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Did you mean air impact? An air ratchet won't get that near tight enough. I want to say 210ftlbs is the spec. That is one nut where torque is fairly important for bearing life. I don't torque mine but make sure it's plenty tight with a breaker bar.
    I like the open bed look on mine so much better than with the Wildernest on it.
    DashMaple[QUOTED] and jubei like this.
  13. Feb 21, 2022 at 10:00 AM
    Speedytech7
    It's been painted in chalkboard paint yeah.
  14. Feb 21, 2022 at 10:06 AM
    eon_blue
    Azusa, CA
    175 ft/lbs but yeah, if he used a ratchet then he'll want to take the wheel and cap off and tighten it down. My bigger torque wrench broke so I use my smaller one and get it to 150 ft/lbs, then use hit with an impact to give it another quarter turn or so.
    been there done that with wheel bearing failure due to improperly installing the axle nut, it's not fun
    Digiratus likes this.
  15. Feb 21, 2022 at 10:40 AM
    jubei
    NoCo
    Stuff. Also things.
    It’s been almost five years now, but the paint over the chrome has started to fail over the last year or two.
    The moral of the story is to not be lazy like me and only do a token bit of sanding on the chrome. I’m fairly positive that with better prep, they would last much longer and look better. But they lasted at least three years with my crappy prep work, though, so there’s that.
    my2coma likes this.
  16. Feb 21, 2022 at 11:09 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Was out wheeling yesterday and heard a loud pop. I was going up a icy ledge and was locked front and rear. After the pop, Front passenger had no power when I locked the front. When I unlocked I was essentially in 2wd and every now and then I could hear some nasty noises. I then threw it in 2wd and got tugged out of the trail. At first I thought I blew a CV, but I was able to drive home (1 hour drive). I haven't tore into yet, but now I'm wondering if I fucked up the diff. Any input or ideas?
    unstpible likes this.
  17. Feb 21, 2022 at 11:20 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    If I'm a gamblin' man, I'm going with: front pass axle decided to split...
    Fernando[QUOTED] likes this.
  18. Feb 21, 2022 at 11:21 AM
    eon_blue
    Azusa, CA
    When I blew a CV it was similar...while in 4wd it sounded awful but was able to drive it in 2wd. Didn't go very far before swapping it out though. Have you looked underneath at it? Should be pretty obvious if the CV looks OK or fubar'ed.
    my2coma and Fernando[QUOTED] like this.
  19. Feb 21, 2022 at 11:45 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I'm hoping that's all it is
    I took a peep. It has side to side play and the boot tore too. I'm going to swap the axle and go from there. :fingerscrossed:
  20. Feb 21, 2022 at 12:00 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Are those something you can just buy or did you find it at a part out?
    ijm01PR[QUOTED] and unstpible like this.
