  1. Mar 21, 2022 at 10:32 AM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    If you happen to come across any more good ones, I'll buy one off ya.
    Empty_Lord[QUOTED] likes this.
  2. Mar 21, 2022 at 10:39 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Oh I shall. Soon I have to clear out all the diffs I have. So anyone looking to regear? Ask lol
    Captain Magma[QUOTED] likes this.
  3. Mar 21, 2022 at 10:41 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I was going to say I'd buy a non working one off you if reasonably priced, but preferably without holes... :p
    ToyRyd04 likes this.
  4. Mar 21, 2022 at 11:14 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    My rear diff housing is pretty crusty rusty and you aren't that far from me. Not interested in regearing though. Hmm...
  5. Mar 21, 2022 at 11:21 AM
    Empty_Lord
    Dan
    I just have the 3rd members. Housings are a different story
  6. Mar 21, 2022 at 1:24 PM
    Morden
    Morden Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    I'm going to order a set of Spicer u-joints this week in preparation for drive shaft rebuilding. Prices seem to be all over the map for the 5-1510X's:
    Amazon: $26.10
    The U-Joint Store: $38.00
    O'Reilley's: $50.00
    Strongly tempted to go with the first option but afraid of receiving a counterfeit product. Can't risk that in such a critical location, and as they say, if something sounds too good to be true... :rolleyes:
    I'll probably hit up the U-Joint Store. Thoughts?
  7. Mar 21, 2022 at 1:33 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    So broke a wheel stud, should I just swap in an OEM one or should I swap them all (front ones) out for extended studs? Running SCS wheels so I don’t think it’s needed but would it be worth running extended studs and extended lug nuts (came with the wheels)
  8. Mar 21, 2022 at 2:05 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I just got some from Autozone, $1.80 a piece, stock length and changed em if the stockers break.
  9. Mar 21, 2022 at 3:00 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Gotcha so extended length isn’t worth swapping the other 11 as well since I’m “in that far”
  10. Mar 21, 2022 at 3:03 PM
    Speedytech7
    You're not really in far to change studs in fact the most you have to do is take off your rotor or drum
  11. Mar 21, 2022 at 4:18 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Thanks. I do a bit of laser cutting with plastics and some machining, but never really any forming. I'm more of a metal guy, machining/fab work. These were my second set, the first weren't bad, but not enough coverage.
  12. Mar 21, 2022 at 4:48 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Finally got my trans cooler installed after sitting for almost a year
    So far no more 190F+ moments in traffic
    unstpible and Parkvisitor like this.
  13. Mar 21, 2022 at 5:15 PM
    03_taco_IN
    03_taco_IN Well-Known Member
    Indiana
    2003 xtracab sr5 v6 trd
    Blue wire/ grey wire/rear diff breather mod/881s w/bilistein
    I'm still looking for a rear diff. If you have one that's not too crusty. Just the third is all I need
    unstpible likes this.
  14. Mar 21, 2022 at 5:18 PM
    Empty_Lord
    Dan
    I totally forgot you wanted one. If you want a third member I’ll check this weekend. Pretty sure a couple of them are minty.
    As for fronts I have a crusty 4runner diff with vacuum ADD. That’s about it
    To be clear. I have no housings. Hell I’m looking for one for my Fathers 2002.
    unstpible and DashMaple like this.
  15. Mar 21, 2022 at 5:22 PM
    03_taco_IN
    Indiana
    I just happened to find a front diff this past weekend out of a 01 runner with add....that's all they had left of the truck though, it was sitting on a shelf. But yea if you could look this weekend and think on a price I could prolly drive up your way next weekend. All I'm missing for my regear is the third. Thanks
    unstpible and Empty_Lord[QUOTED] like this.
  16. Mar 21, 2022 at 5:25 PM
    Empty_Lord
    Dan
    If your making the drive up here your more than welcome to just have one. I think I’ve got 6-7 of them. I’ll take a look. If I’m out of work early enough one day I’ll make it there sooner
  17. Mar 21, 2022 at 5:28 PM
    03_taco_IN
    Indiana
    Yea I'm 45 min east/southeast of Indy so it would be a cruise...just let me know...if I don't see you post anything by next week I'll ask again
  18. Mar 21, 2022 at 5:32 PM
    Empty_Lord
    Dan
    Tag me in the lunch table if I forget
    unstpible and 03_taco_IN[QUOTED] like this.
  19. Mar 21, 2022 at 6:41 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    AZ4x4Taco, Plkyone, unstpible and 4 others like this.
  20. Mar 21, 2022 at 7:07 PM
    DashMaple
    Louisiana
    I have a housing that needs a cover welded on but besides that its in pretty solid shape
