  1. Mar 24, 2022 at 7:58 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    The sway bar end link is busted, you say?
    You didn't notice it was broken. or have any idea how long it's been broken, you say?
    Sounds like you wont even notice, when it goes to the scrap yard :)
    unstpible likes this.
  2. Mar 24, 2022 at 9:44 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Installed a Hayden transmission cooler. So far so good
    Area51Runner and DashMaple like this.
  3. Mar 24, 2022 at 10:24 PM
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
    how much for the 60/40 bench and where are located?
  4. Mar 25, 2022 at 7:30 AM
    FatBilliam
    FatBilliam Well-Known Member
    East TX
    '97 3.4l 5spd Ext. Cab
    So OEM is the answer? Obsolete Equipment Mitigation?
  5. Mar 25, 2022 at 7:36 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Someone woke up and chose violence this morning
  6. Mar 25, 2022 at 7:40 AM
    FatBilliam
    East TX
    Knowing is half the battle, the other half is violence.
  7. Mar 25, 2022 at 8:16 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Keep it up, everyone started where you were. Installing and repairing items on these rusty battleships is no small chore. You'll learn techniques that you will build off of and with enough influence/peer pressure.....you'll start hacking old parts off and welding new shit on!:welder:
    Area51Runner, cynicalrider and jubei like this.
  8. Mar 25, 2022 at 8:21 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I washed my winch rope for the first time. And I installed a rope gard that had been sitting in my tool box for the last couple of years. It's all Gucci now. Like yesterday's Gucci but still none the less. Oh and I washed the truck too.
    BeLance89, SwampYota and jubei like this.
  9. Mar 25, 2022 at 8:31 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    100% :thumbsup:
    As long as you're running upgraded shocks/coils you wont feel so much roll.
    And if you're lifted, the sway bar isn't actually doing the job the way it was intended to do anyway, unless you lengthen the sway bar end links equivalent to the amount of lift.
    I've been running no sway bar for quite a while, I'm heavier than most, and I do a lot of driving. I have never found myself in a situation where I wished I had the sway bar.
  10. Mar 25, 2022 at 8:54 AM
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    Have you noticed any difference in trans temps?
    unstpible[QUOTED] likes this.
  11. Mar 25, 2022 at 12:08 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Throttle body just came back from Maxbore. Looks clean! I’ll get a picture later when I install it Sunday. Got a good feeling that it’s not gonna fix my high idle so I’m thinking my next course of action might be new thermostat and/or coolant temp sensor? Its on its second new IAC valve and every hose is new so it can’t be those two things.
    The mystery continues…..
  12. Mar 25, 2022 at 12:14 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    And I can’t find the throttle position sensor on McGeore Toyota. What brand do we go with when it comes to the TPS other than OEM?
  13. Mar 25, 2022 at 12:17 PM
    foothill96tacoma
    foothill96tacoma Well-Known Member
    Have you searched for the part number elsewhere in case someone else has the Denso/Toyota part? My experience is that the cheaper TPSers don't last long before causing problems.
  14. Mar 25, 2022 at 1:31 PM
    JKO1998
    Utah
    This is fine right
    unstpible and Yetimetchkangmi like this.
  15. Mar 25, 2022 at 1:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  16. Mar 25, 2022 at 4:36 PM
    TheBraves
    TheBraves Active Member
    West Virginia
    1999 Toyota Tacoma Reg Cab 4x4
    2.5 Rough Country strut lift. All new springs. 33/12.5/15 Mickey Thompson MTZ. 15x8 wheels.
    02CAFFC2-9AB6-434A-A69C-EB36448A466D.jpg So finally got the mirror upgrade. New wheels and tires this week.
    ireymon, SpokeWench, ijm01PR and 8 others like this.
  17. Mar 25, 2022 at 4:49 PM
    unstpible
    Derek
    Cedar City, Utah
    Temp seems to be holding steady since it's been parked in the garage haha.
    There's a specific spot up a local road that usually cooks the transmission pretty fast. I need to drive it up there to get a good comparison but It was running at 155° around town
    Yetimetchkangmi likes this.
  18. Mar 25, 2022 at 8:51 PM
    FatBilliam
    East TX
    Knocked out the passenger side LBJ, outer tie rod, and CV. You can also see my snapped sway bar link here which we were unable to get loose so I had to hit it with the sawzal :sawzall:
    CV was completely loosey-goosey so it came out in two parts (actually made it pretty easy since the outer joint and shaft were greased and loose and I could get my cobra pliers on the inner joint to yank out). Feeling good about it but still staying ready to tackle to driver side LBJ and tie rod tomorrow AM and still increasingly eager to get my OME setup.
  19. Mar 26, 2022 at 8:03 AM
    scofflaw
    scofflaw Well-Known Member
    I replaced both sway bar end links with OEM this summer and it made a huge difference with the rolling wobble I felt at highway speeds when the bed was loaded. I considered the Moog ones but ultimately went OEM. There are some overlander expedition brand ones that are super thick and look more durable than the OEM ones but I stuck with the OEM. Like you, at least one of mine was completely broken.
    Probably obvious but I found the two wrench method was needed for tightening the nut that connects to the sway bar because otherwise it twists the ball joint all sideways. Allen key needed to loosen the connection with the LBJ but I don’t think needed to tighten. Oh and I found that I had to use a tie bar or ratchet strap in order to get the sway bar down onto the threaded rod part of the link—the rubber bushings are thick and so only the very ends of those threads are exposed at first. Also the torque specs for the two nuts are quite different, the top one is only like 28 or something and the lower one to the LBJ is like 48 I think (or vice versa).
    4258525A-5764-4DAC-B3F6-D812CA10AB39.jpg 3832C16B-A3F6-4B8D-AB8F-3745ACB33247.jpg 70DA993F-AE62-4A5B-9583-B5BB5A0E3DF1.jpg DAB39A1D-12DF-48AD-8F68-2D7BAE18F197.jpg 3CF01EDF-E7B7-4EDE-AB68-F27277D63369.jpg
    Area51Runner and SwampYota like this.
  20. Mar 26, 2022 at 8:54 AM
    FatBilliam
    East TX
    Driver's side LBJ and tie rod end done. I think it took longer to Tetris all my tools back in the bag than it did to do the actual job.
    Good info and kinda weird that both our snapped links were the passenger side (I guess the odds are 50/50 that would be the case... or are they?). I'm going to ride with it disconnected for a while and then decide if I'm going to restore or delete.
