  1. Apr 6, 2022 at 6:38 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Friend came over yesterday and we both felt motivated, took the bed off, made a new shock x-member, welded shock mounts on, installed shocks, then took the front apart and liberated the sway bar and stock coils for some SAW coilovers.
  2. Apr 6, 2022 at 7:46 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Lost my brakes on the way to work yesterday after my neglect of the obvious warning signs past couple weeks. What a bitch it is to do the rotors and pads :rofl::rofl:
  3. Apr 6, 2022 at 9:50 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's pretty easy on a 6lug. Not sure if it gets any easier honestly.
  4. Apr 6, 2022 at 9:59 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    5 lugs are a ball of joy,
    hopefully they last till i cut the front off for new suspension
  5. Apr 6, 2022 at 11:12 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Anyone have a Volant intake and can do me a quick favor? I need to see roughly how much clearance there is to the inner fender on the back outside corner by the cruise control etc.
    unstpible likes this.
  6. Apr 6, 2022 at 11:20 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    @Rldanie
  7. Apr 6, 2022 at 1:01 PM
    TacoJim333
    TacoJim333 Member
    Jim
    2001 Tacoma xtra cab
    2 in lift.
    Added cell phone holder few days ago. Just Popped out the plastic blank plate on dash. Took a Cupholder cell54171397-B728-48BC-95DB-1BA5630701EC.jpg phone type cut it off close base. Added piece rubber for soft spacer between it & plate. Fastened from behind with 3/16 short bolts. Seems hold it fine.
    chrslefty and unstpible like this.
  8. Apr 6, 2022 at 1:27 PM
    Shortman5
    Supercharged TRD
    Only issue with this spot is the heat will lock your phone up. Turning the closet vent to the passenger side helps keep it from overheating.
  9. Apr 6, 2022 at 1:37 PM
    TacoJim333
    TacoJim333 Member
    Jim
    2 in lift.
    Yes kind figured that’s exactly why I made it longer si it’s about 3 inches out. Hard tell from angle took pic. I typically put heat on floor after windshield is defrosted anyways…
  10. Apr 6, 2022 at 2:18 PM
    Reh5108
    Idaho
    Never had a problem with the heater causing it to shut down my phone. The sun hitting it through the window from being parked has. The AC also cools it from that scenario once you get going. Mine is only maybe 1.5" away from it.
  11. Apr 6, 2022 at 6:53 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I put the new Hayden trans cooler to the test today. Very impressive results. A few spots where I've hit 220°f in the past barely hit 180 this afternoon with 45mph winds I was headed North on I-15 out side of St George back to Cedar City after the dealership told me the couldn't find my evap leak
  12. Apr 6, 2022 at 7:39 PM
    unstpible
    Derek
    Cedar City, Utah
    90's ford's have a single pin holding the front calipers in place. That's got the be the easiest brake job I've ever done
    Reh5108[QUOTED] likes this.
  13. Apr 6, 2022 at 7:41 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I did caliper, pads and rotor on both sides in less than an hour last fall. I made a stupid mistake that snow balled into an expensive, couple week job, but it coulda been real quick.
    unstpible and Reh5108[QUOTED] like this.
  14. Apr 7, 2022 at 5:20 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    I’ve got one but I won’t be home to measure it until tomorrow afternoon. I'll send them tomorrow if you still need it.
  15. Apr 7, 2022 at 6:27 AM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    Sounds like there’s a good story to this?
  16. Apr 7, 2022 at 8:16 AM
    JKO1998
    Utah
    Not really, I put the calipers on the wrong side and thought the booster gave out finally when I couldn’t bleed them haha…
  17. Apr 7, 2022 at 8:37 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Lefty tighty righty loosy.
    BeLance89 likes this.
  18. Apr 7, 2022 at 8:44 AM
    JKO1998
    Utah
    Common knowledge
    I’m an engineer, not mechanic
  19. Apr 7, 2022 at 10:10 AM
    2pei
    2pei Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    was that blank plate where the passenger airbag switch was located??
  20. Apr 7, 2022 at 3:34 PM
    Kansas_Taco
    Kansas_Taco Well-Known Member
    Tim
    2002 Green Extended Cab - SR5
    Finally got my strut assemblies fixed and installed. Billy 5100's with Wheeler's T1's on the 0 notch. Love how everything is tight in the steering and responsiveness. Now I can feel how bad my tires are. lol
    Wheels and tires up next (and a new carrier bearing, just in case).
    nagorb and m3bassman like this.
