  1. Apr 20, 2022 at 11:52 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I prefer using long ass extensions into the wheel well haha
    slander likes this.
  2. Apr 20, 2022 at 11:56 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    If you take the air box out it isn’t bad at all to deal with
  3. Apr 20, 2022 at 12:13 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    The tensioner or pulling the pump? Removing the airbox is almost essential for pulling the pump (have done both ways many times and it sucks way less with the box out), but to just adjust the belt you don't need to.
  4. Apr 20, 2022 at 12:21 PM
    JKO1998
    Utah
    Noted
    unstpible likes this.
  5. Apr 20, 2022 at 1:38 PM
    Civi
    Civi Active Member
    Carlos
    2004 Impulse Red Dbl TRD 2wd
    265/70R17, Helo Rims, leveling kit, smoked rear lights, led light bar, double din JVC, backup camera, led interior lights, red rock pod lights, led headlights
    Thanks, will do
    96BlueTacos[QUOTED] likes this.
  6. Apr 20, 2022 at 2:19 PM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    Hobo shade V3!
    Two 9' that are about the same in square footage as two full size ARB awnings
    JPinFL, chrslefty, unstpible and 2 others like this.
  7. Apr 20, 2022 at 9:20 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Took mine apart….
  8. Apr 21, 2022 at 7:53 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I've searched, found info, but not really details. My 01 double cab needs new body mounts, seems like all the available options are only for xtra cabs or oem which is $. Anyone find a solution? Or know what durometer polyurethane is typically used?
  9. Apr 21, 2022 at 8:59 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Mine has a noticeable knick on it, but I am just too lazy to change it. Guess it's future me's problem haha
    ....don't worry it'll honestly get changed here in the next week or so
    AssQuake[QUOTED] likes this.
  10. Apr 21, 2022 at 9:04 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    I just changed my drive belts tonight, man that steering pump belt is a b*tch
    On the plus side it seems to idle smoother
    on the other hand...I still need to do my timing belt after having a kit sitting on the shelf for a year now :anonymous::anonymous::anonymous:
    AssQuake and unstpible like this.
  11. Apr 21, 2022 at 9:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The Xtra cab ones won't work. Your only option is OEM I'm afraid. I tried the others thinking it wouldn't matter, it does. A lot.
    nagorb[QUOTED] likes this.
  12. Apr 21, 2022 at 10:04 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    DashMaple likes this.
  13. Apr 21, 2022 at 10:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that sounds like a rotor rubbing a pad.
    Wheel bearings in my experiance sound like a rumble. If they get REALLY bad its like a shrieking pepper grinder and you would pull over immediately.
  14. Apr 21, 2022 at 10:35 PM
    betterbuckleup
    Ian
    Concord, CA
    That's what I was thinking possibly.
    Going to check it out later, but I haven't ever had to replace a wheel bearing so I wasn't sure what to expect.
  15. Apr 21, 2022 at 11:29 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Good ol Russian door check repair on both drivers side doors
    and a metal handle for the driver's door
    warmingupmymind likes this.
  16. Apr 22, 2022 at 9:47 AM
    DashMaple
    Louisiana
  17. Apr 22, 2022 at 10:28 AM
    Winkle99
    Winkle99 Don't Look Back
    David
    CO
    99 XCab 3.4 Manual 4x4 TRD SR5
  18. Apr 22, 2022 at 10:33 AM
    eon_blue
    Azusa, CA
    I've had pretty much the same sound happen after doing water crossings or driving through mud pits on the trail, like a little rock or something gets wedged in the brakes and makes a rotational squealing noise until it pops out. Did it go away eventually or?
    I've had a wheel bearing go bad and it's definitely more of a low grinding sound rather than a squeal
  19. Apr 22, 2022 at 11:35 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Having a weird issue with my auto shifter. When I put it in park, I have to give it a second bump for it to click in place. Anyone got ideas on why that would be?
  20. Apr 22, 2022 at 11:50 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Worn out linkage bushings be my guess, @Brice sells some
