  1. May 15, 2022 at 9:21 AM
    TacoJim333
    TacoJim333 Member
    Jim
    2001 Tacoma xtra cab
    2 in lift.
    I say so ⭐️ looks Fantastic Nice set up. What size are those All terrains? Jim
    ijm01PR[QUOTED] likes this.
  2. May 15, 2022 at 9:52 AM
    ijm01PR
    ijm01PR Well-Known Member
    Alex
    Indiana
    01 DC Prerunner (4x4 TBD)
    Ome 881s w/ 5100s and jba ucas 2” pro comp AAL with 5100s in the rear
    Thanks. They are 265-75-16
  3. May 15, 2022 at 10:29 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
  4. May 15, 2022 at 10:30 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    That sucks.
    Kwikvette likes this.
  5. May 15, 2022 at 10:33 AM
    unstpible
    Derek
    Cedar City, Utah
    I've had great results with the VHT stuff. Hope it lasts for you as well
  6. May 15, 2022 at 10:39 AM
    unstpible
    Derek
    Cedar City, Utah
    I did put some RTV down before the A pillar bracket and used a little extra around the rivits so hopefully it at least sealed good for now. It feels pretty secured and I think the Safari Snorkel in my 2nd gen only used self tappers on the A pillar.
    Did yours get ripped off on some brush or a car wash?
  7. May 15, 2022 at 10:48 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The rivits should be fine as far as strength and it seems you sealed it well with the RTV. None of that is the issue.
    The problem is, if you ever have to replace your windshield, you'll probably have to drill out those rivits. It can be pretty hard to find a glass shop that will to install a windshield with the snorkel attached. Because they can't set up and drop the windshield straight in. They would have to manuver around the snorkel.
  8. May 15, 2022 at 11:12 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Well, need some advice. In the middle of an alternator swap and while trying to loosen the bottom bracket i loosened a oil pump cover bolt instead. The one circled in red is the one I broke loose. When I reached up feeling around for the bracket I knew I got the wrong bolt.
    So I’m looking for torque specs so I can get this back down correctly and there’s two specs for two different sets of bolts but I can’t find a diagram anywhere.
    anybody have any idea if it’s 15ftlb or 31ftlb?
  9. May 15, 2022 at 11:17 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I don't think any of that is necessary.
    I did not have a problem 2 years ago when I had mine replaced. Called ahead to double check though.
  10. May 15, 2022 at 11:30 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Fortuanately I used rivnuts. Checked with 4 shops, and none of them would do it with the snorkel on. (was being lazy and didn't want to remove it). Ended up removing it and getting it done.
    Now, thinking about it, I can understand why they wouldn't want it in the way... and actually, wouldn't really trust a shop to do it with the snorkel on the truck.
    Reh5108[QUOTED] likes this.
  11. May 15, 2022 at 2:06 PM
    FatBilliam
    FatBilliam Well-Known Member
    East TX
    '97 3.4l 5spd Ext. Cab
    All done installing the lift. I'm not measuring on level ground but I definitely got ~1.5-2" in front and ~2.5-3" in the back from where it was. There is a decent amount of rake but I know the leafs should settle over time. Thoughts on what should come next between 33s, UCAs, or a front bumper?
  12. May 15, 2022 at 4:32 PM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
  13. May 15, 2022 at 7:36 PM
    unstpible
    Derek
    Cedar City, Utah
    Makes sense
  14. May 15, 2022 at 7:38 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Let er eat!!! She ate!! My son finally got to hammer down
  15. May 15, 2022 at 8:11 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    [​IMG] Picked up an organ and skeleton donor today.
    2001 v6 5 speed. Frame will hopefully get the 98 back on the road, bumper if it can be straightened out will go on the 2002 as well as the rear leafs, front suspension on my 1995, and I may manual swap the double cab with all these parts
    tbose who know, will notice who’s truck it was
  16. May 15, 2022 at 8:27 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Looks vaguely familiar.
    what road and Area51Runner like this.
  17. May 15, 2022 at 8:39 PM
    Empty_Lord
    Dan
    Indeed.
    what road likes this.
  18. May 15, 2022 at 10:40 PM
    unstpible
    Derek
    Cedar City, Utah
  19. May 15, 2022 at 11:51 PM
    Locot@co
    Locot@co Well-Known Member
    2001 Green Prerunner
    Switched over to an AGM battery, replaced the broken top post terminal, cleaned up wiring w/ blue seas fuse box & drew a terrible sketch of the Toyota fuse box layout for a just in case reference in the glovebox.
  20. May 16, 2022 at 7:18 AM
    03_taco_IN
    03_taco_IN Well-Known Member
    Indiana
    2003 xtracab sr5 v6 trd
    Blue wire/ grey wire/rear diff breather mod/881s w/bilistein
    Will you be willing to part with the rear driveshaft. I can't seem to find one down here.
