  1. Jun 15, 2022 at 11:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Don't forget, you need his trd headers and trd exhaust too... :bananadead:
    unstpible likes this.
  2. Jun 15, 2022 at 11:16 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    well. i mean. for my 1998 i'd LOVE to have it. but those are useless to me on the 01 or 95.. @eon_blue my 2002 will be for sale most likely once she gets her new frame!
  3. Jun 16, 2022 at 8:54 AM
    Arman Bagdasarov
    Arman Bagdasarov armbag
    2001 4x4 Tacoma
    Camburg UCA, King coil overs, Fox Shox, Deaver springs, BAMF sliders & LCA Skids, Relentless Skids. Lights on lights on lights
  4. Jun 16, 2022 at 8:56 AM
    Arman Bagdasarov
    2001 4x4 Tacoma
    Isn’t it supposed to be black?? :anonymous:
  5. Jun 16, 2022 at 10:01 AM
    eon_blue
    Azusa, CA
    paint it black and stick a kazoo in the grill, won't even need to fill up with 91
  6. Jun 16, 2022 at 10:07 AM
    1997tacomav6
    Denver
    Not a supercharger, hope I didn’t pay too much
    Taco critter likes this.
  7. Jun 16, 2022 at 10:48 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Idle is starting to.. how can I describe this.. “flutter”? On cold starts for about 20 seconds and then will smooth out eventually. Stays around 1100 rpm regardless. Thoughts?
  8. Jun 16, 2022 at 11:02 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    If you want to put the icing on the cake, replace the main two sway bar bushings as well. It was one of the most notable changes I’ve made after doing all the same work you have, and cost under $20.
    PaulIsOnThePhone and unstpible like this.
  9. Jun 16, 2022 at 12:05 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    What improvements did you notice? My truck has a fair amount of roll, wouldn't mind improving my sway bar.
  10. Jun 16, 2022 at 12:09 PM
    Tacoscar-the-grouch
    Tacoscar-the-grouch Well-Known Member
    Josh
    North Idaho
    2001 Reg. Cab Tacoma
    OME kit 4.56's 235/85/16
    Finally got my trail gear bumper installed, new synthetic line on the winch, and rewired and relocated solenoid under the hood. Oh and new headlights and blinker relocation.
    Need to get the bud built skids painted and installed next, then relocate the washer fluid reservoir.
  11. Jun 16, 2022 at 3:06 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I repainted my sliders, they were starting to get pretty bad.
    During.
    After.
  12. Jun 16, 2022 at 3:39 PM
    Rastopher
    Ras
    Sacramento, Ca
    Less roll, seemed to tighten the front end up
    ztwatson[QUOTED] likes this.
  13. Jun 16, 2022 at 5:18 PM
    TACO_GUY03
    TACO_GUY03 Well-Known Member
    Houston, TX
    03 Tacoma Xtra-cab 4x4 v6
    Wildpeaks got delivered today… finally got to mount tires on my SCS wheels
  14. Jun 16, 2022 at 5:53 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Stripped the last valve cover bolt. The rest came off easy. I have a second ride fortunately. This is a tomorrow problem. What do what do…..
  15. Jun 16, 2022 at 6:26 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Iac is dirty? Or vacuum leak?
  16. Jun 16, 2022 at 6:43 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Paint those fenders :gossip:
    unstpible and chrslefty[QUOTED] like this.
  17. Jun 16, 2022 at 6:55 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Fenders? Or fender flares? I agree though
  18. Jun 16, 2022 at 7:11 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    IAC is brand spanking new and so are the hoses.
  19. Jun 16, 2022 at 8:52 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Welded up the spindles, seemed pretty true. So did it in time!
  20. Jun 17, 2022 at 1:59 AM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    I knew I was gonna get some crap for this. Last time I tried to paint paint them it was a shit show.
    I think I'm going to hit them with raptor liner. I'm trying to decide if I want to take them off again or just shoot them on the truck.
