  1. Jun 29, 2022 at 7:14 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Jus blown cv boots and a winch on a tree
    unstpible likes this.
  2. Jun 29, 2022 at 7:43 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    700k!!! Wow! Good stuff
    1997tacomav6[QUOTED] likes this.
  3. Jun 29, 2022 at 7:43 PM
    Chungas
    Chungas Help! My Ferret has lost its stank!
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    That works but let's start here
    Out of gas? Chain broke? Sudden guilt? Caught on fire?
    Wulf likes this.
  4. Jun 29, 2022 at 7:49 PM
    JKO1998
    Utah
    Well… The chain saw was running very good, chain wasn’t sharp, it’s leaning over a house so we winched it over.
    just a combo
  5. Jun 29, 2022 at 8:32 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Got my northwest fab box assembled and ready to test fit in the truck.
  6. Jun 29, 2022 at 9:19 PM
    bugly64
    bugly64 Member
    Bryan
    1997 Extended cab Tacoma
    Got a bluetoothy double din for my 97 Tacoma
    And right after the stereo was installed I got a blow-out on 80 E heading to Sacramento, so I put 4 new tires on the truck, too.
  7. Jun 30, 2022 at 11:12 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Tweaked a couple previous mods for "old guy convenience camping" after a bunch of my stuff was stolen out of the garage. More details in the usual place.
    Built another inflator, this time with a second hose to fill two tires at once.
    Added a little bity switch in the RTT for my LEDs, which I previously had to turn on/off from a switch located in the bed - doable, but inconvenient.
  8. Jun 30, 2022 at 2:03 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Okay, installed a new oem upper/ lower radiator hose, oem thermostat and oem rad cap. As well as flushing the system again. And all new coolant. Taking it out tomorrow to camp this weekend so we will see if the temp problem has been fixed.
    Area51Runner and unstpible like this.
  9. Jun 30, 2022 at 2:12 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Is the temp problem with the coolant system or the transmission? Or, both?
  10. Jun 30, 2022 at 2:33 PM
    Dan8906
    Daniel
    Concord, California
    Both, but seperate. Although I think the trans is in a much better place now with the divorced cooler. And coolant system is still technically okay, as it’s within normal operating temps, just recently more on the hot side. So I think my weekend trip will give me a better feel for how things are looking.
  11. Jun 30, 2022 at 2:38 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Right on. I thought so, but it seemed the subject kept jumping back and forth from trans to radiator... that all makes more sense (to me) now.
    When I was having a lot of problems running hot, I found that the lower radiator hose was collapsing under harder throttle. I put a spring in it, that wont allow it to collapse, that seemed to help. I haven't had any problems since.
    I did some other stuff to address the heat issues as well, but the spring seemed to make an immediate impact.
    unstpible and Dan8906[QUOTED] like this.
  12. Jun 30, 2022 at 3:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    thermostat installed correctly?
  13. Jun 30, 2022 at 3:25 PM
    Dan8906
    Daniel
    Concord, California
    It was yes, and I boiled it after, seemed to work fine. So I don’t think that will be doing anything.
    unstpible and Blackdawg[QUOTED] like this.
  14. Jun 30, 2022 at 7:52 PM
    TheKoda
    TheKoda Member
    2004 PreRunner SR5
    LEDs in the instrument cluster and paracord around the "oh shit" handles
    20220629_213851.jpg 20220630_202311.jpg 20220630_202243.jpg 20220630_202206.jpg
  15. Jun 30, 2022 at 9:08 PM
    1997tacomav6
    Denver
    New raptor lights and grille
  16. Jul 1, 2022 at 10:33 AM
    mopar2
    mopar2 Well-Known Member
    Franklin TN
  17. Jul 1, 2022 at 10:41 AM
    mopar2
    Franklin TN
    Can I get some info on the grille?
  18. Jul 1, 2022 at 12:17 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
  19. Jul 1, 2022 at 12:25 PM
    1997tacomav6
    Denver
    unstpible and SwampYota like this.
  20. Jul 1, 2022 at 3:39 PM
    oreganoflow
    oreganoflow Well-Known Member
    Gerald
    2021 Tacoma TRD Pro
    A few
    love the supercharger mod...
    m3bassman and 1997tacomav6 like this.
