  1. Jul 11, 2022 at 11:50 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Look at your kick panel area, the door closed switch. Most likely corroded or wire may be exposed. Mine was, new switches are not toyota specific and can get cheapish.
    https://www.amazon.com/Standard-Cou...gid=pla-870407016206&ref=&adgrpid=93124985719
    unstpible and Reh5108[QUOTED] like this.
  2. Jul 11, 2022 at 11:50 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Got the Spiker hood struts installed yesterday. Will be nice to have the extra clearance for some of the upcoming jobs I have planned.
  3. Jul 11, 2022 at 11:55 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    I recently received mine. Looking forward to putting them in
  4. Jul 11, 2022 at 11:57 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Drivers kick panel is where the junction is for it, pin always kept coming lose in my grey truck
  5. Jul 11, 2022 at 11:59 AM
    Speedytech7
    unstpible and Reh5108 like this.
  6. Jul 11, 2022 at 12:04 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I guess I'll just remove the cat, retain the O2 sensor, and see what happens for now. :notsure:
    Oh, and truck update - cut an even bigger hole in my floor.
  7. Jul 11, 2022 at 12:05 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  8. Jul 11, 2022 at 12:08 PM
    Speedytech7
    I think you can go bigger
  9. Jul 11, 2022 at 12:22 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    So this showed up on a big freight truck. Driver was cool and brought it all the way up the driveway to the garage for me using the pallet jack. 4x2 -> 4x4 is definitely real now. Need to give this thing a good once over and wrap up a few other items (finish assembling the knuckles and button up the transfer case) then it will be time to start installing.
    Transmission is out of a 99 4Runner, no collision damage. Tree limb took out its roof. 163k miles on it which is what I have on my A340E (163,720).
    A340F, 2-4 Conversion, 99 4Runner
  10. Jul 11, 2022 at 12:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    unstpible likes this.
  11. Jul 11, 2022 at 12:45 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    still waiting on my to be delivered, maybe tomorrow if I'm lucky. Looking forward to having the hood support rod out of the way.
  12. Jul 11, 2022 at 2:33 PM
    CS_AR
    That looks like the type of 4Runner where I got my engine. :thumbsup:
    Area51Runner[QUOTED] likes this.
  13. Jul 11, 2022 at 3:02 PM
    Mac.
    Mac. Well-Known Member
    North Bay Area, CA
    2003 prerunner
    Cleaned some stuff up for an upcoming 4x4 swap.
    Lil Puke, unstpible, jubei and 3 others like this.
  14. Jul 11, 2022 at 5:13 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I’ve been running with no cat and the rear O2 sensor plugged in and tucked up above the heat shield for years now. The rear o2 doesn’t need to see any specific range of oxygen, just a steady stream so fresh air works. It’s just there to make sure the cat is cleaning up the constant switching from rich to lean that an efi engine uses to run. I did have to run a ground wire from one of the bolt holes to the chassis, but it works.
  15. Jul 11, 2022 at 6:48 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    We made it :thumbsup:
    Didn't really break anything. Not sure about my rear locker. It stopped engaging halfway through Slick Rock.
    At any rate... we didn't break anything to the point where we couldn't drive home.
    Was an f'n WILD weekend though. Hooked up with the High Sierra Krawlers. For sure, those dudes are legit and cool as hell. We ran Slick Rock Sat, then Deere Valley on Sunday.
    If you want a LONG f'n weekend. Be with a group that helps a 76 Chevy Long bed, through Slick Rock and Deere Valley. No lockers, on 35s, the power steer went out halfway through Slick Rock, and all day through Deere Valley, his fuel lines were overheating and shutting him down.
    10 hours to run Deere Valley.
    But, we made it to Lost Lake last night. Found @Impoy47 and ran Forestdale Divide OHV, and Strawberry Pass OHV today.
    Nice view to wake up to.
  16. Jul 11, 2022 at 6:53 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    Email them direct. Long story, but I was dealing with them on something else and they mentioned it so I ordered it up. I’m shocked it ain’t on the site yet, but 10/10 for customer service from those guys.
  17. Jul 11, 2022 at 8:12 PM
    1997tacomav6
    Denver
    Today was a good day, AC is finally fixed, low 40 degrees blowing now!
    New compressor and dryer.
    Ready for another 100 degree day tomorrow
    Winkle99, Pscdouglas, RayDon and 4 others like this.
  18. Jul 11, 2022 at 8:13 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Man
    I asked for a tree to kill the 99 forever
  19. Jul 11, 2022 at 8:30 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I've heard other good things and love hearing more. It's definitely high on my list of wants. Thanks for the suggestion
  20. Jul 11, 2022 at 10:05 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Reserving judgement... but interesting development
    Apperantly Trail Gear/All Pro is seeing all the drastic leadtimes with Fox, King etc... they are introducing a line of Coilovers and shocks. 1st Gen Tacoma WILL be part of their line up.
