  1. Jul 16, 2022 at 9:12 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    555 come in those orange boxes and colored bags. Here's when I did mine for the Tacoma -
    OEM comes in a clear bag with Toyota part numbers. Here's when I did mine for the 4Runner -
  2. Jul 16, 2022 at 11:01 AM
    FatBilliam
    FatBilliam Well-Known Member
    East TX
    '97 3.4l 5spd Ext. Cab
    That is pretty likely. It did rub some this morning on the passenger side while compressed easing diagonal down a hill on my property, so it needs some clearance work as well. Driving around town I was getting a lot of driver side rubbing on right turns with that 225lb in the driver seat pushing into the direction of the body roll.
    I would really like to do the cam delete kit and get new UCAs to make sure everything is aligned how it's supposed to be in the future.
  3. Jul 16, 2022 at 12:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Goodbye slow truck
  4. Jul 16, 2022 at 2:36 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    What do we think?
    tXisLk4nQxBPLrPgp-srf19iG5VVJuDrBq0EmVqh_52485bef80913f8f24e1a67bad65a892f8cbbe46.jpg
    xuni0qRDaDwULu-n5gOCUOyD58ombv5X8GwgWhzO_ada0aa8be8b109c57269dadff8f4bcd6635cc513.jpg
    Vwn3JPYGzOwiJvDudIsSrepOcDgo3MC2nEVzaYZS_b485a7d0ce5c40e03e0b70dbc6aae9c8fb440749.jpg
    mopar2, BYJOSHCOOK, SwampYota and 4 others like this.
  5. Jul 16, 2022 at 2:42 PM
    Pscdouglas
    Pscdouglas Wish you weren't so awkward Darry.
    Stu
    Glens Falls, NY
    2004 black Tacoma Xtracab 4WD TRD AT, 2020 Black Tacoma ACLB 4WD Sport MT
    That IS the pattern your looking for, right?:burnrubber::fingerscrossed:
    DashMaple[QUOTED] likes this.
  6. Jul 16, 2022 at 2:46 PM
    DashMaple
    Louisiana
    I assume so, but this is my first time doing gears and this was my first attempt so just wanting some more opinions before I throw it in the truck.
  7. Jul 16, 2022 at 3:10 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Anyone know which side is the transmission cooler return line on our radiators? Trying to plumb an external cooler inline with the existing one.
  8. Jul 16, 2022 at 3:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    IIRC, on mine (v6, A340F) the drivers side was the return side.
  9. Jul 16, 2022 at 3:16 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Ah thanks. I wasn't sure if the four cyl differs from the v6.
  10. Jul 16, 2022 at 3:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Like mentioned, the line that comes out the hardline and routes to the driver side of the radiator is the return line.
    Was the same on my 4R as my Tacoma.
  11. Jul 16, 2022 at 3:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Neato, thanks Nelson.
  12. Jul 16, 2022 at 3:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Used Gates transmission line
  13. Jul 16, 2022 at 3:28 PM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Pattern looks good, favors the toe side on the ring gear on the drive side. Which is a better than ideal setup as the gear deflects under load it will be dead center on the tooth. Can tell pinion is good placement as well due to the "comet tail" wide on the beginning of tooth engagement then trails off as it goes through the cycle.
    Pscdouglas and DashMaple[QUOTED] like this.
  14. Jul 16, 2022 at 3:51 PM
    DashMaple
    Louisiana
    Awesome, thanks for the input.
    Getting about 8 in/lbs of preload with a solid spacer. Thoughts on that?
  15. Jul 16, 2022 at 4:51 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    i would like to know more about this
    Speedytech7[QUOTED] likes this.
  16. Jul 16, 2022 at 7:01 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Welded up some tube.
  17. Jul 16, 2022 at 7:16 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I agree. Looks good. Maybe a touch deep but not enough to redo anything.
  18. Jul 16, 2022 at 7:25 PM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    8in lbs is way too low, you want to be in 16-20ish range. Take some shims off in front of the solid spacer.
  19. Jul 16, 2022 at 7:36 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I’ll give you 5 bucks for that!
  20. Jul 16, 2022 at 8:12 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    Started on the valve cover gaskets… realized I totally forgot to order the cam end plugs.. guess I’m waiting a few days to button everything back up lol! Got quite the build up on these bad boys too.
    JoeT4R and SwampYota like this.
