  1. Jul 25, 2022 at 9:55 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I bought some 5/8" plywood, I didn't think it would need to be any thicker than that because the side walls add a lot of strength as well.
    Lil Puke[QUOTED] likes this.
  2. Jul 25, 2022 at 10:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I ran 2.25" backspacing. You generally need to be less than 3" to be totally rub free.
  3. Jul 25, 2022 at 10:59 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    That's kind of what I was thinking. Thanks.
    Fuck, I really don't want to run 2 inch spacers, but it looks like that's what I'm about to do. That would leave me at 2.75 inch backspace overall.
  4. Jul 25, 2022 at 11:02 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    that small capacitor on the OEM tweeter is part of the tweeter crossover, I believe it’s for the high frequencies
  5. Jul 25, 2022 at 11:36 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    You could also just deal with the frame rub. I know folks that do that and just be conscious of your slightly more limited turning.
    I wouldn't wanna go to a 2.75in bs either. That puts you at an absolutely massive scrub radius.
  6. Jul 25, 2022 at 11:42 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I have a total of 3.25" (OEM 4.5" + 1.25" spacers) and I rub the frame but only at full lock. FWIW the rubbing at full lock I have never felt stopped me from being able to attempt any obstacle. I ran 2" for one trip and that same trip the rear wheel bearing went/axle seal started to leak. Not sure if they were shitty spacers or coincidence but it made me feel like it was to much spacer putting the pressure too far outside the axle vs doing it the right way with proper wheel back spacing. I'd give the 3.5" a shot before you slap the 2's on.
  7. Jul 25, 2022 at 11:43 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    I got some track from US Cargo Control. Just the standard L-track. I'm happy with the track and anchors I've used, with a few caveats.
    Their screw countersinking is a different angle than what you'll find at a regular hardware store. I guess the angle they use is common in the airline industry (I don't remember where I read that--somewhere on the internet), but it means you'll want to spring for the pricey hardware. Unfortunately, the pricey hardware comes with generic (non-locking) nuts and small washers. I upgraded to fender washers and nylock nuts from the hardware store for peace of mind.
    I found that their pricing can vary between their website and their Amazon store, and that some of their combo kits are significantly than buying the same parts individually. Shop around. Be careful about mixing brands, though--the track and anchors aren't standardized, so not all brands are compatible. Look for YouTube videos testing different combinations.
  8. Jul 25, 2022 at 11:45 AM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    Most people don't read the thread in its entirety.
    nagorb and Speedytech7 like this.
  9. Jul 25, 2022 at 11:59 AM
    betterbuckleup
    Ian
    Concord, CA
    Def try out the 3 before going to 2, but keep in mind that will also change where you have to cut on your fenders & flares I'd imagine. And possibly affect the shape and size of your tub job.
    I ran into the same thing thing with the L-track I installed in my bed.
    Although I don't think it's the end of the world if the countersink isn't exactly the same and off by just a little bit. As long as it's not taller and sticking up into the track
  10. Jul 25, 2022 at 12:18 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I think, the way I'll approach this is using a wheel/tire off my wife's Silverado. Her tires are just about an inch taller than these, and about an inch wider. Her wheels are 4.5 inch back space and I have a set of 1.5 spacers that I can use for mock up.
    That way I'll be using a bigger tire and more backspace, to figure out what I need to cut. I'll also have the bumpstops all the way removed.
    I think that should give me all the clearance I'd possibly need. Obviously the frame could still present a problem at full lock and stuff, but at this point I'll probably deal with it.
    If it makes crazy noises on the trail, I'll tell the wife it's the truck saying it wants long travel.
  11. Jul 25, 2022 at 1:03 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    This x2.
    I'm running 35x12.50s with 4.0" backspacing.
    Let er rub the frame, you'll be better off in every other way with less backspacing. Plus you don't look stupid with tires sticking way out. #stance :luvya:
  12. Jul 25, 2022 at 2:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This explains why Frank's steering wheel has so little influence on directional control. :)
    Empty_Lord likes this.
  13. Jul 25, 2022 at 2:11 PM
    vtroot
    vtroot Mistakes Were Made
    Eric
    Bay Village, OH
    1995 Toyota Tacoma 4x4 2.7 Manual Standard Cab
    I installed this "Mini Truck" Seat and steering wheel cover to try and mitigate the heat from the sun on the vinyl. It's really not a bad fit. It'll get much better with a steam. The cover doesn't match the bench seat behind the shifter, but that's my only complaint. Maybe the universe is telling me the makeshift cupholder I kept there (which was just a big cup that wedged in pretty well) needed a revamp.
    EDIT: it looks like you can get a cover from this company that'll be correct, I just got item #80003 instead of #80004. Their website is csdashcovers.com, but I couldn't find what I was looking for there or on Amazon.
    Area51Runner and opteron like this.
  14. Jul 25, 2022 at 2:46 PM
    Squeaky Penguin
    Brett
    Speaking of 35s, did some further testing of them, along with the new Northwest Fab ecocrawler this weekend.
    jubei, chrslefty, unstpible and 15 others like this.
  15. Jul 25, 2022 at 2:48 PM
    Phessor
    Phessor Well-Known Member
    I looked at it, does that count?
    Burro, chrslefty, TacomaLad and 8 others like this.
  16. Jul 25, 2022 at 2:52 PM
    Phessor
    I wan to be there...
  17. Jul 25, 2022 at 3:51 PM
    Lil Puke
    Lil Puke Well-Known Member
    Oregon
    ‘99 Taco
    crumbs between seat cushions, junk in glove box, center console mostly full
    Thank you for the detailed reply, I appreciate it. US Cargo was one of the brands I was considering along with MAC. Glad you mentioned the fasteners being a different angle, I’d already decided I’d skip on over to the hardware store for some cheaper stuff—you saved me.
    Have you found one particular style of anchor to be superior or more useful than others? I noticed US Cargo has a lot of flavors when it comes to them.
  18. Jul 25, 2022 at 3:57 PM
    6P4
    Colorado Springs
    I'm only using two styles, for obviously different purposes--the threaded studs and the rings.
    The rings feel a little flimsy, but their advertised load capacity is well beyond anything I'm carrying in this truck so I'll live with it.
    [​IMG][​IMG]
    Lil Puke[QUOTED] and Phessor like this.
  19. Jul 25, 2022 at 3:59 PM
    Phessor
    I am going to be running the same ones on my L track system.
    Lil Puke and 6P4[QUOTED] like this.
  20. Jul 25, 2022 at 4:09 PM
    1997tacomav6
    Denver
    Out with the broken wiper tank and in with the new.
    25 years and the plastic neck is done
    =101.00
    unstpible, 2pei, K-DubTaco and 4 others like this.
