  1. Aug 29, 2022 at 9:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    im mostly just over having to touch up everything all the time. PC avoids that mostly.
    Area51Runner[QUOTED] likes this.
  2. Aug 30, 2022 at 6:18 AM
    acs118
    acs118 Well-Known Member
    Pittsburgh, PA
    2002 4WD V6 TRD Tacoma
    Thanks for the reply. I’m in the same boat… with associated codes. New hangar, multiple gaskets, new tank. Cannot get the dang thing to seal tight.
  3. Aug 30, 2022 at 8:20 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I have not, and will not, powdercoat anything on my truck. Especially something that will take impacts, like bumpers, sliders, skids etc.
    Powdercoat is no where near as durable as people make it out to be. Once you chip, or scratch it, and moisture starts getting under it, it's done. It'll start peeling away.
    https://www.vista-industrial.com/blog/does-powder-coat-chip/
    Powder coat also doesn't actually provide protection from rust.
    For the cost, and hassle of Powder coat. It just isn't worth it, at all, for me.
    Now... If I was build a show truck, like a Silverado with pink axles, 6 shocks at every corner, and a drop bracket lift... you betcha... that thing would be going to the powder coater :thumbsup:
    Deathbysnusnu and Kwikvette like this.
  4. Aug 30, 2022 at 8:25 AM
    Wulf
    rock raisin
    I think my cab interior on the crawler is done up with dupli bed liner, it must be 10 or so years old and is still attached everywhere I can see
  5. Aug 30, 2022 at 8:46 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    @Area51Runner
    Another recommendation for Duplicolor Truck Bed Coating. I used it on my FrankenFab rear bumper and it has held up very well for almost 8 years now. I really like the texture. It's definitely got some, but not too aggressive and is easy to clean.
    Area51Runner likes this.
  6. Aug 30, 2022 at 9:14 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    A lot of it comes down to the powdercoater and their prep before coating and setup.
    I have my bumpers both powdercoated and yea they do chip when you bash it on rocks, but if the shop properly blasted and cleaned the metal before primering it and then doing the final coat, you shouldn't have issues with moisture getting under the coating at all. I never had any issues with that in my years previously working at PC shop.
    I wouldn't say it's a hassle at all, it is pretty nice not to have to worry about touching things up. It cleans up real nice with just a regular car wash. But you can't really touch up those areas that chipped off the same as a spray job obviously.
    That being said, I wouldn't pay what it costs to have it done compared to just doing it yourself with a quality rattlecan. At least for me I wouldn't, since I like to put my armor to the test. I just took advantage since I used to have access to the facility at the time.
    nagorb, drr, opteron and 1 other person like this.
  7. Aug 30, 2022 at 10:02 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The hassle I was referring to was A) finding a powder coater that's worth taking it to. B) Taking it to that shop C) Handing the shop the pile of cash it costs to get it done. D) Taking it back off and taking it back down to the powder coater to have it done all over again when it starts to fail. (because it really can't be touched up)
    All I know is my wife's Grandpa worked as a powder coater for 30 years. Her other Grandpa was a chrome plater for over 20. My wife's dad worked in body shops his entire career ending up as a manger at a dealer, and built hot rods all his life. They all agree, powder coat isn't worth it on a truck that is going to see any type of abuse. My truck sees more than it's fair share of abuse. lol.
  8. Aug 30, 2022 at 10:32 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I think one question that may be lingering over in the corner with the elephant in the room.
    ARB bumpers come with a "durable powder coat" (ARB words, not mine). So if the powder coat is so durable... why are we talking about what paints, linings, or coatings should be applied to the bumper, lol.
  9. Aug 30, 2022 at 11:32 AM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    1 taco got a new tailgate, super shiny. The other got new tires
    Anyone want a crushed, burned tailgate? :rofl:
    469C43B9-8A4E-4E60-B3CF-1C8F15DC2F37.jpg B3862826-3E87-45C6-8EFC-83E29CF6EC7F.jpg 4EDCCEF6-E70A-4DC5-B77E-20AFB4D7BD2D.jpg
  10. Aug 30, 2022 at 12:35 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    So just to shed some background, this ARB bumper saw plenty of action on @2BeersPlease rig before it found a new home with me a few years ago. He definitely took it to hell and back and had the occasional stump jump out at him (3:54) on the trail. Needless to say, it was showing its scratches.
  11. Aug 30, 2022 at 1:05 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    LOL... I was just posing a hypothetical, semi comical, question.
    I know Jason probably ran that thing hard.
    But, at the end of the day (take it for what it is) I would highly ,not, suggest shelling out the money to powder coat anything on a truck that is going to be put through paces. It's just not worth it.
    Unless, like @betterbuckleup, you have an in where you can get it done for less than the full price it costs. Even then, I personally wouldn't have anything powder coated. It's completely, and totally, overrated for our applications. Hell, I think it's totally over rated for any application, personally.
  12. Aug 30, 2022 at 1:08 PM
    Area51Runner
    Why I skipped on taking my wheels in to be powder coated. Duplicolor worked just fine for my needs.
  13. Aug 30, 2022 at 1:15 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    100% the right way to go man. When you start hammering your truck (which you will when you get the 4wd, trust me) you'll start hammering your wheels for sure. Powder coat would have been a total waste of money.
    turbodb and Area51Runner[QUOTED] like this.
  14. Aug 30, 2022 at 1:24 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Link to 2 part Raptor Liner? Search isn't my friend.... today...:anonymous:
  15. Aug 30, 2022 at 1:31 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  16. Aug 30, 2022 at 2:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You just reminded me of those wheel covers that I still have brand new that never fit :bananadead:
  17. Aug 30, 2022 at 2:09 PM
    Area51Runner
    Have no idea what happened with yours .. no issues here. Fits perfectly. :notsure:
  18. Aug 30, 2022 at 2:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Been a year or two now, don't expect you to remember :rofl:
    They never "clipped in" or whatever.
    Even pulled the tabs or tried to see about making sure they were the same as my factory set.
  19. Aug 30, 2022 at 2:14 PM
    Area51Runner
    No I remember, just don't understand why yours didn't fit. Maybe a variation in the cheap knockoff copies being sold on eBay. Oh well.
    Kwikvette[QUOTED] likes this.
  20. Aug 30, 2022 at 2:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Maybe I'll just give you my set if you ever come hang out with us; I have no need for them.
