  1. Nov 20, 2022 at 7:15 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    hauled the boat up one last time for the winter
    T.Barn, SwampYota, Rhodes and 5 others like this.
  2. Nov 20, 2022 at 7:48 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    When did you cut the vent in the hood? Turbo getting too hot?
  3. Nov 20, 2022 at 10:40 AM
    devinzz1
    devin
    2023 aclb trd or mt
    few months ago. did it out of boredom. but it does make an insane difference to underhood temps. when fan kicks in its crazy how much restriction it is to push that air out from the engine bay
  4. Nov 20, 2022 at 11:29 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ha nice. Yeah I'd though if doing louvers or a scoop at some point.
  5. Nov 20, 2022 at 1:14 PM
    vtroot
    vtroot Mistakes Were Made
    Eric
    Bay Village, OH
    1995 Toyota Tacoma 4x4 2.7 Manual Standard Cab
    When I did mine, I packed that whole area with grease, not just the pump. I don't know if it was necessary, but it did work seamlessly. My thought process was that air is compressible, so the fewer air pockets there are, the better.:notsure:
  6. Nov 20, 2022 at 1:38 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    She’s running! Gotta adjust my belts a bit I think they’re too tight otherwise everything seems good. Still gotta fix the oil filter housing leak but that’s a thanksgiving adventure.
    I noticed on my initial test drive that when at a stop in drive it would idle low in the 600s. Previously it’s always been in 700-750 range. Is this expected as I had the battery disconnected for a week and the ECU is learning after a few cycles?
    Area51Runner and vtroot like this.
  7. Nov 20, 2022 at 1:51 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I think so. Mine is around there too when I’m in drive. In park is usually around 700-850 I believe.
  8. Nov 20, 2022 at 4:16 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Final swap update -
    Was able to confirm the odd noise I was hearing was the carrier bearing on this aftermarket DS and not the torque converter. I was going to swap in a Spicer CB but the stake nut on this one is not the same size as OEM. Instead of messing with it my plan for tomorrow is to drop off my PreRunner DS and have it shortened and rebuilt/balanced. Should've listened to TW and did this in the first place. Live and learn I guess.
    Transmission is shifting fine and temp doesn't want to climb higher than 170. Of course it's 63 degrees outside and the Hayden cooler (installed w/the swap) is doing its job. Happy so far with this 1999 T4R transmission.
    My speedo cut out today, re-seated the connector on the tcase and its working so maybe just a loose connection, will monitor. Transfer case seems to be fine after a complete rebuild except chain. Might have to go back in since I removed the synchronizer ring but its working - just have a slight intermittent grind when going from 4L to N and into 4H. Again, will monitor.
    During the 4WD swap, I had pulled the ARB bumper to 'refurb' it. Lots of scratches and wanted to refresh its look. Went the bedliner spray in a rattlecan route and after a couple of re-dos, I was satisfied. After Krylon and Rustoleum both failed, Duplicolor TR-250 worked out great (thx @Speedytech7 for the tip). Also put in new LBJs, UBJs, and stabilizer bushings w/new end links. Front driveshaft received new U-Joints.
    A lot of work, wrenching and learning but I'm glad to be done - for now.
    Sliders/winch & replace the 881s will come in January.
    Alignment is on Tuesday.
    A huge thanks to all who helped out along the way with answering numerous questions, adding suggestions and sharing their own experiences. Cheers!
  9. Nov 20, 2022 at 4:44 PM
    Mac.
    Mac. Well-Known Member
    North Bay Area, CA
    2003 prerunner
    Looks so good. Great work man, I know you put a lot of effort into this one. Looks like it paid off!
    Area51Runner[QUOTED] likes this.
  10. Nov 20, 2022 at 5:03 PM
    Area51Runner
    Thanks, appreciate the collaboration during both swaps. As soon as you resolve your CAT, let me know. Need to get that front bumper up to you.
    Mac.[QUOTED] likes this.
  11. Nov 20, 2022 at 5:31 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Nice work man!
    There is definitely a level of comfort in knowing all the ends and outs of the mechanicals while you are on the trail. No better way to get that knowledge than to do what you just did.
    Welcome to the 4wd swap club brotha! :thumbsup:
  12. Nov 20, 2022 at 5:57 PM
    Area51Runner
    Thanks Matt. The work you did with your swap thread helped quite a bit. Looking forward to reading about your newest project.
  13. Nov 20, 2022 at 6:31 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Have you purchased 882s yet? Cause mine are just sitting waiting for me to list them for sale
  14. Nov 20, 2022 at 7:19 PM
    Area51Runner
    I have not.
    I'm actually still torn between 882s and 883s. Was reading a couple of threads last night which made me start thinking about 883s all over again. Doublecab 6cyl with the ARB + adding a winch, sliders and partial or full skids have no idea if that's going to push it into 883 country. Going to call ARB support and see what they recommend.
    Thx for the heads-up, if I go that route will let you know.
  15. Nov 20, 2022 at 7:20 PM
    DashMaple
    Louisiana
    Yeah just let me know if you go with 882s and we'll work somethin out. Mine have some miles on them but they're still in good shape...definitely not sagging any lol
  16. Nov 20, 2022 at 7:23 PM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    A95B688E-ED72-4741-B169-D1542A95D6F4.jpg Not mine, but my youngest son’s 02. He wanted to add TRD style stripes on it, so we spent yesterday doing it. He had to order more white to do behind the rear doors.
  17. Nov 20, 2022 at 8:38 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I drove my truck for the first time in 10 months today.
    IMG_6806
    by Cory Bechtold, on Flickr
    More photos in my build thread
    jubei, T.Barn, 03_taco_IN and 11 others like this.
  18. Nov 20, 2022 at 8:58 PM
    Area51Runner
    Love this shot! Just the right amount of background blur and I swear it looks like one of those mini rc/models.
    cbechtold[QUOTED] likes this.
  19. Nov 20, 2022 at 9:23 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Prob drives like one too
  20. Nov 20, 2022 at 9:25 PM
    cbechtold
    Cory
    Pleasanton, CA
    Thanks man! I can definitely see the RC car resemblance.
    We're going to find out in February once she's a little more dialed and broken in.
