  1. Dec 7, 2022 at 9:10 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Thank you sir :hattip:
    I'm not sure, but I think if I'm going to upgrade to the 14WA 4 Runner brakes in front and 4 Runner disc brakes in back, I may need more volume from the MC. But... I've also heard more volume isn't always a good thing because it decreases pressure. I'll contact them and maybe they can help.
  2. Dec 7, 2022 at 9:23 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The 14wa have a notorious issue with soft pedals on the stock tundra setup. Don’t know anyone running that setup with 4 wheel disc. I’d imagine you’d end up with a slightly softer pedal running a sequoia master with the 4runner front brakes and a disc conversion. But not certain. I avoided that whole mess in my tundra with a TRD BBK. Almost wish I could find another for my tacoma lol
  3. Dec 7, 2022 at 9:24 AM
    Empty_Lord
    Dan
    In other news… my new frame for the 1998 is here… start assembly tonight maybe[​IMG]
    SwampYota, erice, det107 and 5 others like this.
  4. Dec 7, 2022 at 10:05 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Running:
    13WL (Tundra) Front calipers
    05+ 4runner rear calipers
    Factory 13/16 MC
    ABS module delete (The Factory Module has internal Brake Bias set)
    Rear Proportioning valve delete
    New brake lines
    Wilwood full system Proportioning Valve (Front & Rear)
    With this setup brakes are powerful enough to stop Auto + crawlbox
    det107 likes this.
  5. Dec 7, 2022 at 10:24 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Right on. I already don't have ABS (thankfully). Was already, definitely, planning on deleting the load sensing proportioning valve and probably going with the Wilwood. Maybe I'll try that out before worrying about the MC.
  6. Dec 8, 2022 at 8:35 AM
    erice
    erice Well-Known Member
    Eric
    San Diego
    Ugh... from one issue to the next.
    Saw a small puddle under the truck. Slow drip I think.
    Looks like fresh trans fluid. Is It possible to install the rear main seal incorrectly? I can't imagine any other issues after changing the clutch. Drip on front cross member and bottom of the bell housing.
    I really don't want to have to pull that damn thing again. Total pita to get back in but if it saves me the labor costs then so be it.
    Beuller?!
    @Speedytech7
  7. Dec 8, 2022 at 8:36 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What color is the fluid, it's possible to put in the rear main a bit off and have it leak but if it is ATF then the trans has a leak.
    erice[QUOTED] likes this.
  8. Dec 8, 2022 at 8:37 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    The rear main seals engine oil, so if you're seeing trans fluid, then that's something else...
  9. Dec 8, 2022 at 8:42 AM
    erice
    Eric
    San Diego
    Trans was freshly rebuilt.
    Fluid is reddish and super fresh. Slight oily tinge. Doesn't smell like gear oil so I could be wrong. Could that be coolant instead?
    Ok that's what I thought. Still learning. Yeah it's fresh something.
  10. Dec 8, 2022 at 8:45 AM
    Speedytech7
    This is gonna sound nasty, but you can tell if it is the toyota red coolant easily. Dab a finger in it and touch it to your tongue, it has a disgusting bitterant in it (to stop animals and people from eating it) and you'll immediately know if it is a hard taste to shake that it is coolant.
    vtroot and erice[QUOTED] like this.
  11. Dec 8, 2022 at 8:48 AM
    erice
    Eric
    San Diego
    Lmfao ok. I'll, get my taste on when I can get to the truck. Would it leave an oily residue vs red crusty? Or is that baked vs fresh?
    :rofl:
  12. Dec 8, 2022 at 8:49 AM
    Speedytech7
    That's just fresh vs evaporated haha. But ATF should be more slick and dark overall. Toyota red coolant is pretty slippery though
  13. Dec 8, 2022 at 8:52 AM
    erice
    Eric
    San Diego
    Haha ok good to know
    It's the r150f so it would be the gl5 redline
  14. Dec 8, 2022 at 8:53 AM
    Speedytech7
    oh, I guess that's pinkish, but not really red. also smells, might be easier to determine what it is
  15. Dec 8, 2022 at 8:59 AM
    erice
    Eric
    San Diego
    Oh christ! Its got to be coolant. That's bitter af. Oh jeez. Make it stop!!
    How tf did coolant get all the way back there?
  16. Dec 8, 2022 at 9:04 AM
    Speedytech7
    Heater valve dripping on the bell housing would be my first guess, second guess is the coolant bypass pipe leaking (you don't want that)
  17. Dec 8, 2022 at 9:12 AM
    erice
    Eric
    San Diego
    Lovely. I mean any leak is no bueno.
    Not finding much write up on the bypass pipe but it looks like that might be the cause of the resi being super low.
    Easy job for the bypass?
  18. Dec 8, 2022 at 9:13 AM
    Speedytech7
    No, the bypass pipe sucks to reseal, have to take the entire intake manifold and lower intake off to service it, I'd try to get visual farther up on the leak before tearing into anything
  19. Dec 8, 2022 at 9:17 AM
    eon_blue
    Azusa, CA
    I had coolant leaking into the similar area that turned out to be a freeze plug that had started leaking.
  20. Dec 8, 2022 at 9:22 AM
    erice
    Eric
    San Diego
    Oh fun.. those likely have not been removed or touched for 360k
    Will do a deep dive on lunch I suppose.
    I will check that out also.
    Oh hell, those look like they were easily accessible when I had my trans out. Go figure
    I'll report my findings in a bit.
    Well... not easy to get photos. Found some evaporated crust on something. Couldn't get a shot of the driver side plug. One behind the starter looks fine.
    Found the seal between the tcase and trans is seeping something. Isn't this supposed to not have any fluid in here? :rofl:
