  1. Dec 26, 2022 at 6:48 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    More pics of the crossover
  2. Dec 26, 2022 at 8:46 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Immortalized her on canvas. Ok, so I didn’t do it, it was a Christmas present from my SIL. I hung the picture in the breakfast nook over my wife’s objections.
  3. Dec 26, 2022 at 8:56 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    OK, I submit to the TW braintrust:
    Which Gear oil weight for Rear Diff/Front Diff/T-Case?
    I can't remember they require different weights...
    I have 3 different weights:
    75w-140 (this is Schaeffer's Synth)
    75w-90 (these were purchased at Autozone in Moab, UT as a backup)
    80w-90 (this is Mag1 and nothing states if Dyno or Synth)
  4. Dec 26, 2022 at 10:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I run 75w140 in the rear diff and 75w90 in the t-case and front diff.
  5. Dec 27, 2022 at 6:08 AM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    I keep a spreadsheet in my build thread based on the owners manual in my truck. It shows weights, quantity and torque specs for performing the fluid changes, hope this helps:
    https://www.tacomaworld.com/threads/swampyotas-2003-tacoma-build.646862/#post-22444011
  6. Dec 27, 2022 at 7:30 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I run Lucas 75-90 in front and rear diffs, and t-case. MT-90 in the transmission.
    The Lucas was at the recommendation of Just Differentials (in Cashmere) when they put in the 4.88s, and the MT-90 was at Mike's @Digiratus recommendation as I recall.
  7. Dec 27, 2022 at 7:51 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Ditto.
    Well, MT90 soon to be in the transmission ;)
  8. Dec 27, 2022 at 12:14 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Ok... so, I just got off the phone with Fox tech support.
    Again... the reason I'm proud to run Fox Shocks. I have always gotten great service and helpful information from them.
    He spent at least 45 minutes with me going through every aspect of my LT build and my issues. (And of course none of the issues are Fox's fault, but he ran down every avenue with me anyway)
    These coilovers WILL work for my application. Yes, they are not what I would want if I am trying to get every inch of travel out of them that I can, but with 35s going to 37s shorter body shocks would have to be bumped where I am bumped anyway. Even tubbed the way I am, if I have any more up travel I will rub at full stuff and lock... with 35s... I'll have to tub further right now if I want to go up to 37s. (Essentially Solo's kit running a short shock body can fit 35, is recommended for 33, and will only work for 37s if you hack the shit out of everything)
    Also, at the shock body length I am at right now, I hit my bump just at 1 inch from contacting the frame above the LCA bushings, so the body could only theoretically be 1 inch shorter anyway.
    Now, how to make the coil perches work. He gave me the two part numbers for the 2 piece spring retainer that raises the bottom of the coil up 1.5 inch so I will not have an issue contacting the CV. He gave my info to a rep they deal with direct, for me to order.
    This is making the best out of a bad situation that started by me letting a vendor talk me in to saving money by going with Performance Series shocks instead of Factory Race... which I am not really saving much money because I've had to spend $100 on resi elbows, and now I'm going to have to spend $140 on spring retainers.
  9. Dec 27, 2022 at 12:20 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    So you're running too long of shocks and spaced your bumps down? What are you cycling?
    Going LT and gonna have less travel than stock width. :rofl:
  10. Dec 27, 2022 at 12:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    For some reason I thought you were running 140w in the rear diff. When I had the rear diff rebuilt last year, 75w140 is what was recommended.
  11. Dec 27, 2022 at 12:24 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    But the gram won't even know
  12. Dec 27, 2022 at 12:24 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I didn't space my bumps down. My bumps are an inch higher than they were on stock travel. If I spaced the bumps up much more the actual LCA arm would hit the frame (where the stock bumps hit).
  13. Dec 27, 2022 at 12:28 PM
    Squeaky Penguin
    Brett
    Looks like you have a ways to go before you're into the frame based on your previous pics.
    So you haven't measured what it cycles with the shock and a CV in there?
  14. Dec 27, 2022 at 12:33 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I haven't set droop yet, because of the issues I am having with the spring perch. I'm about 7/8s of an inch from contacting the frame on the front LCA arm.
    The fact that I'm close to rubbing the fender now, as opposed to being 2 inches away from the fender with stock travel with the same size tire tells me I have about 2 inches more up travel. I don't know about the droop travel yet because it's not set.
  15. Dec 27, 2022 at 2:44 PM
    bradkaren
    bradkaren coffee lover
    Pacific Wonderland
    2001 Silver Tacoma SR5 4WD V6 AT
    Added a bluetooth receiver to my OEM radio today. Haven't tried the phone calling aspect to it yet, but playing music from my phone through the vehicle's speakers is great! Installation was a 3/10 - especially since this wasn't the first time I've had the center console apart. I'd post a picture but it's well, bluetooth wireless...
  16. Dec 27, 2022 at 4:15 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I‘ve always run synthetic 75w-90 in both diffs and the transfer case, I know ECGS and others recommend dino oil up to 140 weight but I don’t think that accounts for ambient temperature range. In below freezing temps, a 75 weight oil is much preferable and my truck rarely sees temps hot enough to reach the upper limit of 90 weight.
    Digiratus[QUOTED] likes this.
  17. Dec 27, 2022 at 4:24 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    So... I just talked to Bobby at Solo. (I've been having a bit of trouble getting ahold of him, turns out the phone lines to his industrial park have been down since last week).
    Anyway... He says they install off the self Kings that are 16 compressed, 24 extended.
    My Fox are
    16.44 compressed
    24.45 extended
    He said what I have are pretty much the exact Fox version of the Kings they use.
    Glad to get that outof the way... was starting to remind of of the time I relocated my rear shocks and the peanut gallery all wanted to say the shocks were wrong, too long, and I would have no up travel.
    LMFAO... :rofl:
  18. Dec 27, 2022 at 5:29 PM
    andywear
    andywear Active Member
    Tulsa, OK
    '99 TRD manual
    working on building my own bed rack, I want it nice and tight don't want to spend $1k on scrap metal and 12 small welds.
    trying to decide 1-1/2 or 2" square tube
    or
    1-1/2" pipe, about 2" OD and have it bent to fit the contour.
    Ill draw a few and go out for bids.
    Yetimetchkangmi likes this.
  19. Dec 27, 2022 at 5:50 PM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Finally pulled the trigger on a swingout rear bumper! 55E83BA1-FEF7-4335-ADCF-133502B8657F.jpg
    TRD_IV, Jiveydude, BYJOSHCOOK and 4 others like this.
  20. Dec 27, 2022 at 6:19 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Square is easier to work with, especially if you're doing it yourself.
    I did 2x3 main legs with thinner wall
    The main (side to side) crossbars are 2x2
    The mains front to back are 1x3
    The crossbars for the RTT are 1x2
    I went with those outer sizes so I could keep it mostly 16 guage wall. The main legs are 14 guage. Also the sizes of the pieces also had to do with what lights I'm running (sizes, locations) and how I wanted to run the wires inside them.
    andywear[QUOTED] and Kwikvette like this.
