  1. Dec 28, 2022 at 1:53 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Manual trans rad shroud is different from the auto trans shroud which is also different from the 5 lug auto shroud if I’m not mistaken. No clue about a 5 lug manual truck.
    Like you said above whatever size rad you have stick with it or you’re buying a new shroud.
    Area51Runner likes this.
  2. Dec 28, 2022 at 1:54 PM
    04Pre_Runner
    Andrew
    He’s manual swapped. Seems it is out of stock everywhere now. Not sure about OEM suppliers in Japan or the Middle East.
    nagorb and Digiratus[QUOTED] like this.
  3. Dec 28, 2022 at 2:09 PM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    Changing the oil and getting caught up on some maintenance
  4. Dec 28, 2022 at 6:15 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    That would be helpful info.
    Manual trans.
  5. Dec 28, 2022 at 6:19 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I'd imagine those would be expensive.
    Too bad I didn't save my auto one, I'm sure I could adapt one, but don't want to waste the money.
    Edit: I might just buy a cheap auto mount from rock Auto and see if there's something that can be done. It would help others in the same boat if there's an easy solution.
    Or just go with a cheap RA manual mount, they're easy enough to swap out.
  6. Dec 28, 2022 at 6:40 PM
    Jchase73
    Jchase73 Member
    2002 tacoma4x4
    3in lift goodwrench allterrain
  7. Dec 28, 2022 at 6:42 PM
    andywear
    andywear Active Member
    Tulsa, OK
    '99 TRD manual
    ehiii, it was your build thread that got me on this "build myself" route. :bowdown:
    from the fist page of your thread:
    <Exterior
    - Custom Roof Top tent rack and awning mounts>
    very nice, Ill keep that saved. :thumbsup:
    I Believe you misunderstood my post. the pre-built, welded and painted and sold are all pushing $800, I agree with you, I hope to do it cheaper and matching my truck specific needs, my example of cost* - https://rcimetalworks.com/product/12-sport-bed-rack/
    freaking sweet! :bananadance:
  8. Dec 28, 2022 at 6:55 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    LOL... Awesome!
    I've actually built the rack twice. The first time was a little over built, and heavy. I also reconfigured to work better with ideas I had over the course of running version 1 for a couple years.
    If you have any questions PM me or you can always hit me up in the build thread.
    Glad it inspired, that's what it's there for. :thumbsup:
  9. Dec 29, 2022 at 9:37 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Replaced shifter bushings, installed LED headlights and fabricated a mounting bracket for an oil catch can.
  10. Dec 29, 2022 at 10:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gotcha.
    A lot of that you see there is angle and c channel.
    The hard part is not having a cnc plasma/laser/water or mill to do those nice slots, but if you drill your own holes for mounting stuff you want, you can definitely get it done for cheap.
    C channel will cost you less than square tube, and angle will cost you less than c channel; it's all about the weight you buy.
    andywear[QUOTED] likes this.
  11. Dec 29, 2022 at 12:16 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    my buddy just posted a pic of him doing a frame swap. He said easy peasy! Good to know I have that option! He has a lift too :D
  12. Dec 29, 2022 at 4:16 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How do the old ones compare?
  13. Dec 29, 2022 at 4:22 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Exact same. I think I just got it. It fits flush now but there is some pressure on that corner. Bending the tip of it downward a tad.
  14. Dec 29, 2022 at 5:03 PM
    Overland_Architect
    Overland_Architect Well-Known Member
    Phoenix
    2002 Tacoma PreRunner Ext Cab Black
    Old Man Emu Suspension Dakar Leaf Springs Icon Delta UCA’s Relentless Fabrication Summit Bumper 4xInnovations Rear Bumper Tire Swing out 05 OEM Bed Rails
    it smells like oil and di-electric grease. Assuming this is the leaky valve cover gasket how long do I have before I need to get in there and replace these before it makes a mess of my cylinder 3 plug again? Is this an emergency repair or something to keep an eye on for a few months?
  15. Dec 29, 2022 at 6:33 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    You can keep an eye on it. It usually isnt a massive leak
  16. Dec 30, 2022 at 2:18 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Fixed the AC for the second time this week.
  17. Dec 30, 2022 at 11:53 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Turned it into a 5 lug to make changing the valve cover gaskets easier on myself.
  18. Dec 30, 2022 at 3:40 PM
    Sebz13
    Shane
    Maui Hawaii
    To the SAS guys, I need some help. I’m just not happy with my steering, on a stop or Moans and groans but driving it’s fine at speeds above 15, think turning in a parking lot it groans or turning from a start. Checked fluid last night and it wasn’t cooked and was at fill (hot). It sounds like it’s coming from the steering box but it doesn’t seem to be leaking.
  19. Dec 30, 2022 at 3:47 PM
    eon_blue
    Azusa, CA
    Probably have better luck in the general SAS thread
    https://www.tacomaworld.com/threads/solid-axle-swap-bs-thread.205596/
  20. Dec 30, 2022 at 3:54 PM
    Sebz13
    Shane
    Maui Hawaii
    Forgot about that, will post there
    eon_blue likes this.
