  1. Jan 4, 2023 at 4:53 AM
    Yota03Taco
    Yota03Taco Member
    Brandon
    Chattanooga
    2003 Tacoma DCSB Pre-Runner
    To be fair I just like the soft topper look, you can do it in a contrasting color where as a hardshell looks "cheap" in anything but body color. Functionality wise I don't know that I will ge much use out of the removability of it since I will be putting a bed rack around it.
    Empty_Lord[QUOTED] likes this.
  2. Jan 4, 2023 at 6:47 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Glad you found the plug and got that fixed, but I am willing to bet that everything @ToyRyd04 said is potentially correct. The head gasket sealer stuff may have gunked up your coolant system.
  3. Jan 4, 2023 at 7:16 AM
    NehemiahJantomaso
    NehemiahJantomaso Active Member
    Nehemiah
    1999 Tacoma SR5
    2.5' lift on 265's
  4. Jan 4, 2023 at 10:56 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I don’t have the time to rip all that apart again. What’s the consensus on coolant system cleaner? Or can that clog up just like HG sealer? I feel like it wouldn’t, then again I’ve been wrong before.
  5. Jan 4, 2023 at 10:59 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Back flush the heater core to start, then flush the radiator (garden hose) the. Use distilled water and proper cooling system cleaner and run a few cycles of that’s tuff through. Bout as good as it’ll get
    Logans2001[QUOTED] likes this.
  6. Jan 4, 2023 at 11:01 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Gonna try to burp and drive down the street a few more times. If no luck I’ll be doing this. Thank you.
  7. Jan 4, 2023 at 12:14 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    how did you fill the coolant?
    I always start with the engine and fill it using the top radiator hose first to get the block as full as possible. Then attache the hose to the rad and fill it.
    Also, if you bought a radiator burping funnel it'd make this task much faster and easier and cleaner. https://www.napaonline.com/en/p/SER...6S8uO89OOIvwiQSTOoaAmOcEALw_wcB&gclsrc=aw.ds&
    It's worth picking up.
    https://www.youtube.com/watch?time_continue=52&v=odDJ8idW9QE&feature=emb_title
    SpokeWench likes this.
  8. Jan 4, 2023 at 12:25 PM
    EndangeredSpecies
    EndangeredSpecies Well-Known Member
    Tom
    '98 delux std 5-lug 5-spd
    None
  9. Jan 4, 2023 at 1:13 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    I’m using a wide funnel that does essentially the same thing. Just pouring it all through the radiator cap opening.
    Could this be a clogged coolant temp sensor?
    Or could part of my ecu just gotten damaged from the water it had in it.
  10. Jan 4, 2023 at 2:44 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    How bad is this intake?
    Took it off to do the fuel filter relocation and remove the injectors to have them refurbished. Gonna get this cleaned up and replace the gaskets while it’s out.
    6AC9AC93-BED9-49BF-9941-0B46370E25C7.jpg F3EE45E2-E328-4AB4-8C9E-79156942495F.jpg
  11. Jan 4, 2023 at 3:20 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    looks pretty gunked up. Not the worst I've seen but A catch can would help a bit with that once you clean it.
    first time the intake's been removed?
  12. Jan 4, 2023 at 4:00 PM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    Yes first time and I actually have a catch can ready to install too. It’s the one from timmahs video
  13. Jan 4, 2023 at 6:47 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Anyone know of any deals for an OEM steering pump
  14. Jan 4, 2023 at 6:59 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Think I got mine from McGeorge for just under $300. The remans I tried all sucked/leaked so just said screw it and bought an OEM.
  15. Jan 4, 2023 at 7:26 PM
    Sebz13
    Shane
    Maui Hawaii
    Yup, I’m In that boat, just gotta contend with shipping it here
    04Pre_Runner[QUOTED] likes this.
  16. Jan 4, 2023 at 7:45 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not awful, pretty common for a lot of miles. You don't have to clean it but I don't blame you for wanting to. Depending on how much effort you want to put into it, xylene makes that stuff just come off.... but it is nasty shit to have around.
  17. Jan 4, 2023 at 7:50 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Pulled my starter. I was planning to rebuild it, but it looks like a generic reman, so now I'm wondering if I should spend a bit extra and get a Denso reman.
    Looks like $160-ish for the Denso vs maybe $60 or $75 for OE brushes, plunger, and contacts. Generic parts would obviously be cheaper, but I don't know how the quality compares in this case.
    Anybody have any strong arguments one way or the other?
    Wulf likes this.
  18. Jan 4, 2023 at 7:51 PM
    Speedytech7
    If you're gonna spend the money on a replacement one, spend it on the cold weather package one.
    Wulf and Kwikvette like this.
  19. Jan 4, 2023 at 7:52 PM
    6P4
    Colorado Springs
    Yep, that was the plan. The one on there appears to be 2.0kw already--17669 is a 2.0kw part number on RockAuto. If it was a 1.4kw I'd definitely be replacing it.
  20. Jan 4, 2023 at 8:10 PM
    6P4
    Colorado Springs
    On second thought... will OE-spec replacement parts reliably fit a remanufactured starter? Is there a risk that my reman has different internals from the OE starter?
