  1. Jan 4, 2023 at 8:52 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Good. Considering it's only never been taken off that one time, not too bad for that many miles
  2. Jan 4, 2023 at 10:04 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Holy smokes. What did you break/need to replace that cost so much? Or is that just the going price for four shocks? (which makes me feel a little less bad about buying my spring compressor, hahaha)
    Digiratus likes this.
  3. Jan 4, 2023 at 10:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    $1100 does seem like quite a bit unless shafts, internals and such which would never be part of a normal, timely rebuild, also had to be replaced.
    If you don't mind sharing, about how much was it for all the shock parts you had to buy to rebuild your 4 shocks last year?
    Then there is $700 for a spring compressor, $400 for a nitro recharge kit, labor $0 :) =$1100. Of course, these are one-time costs essentially.
    turbodb[QUOTED] likes this.
  4. Jan 4, 2023 at 10:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Damn, I bought a whole new rebuild kit for half that (or slightly less).
  5. Jan 4, 2023 at 10:38 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    My rebuild for all four shocks was:
    • oil (1 gallon covered 4, 2.5" shocks w/resis): $65
    • seals (4 kits): $100
    • spherical bearings (8 of FKSSX10T-F1): $160
    So, for the rebuild, $325
    Then, tools, as you mentioned:
    • spring compressor: $700
    • nitro kit: $400 (or free, I suppose ;), thank YOU)
    • misc bits like the spanner wrench, threaded rod: added up to $61
    • consulting fee to @TMFF which was the best $100 I ever spent
    so one-time cost of $1261 (or $861 for me)
    Still, pays for itself after one more rebuild if that runs me $325 as well.
    TMFF and Digiratus[QUOTED] like this.
  6. Jan 5, 2023 at 12:13 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    (Googles xylene)
  7. Jan 5, 2023 at 5:53 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Do you still have the link or part number to what you used?
  8. Jan 5, 2023 at 7:11 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Safe enough to use on the upper and lower plenums? I want to deep clean mine while they are off.
  9. Jan 5, 2023 at 7:13 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, safe on metals. Not great for plastics
    cynicalrider[QUOTED] likes this.
  10. Jan 5, 2023 at 7:30 AM
    Speedytech7
  11. Jan 5, 2023 at 7:56 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  12. Jan 5, 2023 at 8:07 AM
    Speedytech7
    I don't think you want it in the engine, but on the 3RZ both halfs of the manifold come off the engine just like the 5VZ, I wouldn't clean it on the engine, you'll end up with sludge sitting on top of the valves (you could clean in that chamber super carefully if you make sure the valves are close and then vacuum after the solvent has flashed off.
  13. Jan 5, 2023 at 8:35 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Lil headlight upgrade. TYCs. Going back to amber corner light soon to bring back some color to it.
  14. Jan 5, 2023 at 10:26 AM
    betterbuckleup
    Ian
    Concord, CA
    Speedytech7 likes this.
  15. Jan 5, 2023 at 12:01 PM
    Noakea_Bean
    Noakea_Bean Well-Known Member
    Noakea
    2001 Toyota Tacoma SR5 4X4 2.7L
    42" Light Bar
    What app is this?????
  16. Jan 5, 2023 at 1:23 PM
    ELjefeX
    ELjefeX Member
    Black 99’ Tacoma Trd
    Leveling kit w/oredy suspension and spacer’s running 32s on 14s
    What do you guys think? Waiting to sell these so I can purchase some better tires for the new 97’ T-100 wheels.
    Thunderer 32/11.5/15 with 1.5” spacers
    For these
  17. Jan 5, 2023 at 1:32 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Finally gave up on this overheating issue. Gave it to the shop to pressure flush since that worked last time and give it a once over.
    Just got off the phone with them….
    Said they did everything they could. Only other thing it could be is improper installation of the HG itself. I felt pretty certain I had placed them correctly, but at this point I’ve done everything else. To say I’m bummed is an understatement.
    And I know the owner personally and grew up with his kids so he’s not bullshitting me.
    Taking a shot in the dark here.. is there anyway to confirm the HG is indeed upside down before I rip it all apart? Again.
    ztwatson likes this.
  18. Jan 5, 2023 at 1:36 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    And if/once I do take heads back off, would you get new head bolts again? God they’re brand fucking new but I know they're suppose to stretch. TTY.
  19. Jan 5, 2023 at 2:01 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Too bad you didn't take a picture at that point in the process. Sorry man, been a long battle for you.
  20. Jan 5, 2023 at 2:03 PM
    Speedytech7
    I don't think they can be installed upside down
