  1. Jan 9, 2023 at 2:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Only if you want to blind oncoming drivers.
  2. Jan 9, 2023 at 3:12 PM
    Noakea_Bean
    Noakea_Bean Well-Known Member
    Noakea
    2001 Toyota Tacoma SR5 4X4 2.7L
    42" Light Bar
    Why?
  3. Jan 9, 2023 at 3:12 PM
    Noakea_Bean
    Noakea
    42" Light Bar
    But would they work?
  4. Jan 9, 2023 at 3:16 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Not well
  5. Jan 9, 2023 at 3:16 PM
    Noakea_Bean
    Noakea
    42" Light Bar
    Why do you say that?
  6. Jan 9, 2023 at 3:18 PM
    JKO1998
    Utah
    Cause they aren't meant to
  7. Jan 9, 2023 at 3:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you DAF about other drivers. Yeah, it can be done.
    The basic problem is the reflector in the headlight housing. It is designed specifically for an omnidirectional halogen bulb filament which is located in a very exact location within the housing. when you put an LED bulb in there, the emitter is not in the correct position and will cause light scatter. This is what is blinding to other drivers.
  8. Jan 9, 2023 at 3:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    crashnburn80 likes this.
  9. Jan 9, 2023 at 3:29 PM
    Digiratus
    Roaming the PNW
    The RedHead
  10. Jan 9, 2023 at 3:45 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    @crashnburn80 has covered this extensively in the threads that @Digiratus posted. LED's just aren't made for this application and your usable light down the road will be WORSE than stock (along with blinding other drivers).
    Just. Don't. Do. It.
  11. Jan 9, 2023 at 4:51 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    They will turn on yes, output will be worse than stock, you'll lose distance projection and likely have excessive scatter and glare blinding other drivers while not being able to see as well yourself either.
    Are your new assemblies aftermarket? Do they look like stock? Any off the shelf unique looking aftermarket headlight is going to be a major downgrade from stock since aftermarket companies selling those types of lamps are not putting money into high quality precision optics. The cheap chinese optics used lack focus, which reduces output intensity and distance projection. Putting an LED bulb in only compounds the problem and makes it significantly worse since LEDs also lack focus and shift the pattern away from distance projection.
    OEM headlights are the best and highest performing off the shelf assembly available. Part numbers available in the 1st post of my 2003 build thread. For bulbs, the best performing 9003/H4 low beam bulbs are the Philips Racing Vision +200 for stock wattage. If you want serious lighting power, an HD harness with the Osram Superbrights will deliver. That is what I run on my 1st Gen. As pointed out the 2nd Gen headlight thread uses the same 9003/H4 base, only difference is ground switched wiring on 1st Gen requiring a different harness if choosing to go with the high power bulbs, but that is covered in the 1st post of the thread. Output numbers will obviously vary slightly as well being the 2nd Gen has larger lamps.
    To boost performance even further, you can run an AGM with a voltage booster, and since voltage boosts halogen output exponentially to the power of 3.4, all lights including headlights get a nice output bump. I also run that setup on my 1st Gen. A nice side benefit is the voltage increase breathes a little more life into the 20 year old power window motors.
    Lots of headlight improvement options, but replacement LEDs are not one of them.
    kevinnnn, scout67, Winkle99 and 2 others like this.
  12. Jan 9, 2023 at 6:39 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    My LED’s seem on par with the halogens and haven’t had anybody flash their lights at me since I adjusted them but idk
  13. Jan 9, 2023 at 7:24 PM
    Noakea_Bean
    Noakea
    42" Light Bar
    Thanks for the great write-up! I'll look into all that!
  14. Jan 9, 2023 at 7:31 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Same, but I have shielded ones which have a cutoff. Everyone here assumes that LED are all the same but it's not the case. Can't be any more obnoxious than some of the projector setups I have been around in these trucks.
    YotaOverAll[QUOTED] likes this.
  15. Jan 9, 2023 at 7:33 PM
    JKO1998
    Utah
    My leds with the cut off thingy fried my ham
  16. Jan 9, 2023 at 7:33 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I prefer my ham smoked
    BYJOSHCOOK likes this.
  17. Jan 9, 2023 at 7:34 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I prefer my ham laminated
  18. Jan 9, 2023 at 7:37 PM
    m3bassman
    Green truck
    Explain.
  19. Jan 9, 2023 at 7:41 PM
    JKO1998
    Utah
    I dunno, LED's interfered with my ham, @turbodb had an issue too I think. Never really worked great after that, till I got a new one.
    turbodb likes this.
  20. Jan 9, 2023 at 7:42 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    I installed my paranoid switch panel below my radio
