  1. Jan 9, 2023 at 7:42 PM
    Noakea_Bean
    Noakea_Bean Well-Known Member
    Noakea
    2001 Toyota Tacoma SR5 4X4 2.7L
    42" Light Bar
    I'm sorry, whats a ham?
  2. Jan 9, 2023 at 7:44 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Ham radio
  3. Jan 9, 2023 at 7:44 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Expensive radio that never works right when you want it to
  4. Jan 9, 2023 at 7:48 PM
    Noakea_Bean
    Noakea
    42" Light Bar
    Oh okay. I thought so but I didn't think it would interfere with the lights
  5. Jan 9, 2023 at 7:52 PM
    JKO1998
    Utah
    My ditch lights interfere too, but they're right next to my antenna so it makes sense
  6. Jan 9, 2023 at 7:56 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    The lights interfere with the radio
    turbodb likes this.
  7. Jan 9, 2023 at 8:57 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I generally liked the light pattern from my LEDs (with cutoff), though hi-beams in the snow was a disaster. Here was the write-up I did on the RFI (radio frequency interference) from my LEDs with the Ham Radio. Out with the LEDs, Back to Halogen Headlights
    I have yet to find any (low priced) LEDs that are "good" from an RFI perspective. That's to be expected, frankly, at such a low price point. The same was true of my HID-upgraded Hella's - they were a bear from an RFI perspective. The SS5s are *much better* but still not perfect.
    Also - I think that one of the reasons you never had any issues with your LEDs and cutoff, whereas I felt like mine - also with a cutoff - weren't as good, had to do with the housings. I think the 01-04 housings are a lot better, since they reflect back and out, vs. the 98-00 which are just a complete mess from a reflector perspective.
    @Noakea_Bean
    Hey now, it's no harder to get a ham to work than a CB. It's the APRS that we always have trouble with. Well, and anything Monte sets up. :boink:
    m3bassman[QUOTED] likes this.
  8. Jan 9, 2023 at 9:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You shouldn't need to adjust them. Aiming them down due to glare issues is counter productive to the design of a headlight. The headlight is to project distance, the goal is to extend that distance projection with better focus to you can see farther and react sooner. LEDs might produce more light, but they lack focus so they don't project as far, then aiming them down due to poor beam discipline compounds that issue even more, greatly reducing the distance you can see, therefore reducing your reaction time to hazards. The tricky part is that reduced focus and aiming the lights down increases the foreground light on the ground right in front of the truck, so it seems brighter leading people to think they are as good if not better than their halogens. But it is brighter in the wrong spot, short range foreground and loss of distance light where it actually matters. Foreground light is useless at speed and foreground light also reduces your distance vision at night, which is why OEM lights do not contain high amounts of foreground light. The entire thing kinda snowballs down a bad path. That said, some LEDs are better than others. But none are nearly as good as using a good halogen bulb in a halogen assembly.
    The RFI and EMI can be transmitted through the electrical system, proximity doesn't necessarily matter.
    Digiratus and Gen1FTMFW like this.
  9. Jan 9, 2023 at 9:15 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Glad you found the headlight thread useful. :) BeamTech is literally the worst headlight product I have ever evaluated. Reason being the product isn't a serious one at all, I'd never waste my time reviewing something that bad, but a certain member was sooo adamant that their LEDs were a huge upgrade and absolutely swore they were better than their halogens. They couldn't seem to understand the concepts about foreground light shift and lack of focus I mentioned in the previous post, so I bought them to demonstrate the issue.
    The review is for H11 in 3rd Gen in post #1854. Not quite as detailed as most my reviews because it isn't worth the effort. Enjoy.
    turbodb[QUOTED] likes this.
  10. Jan 9, 2023 at 9:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think there are a lot of folks who think the white color of the LED light is cooler. No pun intended. Personally, I can see a lot better at night with a warmer light. To some of us that is important. Were talking the difference between 6,000 kelvin compared to 3,500-4,000 Kelvin.
    turbodb likes this.
  11. Jan 9, 2023 at 10:17 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    driving newer cars at night i've found to be miserable with leds. the light sucks in snow and rain.. halogens color is far better in my opinion
    but it does look dated.
  12. Jan 9, 2023 at 10:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Is there anything about 1st gens that isn't 'dated'?
    jubei, Yetimetchkangmi and JBTacoma like this.
  13. Jan 9, 2023 at 10:21 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    I had to bend the “feet” to contour to the cab. Took me the better part of a day. I’m not sure why they didn’t just do it from the manufacturer.
  14. Jan 9, 2023 at 10:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Definitely, 6000k LED is so reflective any bad weather is hard to see through. If you haven't driven a vehicle with LED headlights in bad weather it is actually quite a shocker. At first it just seems the weather is super bad, but then either over time or if you have the chance to drive a halogen vehicle back-to-back you realize it isn't the weather that is bad, it is the headlights. All the reflective back scatter is gone with the halogens and you can see the road that was difficult to see with the LEDs.
    Post #6206 demonstrates a good example how the 6000k color temp highlights bad weather and lower color temps allow you to see beyond it. It is 6000k LED vs selective yellow so not halogens, but halogen 3200k is much closer to selective yellow than it is 6000k and similar results will be realized.
    ztwatson likes this.
  15. Jan 9, 2023 at 10:35 PM
    Empty_Lord
    Dan
    my enjoyment of them!
    i really do not enjoy newer cars. i stick with my old ones and add what i want.
  16. Jan 9, 2023 at 10:39 PM
    JKO1998
    Utah
    All you add is a thick layer of rust dust from dying cars surrounding your collection
    Speedytech7 likes this.
  17. Jan 9, 2023 at 10:55 PM
    Empty_Lord
    Dan
    I save them from rust. By spring I hope to have at least 2 frame swaps done and the mr2 roadworthy
    just waiting on the clutch for the 98 to start getting the swaparoo
    jubei likes this.
  18. Jan 10, 2023 at 2:16 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    I deleted my EGR and am adding a catch can to mine. Bc I don’t want my 3rz to suffer from black lung disease.
  19. Jan 10, 2023 at 3:49 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Yeah I know you can get interference I just don't see it able to kill the unit as Jaxon implied.
    As for the housings, I think you're right as well, the 98-00 had diffusing lenses and the 01-04 did not. Granted, I'm not on OEM housings and do have a couple light defects but that occurs both for halogen and led bulbs when I tested it. I do need to pick up a handheld ham at some point as all my hams have died.
  20. Jan 10, 2023 at 5:37 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    A lot of drivers have the bad habit of having low angle vision, and never look down the road. These drivers are probably the ones that think they are better. The light doesn't project down the road, but they never look down the road. Their focus is right in front of their bumper, just like their headlights.
