  1. Jan 28, 2023 at 7:05 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Get now lbj very quickly.
    And check your uca bushings and lca bushings.
    DashMaple[QUOTED] and Wulf like this.
  2. Jan 28, 2023 at 7:16 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I agree on replacing the LBJs, @DashMaple , but I doubt that amount of play would cause that change in camber.
    I would check to make sure you alignment cams are torqued first thing.
    DashMaple likes this.
  3. Jan 28, 2023 at 7:21 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    LBJs are on the list to do, Ill def check my bushings and alignment cams.
    Any suggestions on LBJs that might last longer than OEM? I wasnt too impressed with the 555 inner tie rods I got, and very displeased with my moog sway bar end links.
    I dont drive the truck too often now so no need to worry about me sending it down the road with bad ball joints and ending up with a kachow post on here haha. I do appreciate the concern though.
  4. Jan 28, 2023 at 7:32 PM
    Squeaky Penguin
    Brett
    Gonna attempt to setup a spare diff. 1st diff setup so we'll see how it goes...
  5. Jan 28, 2023 at 7:32 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    OEM and replace more frequently since you wheel or Total Chaos uniball conversion for $1000.
    DashMaple[QUOTED] likes this.
  6. Jan 28, 2023 at 7:43 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    The problem isn't that OEM are of substandard quality, it's that the design is fundamentally flawed. OEM is still generally considered the best value even though it costs more.
    Some folks do like 555 ball joints, especially those folks who thrash on their trucks replace their ball joints more frequently than normal. The cost savings outweigh any quality difference when you're going to replace them frequently regardless.
  7. Jan 28, 2023 at 10:05 PM
    Flo_TRD07
    Flo_TRD07 Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    I know it's not standard practice on the forum to do this, but I just found this pic and wanted to share it here... I've since upgraded to a 2007 taco since then... But here was when I got my first gen and caught the bug for Tacoma's... I was 17, young, dumb, and stupid at the time (ended up having to get rid of it for that reason). I'm now 22, somewhat older, just as dumb, yet slightly less stupid. I hope you old heads enjoy. Don't worry, the Airforce taught me how to cut my hair and wear shoes!
    det107, 04Pre_Runner, Civi and 2 others like this.
  8. Jan 28, 2023 at 11:49 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Had the exhaust extended out the back and took it all up to 2.5in pipe. No more drone and sounds great now.
    unstpible likes this.
  9. Jan 29, 2023 at 5:59 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I’m waiting on a set of these from Josh:
    https://anonymousfab.com/
  10. Jan 29, 2023 at 11:29 AM
    Civi
    Civi Active Member
    Carlos
    2004 Impulse Red Dbl TRD 2wd
    265/70R17, Helo Rims, leveling kit, smoked rear lights, led light bar, double din JVC, backup camera, led interior lights, red rock pod lights, led headlights
    So, the update to this is that even though I could have just replaced the fuse and restored my dash lights since I already had the gauge cluster pulled decided to check the lights. Turns out that if your selling a truck and you don't want to advertise that there is an airbag or abs issue you just remove the lights
    At least now I know I have an issue and can address them
  11. Jan 29, 2023 at 11:57 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Experimenting something. Used chemical guys on the hood and meguiars on the roof. Same type of product so we’ll see how the two compare.
  12. Jan 29, 2023 at 12:12 PM
    Civi
    Civi Active Member
    Carlos
    Did the Gentex mirror wiring while I had everything apart and was able to get a nice clean run under the dash. Took advantage of existing cord organizers and took an old rubber bushing for the run through the metal frame in the middle. Had the mirror glued when wife's windshield got replaced so am good to go20230129_121055.jpg
    04Pre_Runner and Phessor like this.
  13. Jan 29, 2023 at 3:42 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Upper ball joints. Driver side was fine, passenger side was dry and sloppy.
    04Pre_Runner and Yetimetchkangmi like this.
  14. Jan 29, 2023 at 6:03 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Moog are still going 3 years later after comparing OEM side by side. I personally don't think the Teflon liner can handle the abuse I put I through.
  15. Jan 29, 2023 at 6:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Outta curiosity what kinda lube are you pumping into the Moogs? I've been using Stalube Super Moly fortified for my SPC uppers and moog tie rods. Been good so far on those.
  16. Jan 29, 2023 at 8:11 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Fun times :yawn:
  17. Jan 29, 2023 at 8:31 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Been there, by the time I was fitting shifters I was exhausted from the dual cases project lol but you’re close to the end! Good work!
    betterbuckleup likes this.
  18. Jan 29, 2023 at 8:35 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I FOR SURE know what you're talking about.
    I'm kind of getting burned out on all these projects this winter... and I still have the rear axle and suspension to do.
    I just want to thrash on this and get the duals done. Go to Hammers, and take a break from projects for a minute.
    Dan8906[QUOTED] and unstpible like this.
  19. Jan 29, 2023 at 8:59 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
  20. Jan 29, 2023 at 9:00 PM
    Speedytech7
    Nice! Glad to see you got er done. What did you do about the clutch lever?
    unstpible[QUOTED] likes this.
