  1. Feb 11, 2023 at 2:02 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    These O² Sensors nuts are dead to me
    Speedytech7 and Kiloyard like this.
  2. Feb 11, 2023 at 2:38 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
  3. Feb 11, 2023 at 4:10 PM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
    Nice tail lights. I have the same ones in smoked. Are yours clear? Did you have to rewire them to work with 01-04?
  4. Feb 11, 2023 at 4:41 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I figured out how to compress a timing belt tensioner without a bench vise. OTC front end kit came in handy again... and I used penny because the screw has a pointy tip and I didn't want to damage it.
    Area51Runner and Bluecord like this.
  5. Feb 11, 2023 at 5:38 PM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    these are smoked too. I haven’t rigged the wires yet, but knew I’ll have to. Uh… can you explain what you did?
  6. Feb 11, 2023 at 6:48 PM
    unstpible
    Derek
    Cedar City, Utah
    That small section with the O² sensor is the only thing left of the original exhaust seems fitting that it would put up a fight
  7. Feb 11, 2023 at 6:53 PM
    unstpible
    Derek
    Cedar City, Utah
    This might help
    It's fairly simple
    QUOTE="unstpible, post: 26759358, member: 84909"]How about those Anzo Taillights ah? In my opinion they are the better looking aftermarket taillight available for these trucks but they are not wired to work in the 2000-2004 Tacomas.:angrygirl:
    They use the same size plug and have the same body shape so i figured it couldn't be too hard to figure it out and I wasn't the 1st person to make it work either
    Pre 2000 Tacomas have 5 pins in the plug and the newer models have 6 pins, that extra pin is just a jumper wire for a ground
    If you look closely in the picture below you can see the top left pin is a little darker because it came off an old set of taillights. This is the Jumper wire I'm adding and it clipped right into place like it was designed to
    The other end of the Jumper wire needs to be spliced into the middle pin. I used a tiny flat head screw driver to press in the little barb on the pin and then it pulls right out of the plug.
    It is important to note that the passenger side Jumper wire does not splice into this same spot.
    Ask me how I know :anonymous:
    Then ask @JKO1998 if you still don't believe me
    On the passenger side Jumper wire you will still add the pin into the same spot (its the only unused slot available) you will splice the Jumper wire to the pin right next to it this time like so
    Here's a pic of the passenger side stock Jumper wire that you are recreating
    (white wire with black stripe)
    And a pic of the drivers side Jumper on the OEM light
    I cut the white wire with black stripe to get it out of the way for a better picture of the green Jumper wire
    Long story short make the Anzo plug look identical to the plug on the OEM 6pin plug
    If your passenger side taillight works correctly while plugged into the drivers side, something is wrong.
    I thought it would be more complicated and a local Audio video shop told me it couldn't be done, the owner even went as far as saying the wiring on my truck was incorrect and had no power running to it at all even though the OEM lights were working properly when I arrived at the shop. I'll never have them do work on my vehicle again
    [/QUOTE]
  8. Feb 11, 2023 at 7:27 PM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    [/QUOTE]
    Bookmarked this post. Exactly what I needed. Thanks
  9. Feb 11, 2023 at 7:30 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    How did your wiring finish up?
  10. Feb 11, 2023 at 7:30 PM
    unstpible
    Derek
    Cedar City, Utah
  11. Feb 11, 2023 at 8:08 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
  12. Feb 12, 2023 at 3:54 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    Same here. I replace the full exhaust line with a new upstream sensor and a block plate for the lower. Those nuts gave me hell. Had to use extractors
  13. Feb 12, 2023 at 11:20 AM
    Bolt Head
    Colorado
    Sorry, just saw your post/question but I saw unstpible got ya covered.
  14. Feb 12, 2023 at 1:20 PM
    VolcanoTacos
    VolcanoTacos Well-Known Member
    That was a good idea!
  15. Feb 12, 2023 at 1:23 PM
    VolcanoTacos
    I found a SUPER mint condition leather 3rd gen 4runner steering wheel that I swapped into my 98 today! The steering wheel had the "3 wire" cruise control so that was plug and play but I did have to swap the clock spring from the 4runner as well because the airbag connector is different. Also the steering column cover from the 4R fit perfect as well so now everything is black.
    Also the reason I did this is because the old steering wheel became "detached" from the metal frame so when you were holding it it would move/twist/jiggle and was annoyingIMG_6858.HEIC.jpg
  16. Feb 12, 2023 at 4:01 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Wanna sell me your old clockspring?
  17. Feb 12, 2023 at 9:35 PM
    mattarch
    mattarch Member
    2003 Tacoma SR5 4x4 Extracab
    new wheels and tires - Nomad Convoy wheels in grey with Veredestien AT tires:IMG_5144.jpg
  18. Feb 12, 2023 at 10:08 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Recently did Solo Long Travel front.
    Did a 5 day trip to King of the Hammers.
    Took the truck on some pretty frosty test rips.
    Wife said "Damn, what a difference the LT made, can't wait till the back matches"
    Yes, fellas... I won the wife Lottery.
    Burro, SpokeWench, vonellis and 6 others like this.
  19. Feb 13, 2023 at 5:53 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    Got an alignment scheduled for Friday morning at a local custom shop. National chains didn't want to touch it lol. Fine with me.
    Area51Runner likes this.
  20. Feb 13, 2023 at 5:56 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    What are you asking then to do that is so special?
