  1. Feb 13, 2023 at 8:47 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Same, but with my 4banger. 4th gear 3k rpm 60mph average most all of the way. Grades were about the same experience as you. 8-9 mpg average. Trailer weight around 2500 lbs.
    Needed about a 10in drop hitch as well...
    cbechtold likes this.
  2. Feb 13, 2023 at 9:08 PM
    Lil Puke
    Lil Puke Well-Known Member
    Oregon
    ‘99 Taco
    crumbs between seat cushions, junk in glove box, center console mostly full
    Neither of these posts are getting me stoked for an upcoming 1800 mile tow.
  3. Feb 13, 2023 at 9:51 PM
    betterbuckleup
    Ian
    Concord, CA
    :rofl:
    most annoying part was how often I had to fillup. about 135 miles per tank
    ztwatson and Lil Puke[QUOTED] like this.
  4. Feb 13, 2023 at 11:46 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    i do not miss having to tow with the taco.. it would do it.. but man the tundra is effortless. 550 miles of driving today with my mr2 in tow. horrible mpgs. but it handled it lol
    Gen1FTMFW[QUOTED] and Lil Puke like this.
  5. Feb 14, 2023 at 8:35 AM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    I was worried about that as well. I averaged 10ish mpg for the first 100 miles (minor grades, stoplights, defrost in) and used that as a baseline. The following stretch was 170 miles with more grade and zero service. I was nervous so I topped the tank off. Ended up rolling into the station with just over 1/4 tank. Not sure how that worked, but must've been the stoplights in the first stretch that really killed me. Just did the math and pulled anywhere from 10mpg to 18mpg depending on the stretch, with an overall average of 15mpg over the 500 mile trip.
  6. Feb 14, 2023 at 9:19 AM
    Lil Puke
    Oregon
    ‘99 Taco
    I’ll be sizing down to 31” tires prior to the trip so hoping that I end up in a similar mpg range as you did. I can keep a pretty light foot so I have that on my side. Also will be towing a single axle rather than tandem, fingers crossed it wont be over #3500.
    I hauled a 6x10 enclosed for a neighbor last summer but it was an 8’ tall box at #2500. Hoping this next trip goes noticeably better with a v nose and reduced frontal area, even though I’ll be heavier.
  7. Feb 14, 2023 at 1:47 PM
    erice
    erice Well-Known Member
    Eric
    San Diego
    Don't forget to get an alignment after downsizing also, that'll help some more.
    Lil Puke[QUOTED] likes this.
  8. Feb 14, 2023 at 1:51 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
  9. Feb 14, 2023 at 7:32 PM
    02hilux
    Planet: EARTH
    Is your CO bottoming out before the air bump?
    Dan8906 likes this.
  10. Feb 15, 2023 at 12:56 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    No, the bottom of the body of the shock passes through the coil seat. The shocks never bottomed out. They can't the bump stop will stop it.
    The bottom of the body of the shock (blue line) would have to get down to about the green line for the shock to bottom out.
    erice likes this.
  11. Feb 15, 2023 at 8:21 PM
    Slysock
    Slysock Member
    99 Mobile Home
    Stock
    Replaced battery after frying it by tack welding a front hitch I built into place... Lucky I didn't do more damage.
    Remember to disconnect your battery before welding!
    Fantastic11 and thomasburk like this.
  12. Feb 15, 2023 at 8:36 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You are totally right... I must have been lucky though... cause I can't tell you how many times I have forgotten to disconnect my batteries and never had a problem.
    Dan8906 and Lil Puke like this.
  13. Feb 16, 2023 at 9:23 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Finally drove it after all the new work. It's crazy how much better it feels without a misfire. Runs and idles great, but I am trying to track down a clicking noise that exists after it's been running a while. I think I potentially found the culprit being the silicone hose that goes from the IAC to the motor (it splits in 2) was collapsing under vacuum. I kept the OEM hose and it looked like it was in good condition so I slapped it back on. I need to run it more to see if it comes back.
    [​IMG]Untitled by Michael Halat, on Flickr
    Trying to figure out if this is new.
    https://www.youtube.com/watch?v=1sAuOEb2ChI
    I don't remember hearing this before. I would assume if it was a vac leak it would be idling much higher. It's idling at if not lower than before. Only happens on quick blips of throttle. Only changes at the throttle body was taking slack out of the cable, and adjusting the "soft close" mechanism to use more of its travel.
  14. Feb 16, 2023 at 10:25 AM
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    My 5VZ does the same thing; always just on quick blips like that too. It always sounds like a vacuum leak, but I believe it is normal.
  15. Feb 16, 2023 at 10:27 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's how engines sound when you open the throttle fast, sounds good!
    erice likes this.
  16. Feb 16, 2023 at 10:51 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I was wondering how those would look on a lunar mist, I am into it.
    :thumbsup:
    Maybe my slack was so bad before I could never get that quick blip feel :rofl: I took out a ton.
    Speedytech7[QUOTED] likes this.
  17. Feb 16, 2023 at 1:03 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
  18. Feb 16, 2023 at 2:21 PM
    NewToTheScene
    NewToTheScene Flexy Lexi
    Blake
    KEY WEST, FL
    2004 Tacoma, Long travel, lockers, 4X4
    It’d be easier to say what is not done to it.
    For anyone that’s interested. I spent way too much money and then waited a couple months, but here we are- Dana 44 hubs, manufactured spindles, lower ball joint uniball conversion, and RCV axles. Yes I know everyone is saying I’ll break my front diff before anything. But when that happens, I’ll upgrade that too. IFS for life. Also, time for ABS delete.
  19. Feb 16, 2023 at 2:26 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Keep us up to date on how that stuff works out. I'll be making that investment sometime this year. I've just been getting a bunch of other stuff done before I make that plunge.
    Solo LT = done
    Dual cases = done
    Rear axle is next
    Then I'll be doing the Solo spindles, Heim steering upgrade, and RCV axles
    erice and NewToTheScene[QUOTED] like this.
  20. Feb 16, 2023 at 2:30 PM
    Overland_Architect
    Overland_Architect Well-Known Member
    Phoenix
    2002 Tacoma PreRunner Ext Cab Black
    Old Man Emu Suspension Dakar Leaf Springs Icon Delta UCA’s Relentless Fabrication Summit Bumper 4xInnovations Rear Bumper Tire Swing out 05 OEM Bed Rails
    Installed OEM rear mudguards today.
    SpokeWench, erice and willee51 like this.
