  1. Feb 26, 2023 at 8:30 PM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    Currently in Corvallis Oregon for school but I grew up in the Medford area and have spent most of my life there. Not a fan of Northern Oregon or the Willamette Valley, can't wait to get down south again.
    Gen1FTMFW[QUOTED] likes this.
  2. Feb 27, 2023 at 4:55 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Where'd you get that front bumper? I dig it.
  3. Feb 27, 2023 at 8:49 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I made it, looking into producing them if there's enough interest.
  4. Feb 27, 2023 at 8:50 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  5. Feb 27, 2023 at 9:21 AM
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    https://www.ebay.com/itm/394438542069?
    30 bucks for the support on eBay isn't great, but it's not terrible either. I just had to replace mine recently, because a PO had broke it, and I never noticed. The latch definitely needs this support to release properly. I had to fiddle with it so much before I replaced mine. Works like a champ now.
    For that blowout, I would cut a small square of sheet metal and weld a nut on the back of it. Or you could use a riv-nut for the threads. And then weld it in place, grind it smooth, and paint.
  6. Feb 27, 2023 at 9:57 AM
    austinmtb
    Austin
    Southern Oregon
    I bought it used off of someone. I have no idea who built it but I assume it’s a one-off custom bumper.
  7. Feb 27, 2023 at 10:32 AM
    Fantastic11
    Do these still exist? I looked for them a while ago, but had trouble. It'd be cool to find a chrome version too.
  8. Feb 27, 2023 at 10:38 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
  9. Feb 27, 2023 at 11:03 AM
    Area51Runner
    Answered my own question.
    Specs for local brick/mortar searching-
    • Thread Size: M12-1.25
    • Wrench Size: 19mm
    Amazon links -
    https://www.amazon.com/dp/B09267PSGV/
    https://www.amazon.com/dp/B00JDU66GA/
    Coilover Center Support Nut, OME Nitrocharger nut
    robblacktpre03 likes this.
  10. Feb 27, 2023 at 11:21 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Yeah, nobody has ever made a true low profile first gen bumper. They all pretty much seem to stick way out on at least the corners.
  11. Feb 27, 2023 at 12:39 PM
    austinmtb
    Austin
    Southern Oregon
    Yeah it's unfortunate. This one has always stood out to me as being really low profile for a winch bumper: https://truenorthfabrications.com/c...s/96-04-tacoma-open-wing-hybrid-bumper-welded. Might be swapping out my bumper with this one eventually so that I can have a winch.
  12. Feb 27, 2023 at 2:47 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    how much was that
  13. Feb 27, 2023 at 3:49 PM
    Bluecord
    Bluecord Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    Did the timing belt, water pump, thermostat, idler roller, tensioner roller, hydraulic tensioner, cam shaft seals, crank shaft seals, new crankshaft bolt, and all new accessory belts. Used the aircabinman kit available on ebay. I bought the kit about 3 years ago and its gone up about $50 since then. The hardest part was getting the crankshaft bolt free and getting the new belt on. @Timmah! was right about the belt being near impossible to get on. I guess I'll add my data to the jiggle valve discussion. Mine was in the 12 o'clock position when I got to it and temps were running up to 203F. I put the new one in with the jiggle valve at 6 o'clock and the temp now doesn't go over 190.3F on my Ultragauge. On a positive note, I didn't strip or break anything, and no parts were left over when I was done.
    Civi, SwampYota, erice and 6 others like this.
  14. Feb 27, 2023 at 6:51 PM
    austinmtb
    Austin
    Southern Oregon
  15. Feb 28, 2023 at 1:03 AM
    Sebz13
    Shane
    Maui Hawaii
    It’s pretty sick
  16. Feb 28, 2023 at 1:42 PM
    erice
    erice Well-Known Member
    Eric
    San Diego
    Found both oem from the stealership for 84$
    54 for the latch and 30 for the support.
    However I won't be able to install the support since my bumper overlaps the bottom mount section. :'(
    If I can't use the center support, I'm not sure if I want to reuse the factory latch tincan location.
    I've got some aerocatch showing up today so I will see if it's even viable. The top section appears to ride on a curve so I'm not sure the 5degree allowance for thr pins will be even plausible.
  17. Feb 28, 2023 at 10:37 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Don't do it
    YotaOverAll, Gen1FTMFW, erice and 2 others like this.
  18. Mar 1, 2023 at 12:09 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Nothing wrong with it
    Yetimetchkangmi likes this.
  19. Mar 1, 2023 at 12:09 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    austinmtb[QUOTED] likes this.
  20. Mar 1, 2023 at 12:26 PM
    erice
    Eric
    San Diego
    I second this. Don't do it.
    Gen1FTMFW likes this.
