  1. Mar 20, 2023 at 12:38 PM
    Fantastic11
    Fantastic11 Well-Known Member
    1997 3.4L 4WD / 1996 3.4L 5-Lug
    Shortly after I bought my '97, the original fuel pump failed because the fuel filter was so packed full of crud (no rust in the tank), it couldn't push fuel through it anymore. I wish I would have taken a picture of what I blew out of it with shop air. It was crazy. That was 220k miles on what looked to be the original fuel filter. Results will definitely vary on this for sure, depending on what gets into your tank, but I just thought I would add that.
  2. Mar 20, 2023 at 3:10 PM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Dropped it off for a little diff work.
  3. Mar 20, 2023 at 5:16 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    You need to keep both the low and high wire active when you engage the high beams.
    When you engage the headlights, it grounds the low beam filament. When you engage the high beams, it removes the ground from the low and adds a ground to the high beam filament.
    You can add a diode, something like this https://amzn.to/3TrNh9E
    that goes between the high beam and low beam wires. I did this on my wife’s car when I installed OEM halogen projectors so I didn’t have to do any new wiring.
  4. Mar 20, 2023 at 9:38 PM
    Fantastic11
    I would have never thought to use a diode on it. That's genius.
    @Squeaky Penguin Make sure to put the banded end on the low beam ground to have the desired effect.
  5. Mar 21, 2023 at 5:56 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    What are you having done? I've been toying with the idea of getting a limited slip installed on my prerunner.
  6. Mar 21, 2023 at 11:17 AM
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    4.88s and selectable eaton e-lockers
    Digiratus and chrslefty like this.
  7. Mar 21, 2023 at 11:45 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    NICE! Eaton is the way to go. :thumbsup:
  8. Mar 21, 2023 at 11:50 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I've been getting shitty mileage lately too.
    And my fuel filter has over 380,000 miles :anonymous:... Maybe I should replace mine lol.
    Could be the fuel filter... could also be they are upping the ethanol in the gas. (Like putting air in a potato chip bag to make you think you're getting more chips)
    Regardless... I've had a fuel filter in my Amazon cart for about 2 years... maybe it's time I ordered it :rofl:
  9. Mar 21, 2023 at 5:31 PM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    28683709-BE72-4DB8-8D11-86ECDDC8F596.jpg Not mine, but my youngest son’s. We removed the bed so he can clean up the frame and weld some nice supports for the swing out. He also noticed a part of the frame under the body that has to be repaired. The rust is not looking good in that area.
    Speedytech7 likes this.
  10. Mar 21, 2023 at 8:27 PM
    SpokeWench
    SpokeWench Well-Known Member
    Paula
    1998 Tacoma SR5 4x4, Super Pacific X1
    Mystic Purple Mica, Super Pacific X1 (bld 359)
    Today and the past few days where the day was actually dry. :D
    Upgrading my camper storage from my temporary solution to a more permanent installation.
    First testing of LH structure - here you can see my temporary solution.
    Fine tuning ...
    I actually gave some thought to how I cut the plywood, wanting to match the grain horizontally.
    Panels are secured with finish washers and M5 screws.
    Ready for the weekend.
  11. Mar 21, 2023 at 8:48 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    80/20 is some good stuff. Nice and light and plenty strong. Looks awesome.
    SpokeWench[QUOTED] likes this.
  12. Mar 21, 2023 at 9:06 PM
    SpokeWench
    Paula
    Thanks, plus has a fair amount of flexibility for changes/additions.
    0xDEADBEEF[QUOTED] likes this.
  13. Mar 21, 2023 at 9:30 PM
    Jake92
    Jake92 Active Member
    Traded my cooper tires for BF Goodrich tires KO2
    ztwatson and DIRT YOTA like this.
  14. Mar 21, 2023 at 9:40 PM
    1997tacomav6
    Denver
    I hope you have better luck then me,
    They could not get them balanced at 65-70mph for me
    Jake92[QUOTED] likes this.
  15. Mar 21, 2023 at 9:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Same, damn things weren't round actually
    Jake92 and 1997tacomav6[QUOTED] like this.
  16. Mar 22, 2023 at 7:41 AM
    Jake92
    Hopefully we will see today thanks for the input I’ll keep a close feel of them at higher speeds
  17. Mar 22, 2023 at 9:02 AM
    Pittbull35
    Pittbull35 Member
    Tacoma.jpg Upgraded to Sylvania cool white LED's. 2003 PreRunner.
    1997tacomav6, chrslefty and noodles93 like this.
  18. Mar 22, 2023 at 11:51 AM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    Welp, some jack wagon blew a red light and smashed my bed side. Thankfully didn't get into the cab.
    So whats the word on fiberglass for first gens these days? Is Advanced Fiberglass the way to go? Id probably do bedsides and front fenders to match. Any fitment issues? On there website they list fitting 95-04, I thought the corner marker lights where different between the 95-00 and 01-04?F3E64FF1-193A-48F7-86D7-67E05BF3B3BA.jpg
    Yetimetchkangmi likes this.
  19. Mar 22, 2023 at 12:00 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Fiberglass with a shell? Sketchy...
  20. Mar 22, 2023 at 12:28 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    shouldn't be an issue. I've seen plenty of guys have GFC's and other campers on their fiberglass bedsides. Albeit they were mostly 2nd gens, but I don't see any reason why you couldn't make it work on a 1st gen as long as the weight of the camper is in the right spot
