  1. Apr 5, 2023 at 12:30 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    They are fairly new. I haven’t done a bolt check yet however. I think it’s so for an alignment anyways so I may just bring it to Firestone and see if it does it afterwards
  2. Apr 5, 2023 at 1:03 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Alignment is a good place to start forsure
  3. Apr 5, 2023 at 6:13 PM
    Civi
    Civi Active Member
    Carlos
    2004 Impulse Red Dbl TRD 2wd
    265/70R17, Helo Rims, leveling kit, smoked rear lights, led light bar, double din JVC, backup camera, led interior lights, red rock pod lights, led headlights
    Have been thinking of this mod combined with the turn signal mod. Can you provide more detail. Did you have to trim? Do they fit in the bracket or did you have to fab something.
  4. Apr 6, 2023 at 1:22 PM
    erice
    erice Well-Known Member
    Eric
    San Diego
    Pulled the bed system out. Plan to get the frame more dialed in with some l track and install the drawer slides. But first... 3m thinsulation for the roof.
    Use to have xps in my last shell and it worked great.
    Wanted to hvac tape the seams as I did with the ridgid stuff but it doesn't take well to the thinsulation. Chose this becaue its highly rated and it'll compress perfectly when I put panels on.
    20230406_114817.jpg 20230406_114823.jpg 20230406_123640.jpg 20230406_123643.jpg 20230406_131355.jpg
    Should make a world of difference in this small space.
    Need to plug all the holes in the bed also. The silt from pole line found every one of them. iykyk
    chrslefty and Area51Runner like this.
  5. Apr 7, 2023 at 6:59 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Got the final coat of paint on the BudBuilt front skids and made a little platform saddle for my floor jack to keep the skid in place while I'm installing it. Hoping to get the belly skid cleaned up and installed this weekend.
  6. Apr 7, 2023 at 7:39 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Drove the Taco thru Carrizo Plain today
    erice, jubei and vonellis like this.
  7. Apr 7, 2023 at 7:49 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Yet another painting project.
  8. Apr 7, 2023 at 7:57 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
  9. Apr 8, 2023 at 12:46 PM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
  10. Apr 8, 2023 at 2:53 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Not sure, I have a sun visor delete :laugh:
  11. Apr 8, 2023 at 5:49 PM
    Bolt Head
    Colorado
    It has the measurements in Amazon . I'll take a measurement of between my sun visors and see.
  12. Apr 8, 2023 at 11:14 PM
    erice
    Eric
    San Diego
    You've got about 10" +/- to work with. I ran into that looking at lcd screen rearview mirrors. 12" was too big so I went with a 10"
  13. Apr 8, 2023 at 11:48 PM
    ilikecider
    ilikecider Member
    3rd gen Taco MT 17
    CAI TRD
    What kind of topper is that on the bed?
  14. Apr 9, 2023 at 4:21 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Finished the upper today. VHT titanium silver blue with VHT clear coat. Probably just gonna stick with the other set I painted black so who wants this one. Only did this cus I’m bored lol.
  15. Apr 9, 2023 at 4:30 PM
    TheloniusDrunk
    TheloniusDrunk Well-Known Member
    99 3.4L M/T 4WD 220k
    I'm running into issues removing the upper plenum from the engine bay. I've removed all the bolts and have it flipped over to access the 3 tubes on the throttle assembly underneath. I've managed to get 2 of the 3 tubes disconnected at one end but the third I can't disconnect from the throttle body assembly (actually two of them feel like they're glued onto the throttle bottle assemble but the other I was able to disconnect from the other end -- see binder clip). The stubborn one is closer to the cockpit and I can't access the clamp on the lower end that feeds into the engine but removing the clamp on the throttle body assembly hasn't made it any easier to detach the hose on that juncture. Any advice here? Picture attached
  16. Apr 9, 2023 at 4:38 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Those usually just come right off for me once the clamps are moved away. Gotta muscle it a little tho. Get a flathead in there and pry the hose off? And if so, whoever glued the hose on is an ass.
    Wulf and TheloniusDrunk[QUOTED] like this.
  17. Apr 9, 2023 at 5:08 PM
    TheloniusDrunk
    Was able to pry them off after about 15 minutes with a flathead as a wedge, thanks.
    Now I've run into a stripped bolt head and idk if I'm going to be able to get it off. The bolt for the bracket on the lower plenum is stripped and since it's within the bracket assembly there isn't really any way to get purchase on it. I've tried using a rubber band inside the socket head but that didn't work. Is there a way around this or am I out of luck here?
  18. Apr 9, 2023 at 5:19 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Use a 6 point socket, if no work, use extractor socket.
  19. Apr 9, 2023 at 7:32 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Extractor sockets worth their weight in gold.
    TheloniusDrunk[QUOTED] and erice like this.
  20. Apr 10, 2023 at 6:57 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Are you using 12 or 6 point sockets?
