  1. Apr 18, 2023 at 10:36 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Congrats! Just wait, you're going to think you stepped into some kind of slingshot FORWARD time capsule before you know it. lol
    Captain Magma[QUOTED] likes this.
  2. Apr 18, 2023 at 10:55 PM
    erice
    erice Well-Known Member
    Eric
    San Diego
    Oh shit that's right you're gonna have one hell of a sexy rear end.
    I like the idea of the 1ton leafs. i think the 1/2 ton 4x4 ones are a 4 pack with an overload. i like more options for sure.
    Will that eliminator kit work on our stock axles? i can't recall what the diameter of our housing tubes are.
    EDIT: found they have a bunch of different sizes. nothing about the leaf spring width though.
  3. Apr 18, 2023 at 11:27 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Washed it on the way home from work and put the grill back on as the finishing touches to last weekends project of installing a timing belt and water pump kit with a 72°c thermostat and new green fan clutch. Also dropped the diff to installing a new oil pump and welded in a 10AN fitting on the oil pan.
    anyone want to guess how long I looked for these two 10mm bolts?
    det107, Jbend, Pscdouglas and 7 others like this.
  4. Apr 19, 2023 at 7:56 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    The listings for their Ubolt Eliminators call out for 2.5 wide leafs. Which should be right for 63s.
    erice[QUOTED] likes this.
  5. Apr 19, 2023 at 8:25 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Taco critter likes this.
  6. Apr 19, 2023 at 8:38 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The more I think about it. The more I like this idea. One less thing I have to cut out and weld (drain bung). And one less thing that can potentially drag or hang up. I could just use the lowest bolt as the drain plug. It would probably take a while to drain through there, but at least that's a 10mm bolt. More time to drink a beer while I wait for the oil to drain I guess.
    erice and cbechtold[QUOTED] like this.
  7. Apr 19, 2023 at 3:51 PM
    scofflaw
    scofflaw Well-Known Member
    I am sorry to bother everyone, but does anyone have any ideas for what to use to cover thinning paint on the top of the tailgate that is slowly being worn away by the seal from the camper shell rear door? It's down to the primer on both sides. Trying to think of something that will stick but that won't tear the paint off when removed--some sort of vinyl or rubber tape maybe that will protect the remaining paint in the couple of inches that are exposed to the camper shell rear window seal. Anyone else run into this problem?
  8. Apr 19, 2023 at 5:03 PM
    Area51Runner
    Odd. Haven't run into this issue before. Is that cap made for your truck? Either way, maybe add a THIN layer of foam or EPDM tape to the inside of the existing seal on the cap door? I say thin because if its too thick, doors will not latch properly. I'd affix it to the seal rather than the tailgate surface.
    This is merely an example but should give you an idea what I'm suggesting.
    https://www.amazon.com/XCEL-Weather-Stripping-Rubber-Adhesive/dp/B07KCJ31J9
    On second thought, maybe not that specific product but something similar.
    scofflaw[QUOTED] likes this.
  9. Apr 19, 2023 at 5:08 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Maybe hit up a vinyl wrap place. Maybe a 3m clear or white strip doubles up for thinkness or they have something more industrial strength… just a though
  10. Apr 19, 2023 at 5:46 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Changed out ITREs today.
    Can confirm cheap assed Proforged ITREs will take serious abuse for 4+ years.
    Area51Runner likes this.
  11. Apr 19, 2023 at 5:49 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    I got the ones on rock auto but from Amazon or ebay. Ebay I think. Fairchild is the co if I remember correctly. They are exactly like oem and makes door shut tight as fuck. I think it was $113 for all 4 frame seals. The big ones.
  12. Apr 19, 2023 at 5:51 PM
    Yota X
    NW New Jersey
    1st gen
    That thing is gonna be a whole diff truck with a turbo on it!! Japanese engines love turbos.
    jubei and Wulf like this.
  13. Apr 19, 2023 at 6:29 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    No-name Amazon tonneau cover to go with the carpet
    CS_AR, Yota X and chrslefty like this.
  14. Apr 19, 2023 at 8:27 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    What did that run?
  15. Apr 19, 2023 at 9:13 PM
    Mujtaballa
    Mujtaballa Well-Known Member
    Missouri
    2001 and 2004 Tacoma TRD off road 4x4
    Stock: Light bar!
    Added the icon expansion pack in the rear. Shop left the overload. It’s got a nice rake. You guys think it’s too much? I ordered new bilsteins to accommodate the roughly 2 inch lift gained. Front is only leveled. Thoughts?
    Yota X, DK117, CS_AR and 5 others like this.
  16. Apr 19, 2023 at 9:37 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    $155 + tax
  17. Apr 19, 2023 at 9:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    nice. Seem like a good one?
  18. Apr 19, 2023 at 10:01 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Ya, pretty good quality but I had to shim the anchors to get it tight
  19. Apr 20, 2023 at 6:24 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Took it for it's first alignment in like 6 years. Was going to do it when I installed the ADS shocks and Icon UCA's in 2020 but then we had vacation, and then a pandemic, and then a baby so it just kept dropping on the priority list. :rofl:
    I'll just paint pen it at this position now.
    jubei, Area51Runner and CS_AR like this.
  20. Apr 20, 2023 at 8:33 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I think it looks good. I like a bit of a rake so when you put stuff in the bed, it's less likely to sag.
