  1. Apr 28, 2023 at 7:59 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Boost and AFR gauges for his supercharger
  2. Apr 28, 2023 at 2:38 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    correct, supercharged
  3. Apr 28, 2023 at 2:38 PM
    Sebz13
    Shane
    Maui Hawaii
    Also have an ultra gauge to monitor temps and other odds and ends
    chrslefty likes this.
  4. Apr 28, 2023 at 5:46 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Been slowly making progress on my new bumper. Hope to finally wrap it up this weekend.
  5. Apr 28, 2023 at 7:00 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Yeah sure… I’ll grab the links in a day or 2 when I’m back home. Cb was from Amazon and radio from crutchfield. I did have to dremel the radio bezel trim piece a bit for the cb but only in the way back
  6. Apr 28, 2023 at 9:59 PM
    KoolKruizer
    KoolKruizer New Member
    2002 Toyota Tacoma (374,000 km)
    New frame/ Body parts
    Just received new parts today from Rock Auto. Regular maintenance upgrades. New Rack & Pinion with inner tie rods, Drilled Rotors with calipers,pads, Rear Drums with shoes, & adjusters,outer tie rods,lower ball joints,power steering pressure hose & return hose with filter, upper & lower Rad Hoses, Timing Belt & water Pump Kit, New left & right Valve Covers & Gaskets Radiator Cap & Thermostat ,2 New Front Door Lock Cylinders with keys, 2 front parking/turn signal lamps, Also received my 2 wheel cylinders ., 2 axle seals, 6 spark plugs with new wires from Toyota. 2 New transmission lines from Lines to Go . Going today to get my 3" Front & 2' Rear Lift Kit. Can"t wait to get everything installed next week. Love my 02 Tacoma
    det107 and Speedytech7 like this.
  7. Apr 29, 2023 at 9:14 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I installed some of those license plate bolt/light combos on my tailgate mounted plate to give the cops one less reason to pull me over. Would not do again, I would basically have the cut the wires off and rewire them if I ever wanted to change plates or if the lights fail.
    det107 likes this.
  8. Apr 29, 2023 at 9:47 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Door handle delete
  9. Apr 29, 2023 at 9:54 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah those things suck, and if you got the same chinese ones I got off ebay/Amazon then they will fail in short order.
    I got them just to get my trailer through license inspection, once they stop working they will not be replaced.
    slander[QUOTED] likes this.
  10. Apr 29, 2023 at 10:27 AM
    slander
    Hickory, NC
    Yea they are there to get me through the annual state "safety" inspection (joke).
  11. Apr 29, 2023 at 11:44 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Washington never had a full inspection, but they did have bi-annual emissions test. Thankfully they did away with that a couple years ago, and they just passed a law to de-prioritize getting pulled over for any non-moving violations, so you can pretty much do whatever you want now here.
  12. Apr 29, 2023 at 12:45 PM
    slander
    Hickory, NC
    IL where I used to live had emissions only. Now where I'm at in NC they have this bs annual safety inspection. Waste of time and $$$.
  13. Apr 29, 2023 at 2:15 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I remember that from when I was at Ft Bragg. Gotta get that revenue from poor people somehow right?
  14. Apr 29, 2023 at 8:56 PM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    Finally replaced my front seats. Corbeau Moab in tan.
  15. Apr 30, 2023 at 7:10 AM
    det107
    det107 Well-Known Member
    Is it the Fairchild KT2020; window scraper seal?
  16. Apr 30, 2023 at 12:05 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    @cbechtold @Robmonster117
    Did you get you Total Chaos LBJs from Total Chaos, or elsewhere? I see them on the TC page, just wanting to make sure there isn't somewhere else with a better price.
    Really wanted to do the Solo LBJs but I just think Bobby is making a real error making his LBJs only work with his spindles, and his spindles only work with his CV shafts. That makes it over 6K all at once (with steering upgrade) to make the shit work.
  17. Apr 30, 2023 at 2:59 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Correct, dont think anyone will be able to sell them cheaper. Maybe if TC has a holiday sale sometime toon :notsure:
  18. Apr 30, 2023 at 3:35 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    It's all good. I'll buy them from TC. Just didn't want to find out in a week someone else has them cheaper.
    I know Trail Gear, and All Pro a lot of times is cheaper if you don't buy direct from them.
  19. Apr 30, 2023 at 3:40 PM
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    Does anyone know if OEM steering racks always have toyota stamped on the side? My rack looks like an OE one but doesn't have that stamped into the casting. From what I've seen on Timmah's videos and other photos they typically have that?
    I've been chasing down steering issues and was wanting to swap out the rack guide for the newer version, but might just go ahead and order a new OE rack if this one is aftermarket.
    I ended up ordering the 333 fab steering rack clamp, hoping it will help a bit as well, since the rack was visibly pivoting around the center mount with the old clamp.
    Pyrifera, chrslefty and ztwatson like this.
  20. Apr 30, 2023 at 6:26 PM
    Trandoshan-Tickler
    Trandoshan-Tickler Well-Known Member
    Gene
    Fontana, CA
    2002 Toyota Tacoma Prerunner
    Just some cosmetic work today. First, I installed a neat battery holder (Thanks Coupe!)
    Next I worked on replacing the window trim on the passenger side. It was getting pretty bad.
    THEN I worked on finally replacing the old, plastic side window hinges that have been broken for years.
    The fit is tight but I have working side windows again.
