  1. May 4, 2023 at 7:26 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I had a catch can on my motor when it was NA and it surprisingly caught a fair amount
    Speedytech7[QUOTED] likes this.
  2. May 4, 2023 at 7:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    My 3RZ had a ton too now that I think about it. Might be something about both locations being close together on the head, the flow path isn't as defined through the crank case
  3. May 4, 2023 at 7:28 AM
    Wulf
    rock raisin
    No, unless you like the rumbles they're probably not worth the effort to install :p
  4. May 4, 2023 at 8:50 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    No, it's just a convenient source of "filtered" air and a place for vapors to go when the system is overwhelmed as opposed to out to the atmosphere.
    You could plug the connection at the intake tube and stick a little filter on the valve cover/hose and your engine would never know the difference and you wouldn't be the first to do it. The purpose of the PCV valve is to regulate (down) the volume of air drawn (by vacuum) thru the engine so as not to create issues associated with vacuum leaks.
    In terms of volume of air flow in the intake tube, the amount stolen by the PCV system is inconsequential.
  5. May 4, 2023 at 9:12 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yes, that happens when the "system" is overwhelmed by excessive blow by and/or periods of low vacuum such as low(er) RPM open throttle situations. Engine wear (rings), driving style, manifold pressure and fouled, restricted or sticking PCV valve or any combination will contribute to overwhelming the system.
    I have a pet theory that the 3.4 PCV system is "more easily" overwhelmed than it should be as indicated by the number of folks seeing wetness in that hose. It seems Toyota was aware of this because in later years they increased the diameter of "that tube" and added a metal "can" at the intake tube connection.
    m3bassman and turbodb[QUOTED] like this.
  6. May 4, 2023 at 5:44 PM
    Wulf
    rock raisin
    Replaced my factory rear speakers with a $30 set of Kenwood 6.5s and stuffed the ext cab cubby under the windows with nylon stuffing. Sound much improved over the way too tired factory speakers :bananadance:
    The front doors have some pretty old Alpines in them, they sound OK but for another $30 I think I might be due to replace them too.
    ireymon, jubei, chrslefty and 2 others like this.
  7. May 4, 2023 at 10:58 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    All this PCV talk made me feel like I was reading the Turbo BS thread
    GoJo likes this.
  8. May 5, 2023 at 9:19 AM
    Trandoshan-Tickler
    Trandoshan-Tickler Well-Known Member
    Gene
    Fontana, CA
    2002 Toyota Tacoma Prerunner
    Hmmm looks like I might be adding that to my Taco To-Do list.
  9. May 5, 2023 at 9:25 AM
    Wulf
    rock raisin
  10. May 5, 2023 at 9:26 AM
    1998 TACO24
    1998 TACO24 Well-Known Member
    Bud
    Wulf[QUOTED] likes this.
  11. May 5, 2023 at 9:29 AM
    Wulf
    rock raisin
    My sub quit a while ago and I need to sort that out to fill in the bottom end....But for $30 my expectations were met :bananadance:
    1998 TACO24[QUOTED] likes this.
  12. May 5, 2023 at 9:29 AM
    1998 TACO24
    Bud
    All of my T-Birds speakers were blown lol SOOOO much nicer now!
  13. May 5, 2023 at 9:30 AM
    Wulf
    rock raisin
    :worthless:
  14. May 5, 2023 at 9:32 AM
    1998 TACO24
    Bud
    BEHOLD! The Beater Bird! Hahaha!
    ireymon, Dmesser92, chrslefty and 4 others like this.
  15. May 5, 2023 at 9:38 AM
    Wulf
    rock raisin
    hell yeah, that's not what I'd consider a beater lol
    I'd wheel it :cool:
    Crash415 and 1998 TACO24[QUOTED] like this.
  16. May 5, 2023 at 9:46 AM
    1998 TACO24
    Bud
    Yeah, it's a nice ride. It splits DD duties with the Tacoma. It's got just over 100k miles and I'm still going through it fixing little things.
  17. May 5, 2023 at 11:21 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Did the new speakers require an adapter or they fit? My speakers sound like a something is ripped
  18. May 5, 2023 at 11:41 AM
    Wulf
    rock raisin
    I know there's a couple of different 1st gen speaker configs so I'm not sure about your year. I popped the grille off the speaker and measured the factory one to be 6.5" center to center across the mounting screws each way in an X before I ordered. The new 6.5s fit without any adapter or changes save for crimping a new spade connector on one of the connections with a broken wire
    Digiratus likes this.
  19. May 5, 2023 at 12:33 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  20. May 6, 2023 at 10:00 AM
    Lucky_Gargoyle
    Lucky_Gargoyle Well-Known Member
    96 DLX 2.7 4x4 5spd
    Toytec coil-overs, SPC upper, OME CS019 leafs w/ 5110 bilstein, LCE header
    P0420 code popped the other day. Last night I pulled the cat and o2 sensor. Soaked the cat in laundry detergent overnight. This morning it's all back together and running nice. To bad a stud on the O2 broke, otherwise an easy job.
