  1. May 8, 2023 at 6:19 AM
    Siege.
    Siege. Member
    Siege
    '97 Tacoma 3.4L V6 RWD Manual Transmission
    K&N cold air intake, Borla Catback exhaust, AirRaid throttle body spacer, lowered 2"
    Delighted she started up up first try after replacing so many things in the past 2 weeks. Next is brake job, might need new calipers and rotors, head and tail lights Rotors, and I really need someone to help me convince the wife that I should turbo charge my baby... for the fuel economy... right...?
  2. May 8, 2023 at 6:33 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Call it an engine driven air compressor, it's technically the truth. Compressed air is an excellent tool :D
  3. May 8, 2023 at 7:39 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Nope stock option. I should ask if I can get another drivers side one and see if it can work on the passenger side since I don't have the washer res.
    @cnote4l will that work possibly for those of us with relocated washer resevoirs?
    chrslefty[QUOTED] likes this.
  4. May 8, 2023 at 7:40 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Now I feel like an idiot for putting my ARB twin over there. I got the wrong compressor! :p
    treyus30 and Speedytech7[QUOTED] like this.
  5. May 8, 2023 at 7:46 AM
    3rztacoma01
    3rztacoma01 Member
    Tyler
    Richland WA
    2001 Supercharged 4 banger
    Carbon Fiber Hood Supercharger Lift Wheels/Tires Bumpers Front/Rear Winch On Board Air Custom Interior
    It’s a VIS Racing CF hood that I found on marketplace for $50. It was in rough shape to say the least but with new epoxy and clear oats on top, it’s coming back to life quite nicely!
  6. May 8, 2023 at 6:15 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I like the oil feed routing
    Much better than mine lol
    Speedytech7[QUOTED] likes this.
  7. May 8, 2023 at 6:40 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    You had Kwikvette make a mount for you, right? How'd that work out? I need to get my Viair 400P mounted and have been overthinking it.
    Sorry if you posted and I missed it. I took a hiatus from the LT thread.
  8. May 8, 2023 at 7:41 PM
    Speedytech7
    Thanks dude. I'm glad I spent the time to route it but embarrassed to say it took me 2hrs to figure out how to without hitting anything. Took me 30 mins the first time and then I found out it hit the oil filter and the alt. The second time it hits nothing but took time and a crowfoot wrench I didn't know I owned haha
  9. May 8, 2023 at 10:10 PM
    Lucky_Gargoyle
    Lucky_Gargoyle Well-Known Member
    96 DLX 2.7 4x4 5spd
    Toytec coil-overs, SPC upper, OME CS019 leafs w/ 5110 bilstein, LCE header
    truck runs better
  10. May 8, 2023 at 10:47 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Put 35's on it
    Gen1FTMFW, jubei, ireymon and 24 others like this.
  11. May 9, 2023 at 6:16 AM
    Wulf
    rock raisin
    Yeee I made a cardboard template and had him cut a mount out for me. I still need to do a bit of work and finish installing it because I didn't dimension everything quite right lol
  12. May 9, 2023 at 6:19 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    It's about time! Looks awesome! You'll enjoy the change once you get those balloons aired down.
    betterbuckleup[QUOTED] and Wulf like this.
  13. May 9, 2023 at 6:34 AM
    Speedytech7
    Nice! How'd the trimming go?
  14. May 9, 2023 at 7:28 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Dirty 5's ftw.
  15. May 9, 2023 at 9:12 AM
    betterbuckleup
    Ian
    Concord, CA
    Thanks! Yea can't wait to see how much of a difference they make offroad
    Haven't done any trimming so far. Just threw em on there. Thanks to the solo arms I'm able to drive around on them just fine. Still need to pull the coilovers and see where it hits at full bind.
    I flexed it out on a rock and still had no rubbing up front.
    :taco:
  16. May 9, 2023 at 9:16 AM
    Speedytech7
    That's really cool I'm impressed they fit in the back to be honest mine touched the bottom of the fender and the top of the arch when flexed out in the back
    Wulf likes this.
  17. May 9, 2023 at 9:20 AM
    betterbuckleup
    Ian
    Concord, CA
    The back won't take much more work for me. My axle isn't totally centered rn so it hits the rear lower corner of the fender, but with where I have my bumps set they won't even touch the bottom of the flare or fender completely stuffed.
    I'm sure your 63's help a lot with having your bump height a lot higher.
  18. May 9, 2023 at 9:21 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    cant remember if posted thsi or not...
    the other day it was being mentioned about the rear tailgate badges & who expensive they were, IF you could even fine them.
    well im a poor boy & this is a 20 yr old truck. so grabbed a set of paint pens that had chrome/silver as a color in them & said what the heck.
    it aint perfect cause my hands arent steady like they used to be, but it aint bad & is way better than it was. mine were pretty much all flaked off somewhere.tailgate letters.jpg
    ireymon, DenverMoto and Area51Runner like this.
  19. May 9, 2023 at 9:44 AM
    Speedytech7
    Oh I hadn't thought of that, yeah the off the shelf leafs generally aren't perfectly centered huh. I spent a shitload of time on that with mine. I was surprised just how close the 35s were to everything when I first tossed them on. I couldn't even turn enough to exit my garage when I tried, so you're way ahead there. One area you'll probably touch a lot more than me is underneath the fusebox/battery and underneath the airbox, I was all over that area even without being pushed forward an inch.
    Wulf likes this.
  20. May 9, 2023 at 9:47 AM
    betterbuckleup
    Ian
    Concord, CA
    Yea I anticipate that needing a lot of work.
    Might have to relocate the battery depending on how much I have to clearance there.
