  1. May 12, 2023 at 11:35 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Anytime you dump the exhaust under the vehicle and/or point at the ground you'll get a lot of drone and it'll be louder. Best to route the exhaust out from under the vehicle in any rearward direction.
    I had that same sort of setup as you before and found that to be the case. it got old. I then got the exhaust rerouted out the back over the leaf springs which helped a lot.
    But it was still too loud for me with an 18in magnaflow muffler and the 2.7. The supercharger definitely made the exhaust a good bit louder since it's pushing more exhaust through the system. Sounded good at idle, but too loud everywhere else. I have since added a large resonator and that's helped a lot. My current setup is the LCE header, magnaflow high flow cat, 18in magnaflow muffler, and an unknown brand resonator (not sure how long but it's big).
    moving the exit from out under the bed will make a big difference. It did for me. Almost as much as adding another muffler or resonator to the exhaust
  2. May 12, 2023 at 3:31 PM
    SpokeWench
    SpokeWench Well-Known Member
    Paula
    1998 Tacoma SR5 4x4, Super Pacific X1
    Mystic Purple Mica, Super Pacific X1 (bld 359)
    highly suspect about how this bushing tore.
    the missing half was no where to be found. I would have thought it would be on the skid plate. I put the skid plates on after dealer replaced rack.
    Anyway, ordered a temporary one that will get here ahead of the Total Chaos ones.
    Area51Runner likes this.
  3. May 13, 2023 at 7:15 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    That sucks. I figured they were the same as the ones I have. I have these https://www.amazon.com/gp/product/B07YQBM1Y4 I assume they are the ones you are talking about. They were in stock two years ago. Mine were not broken at the time, but I bought them anyway.
  4. May 13, 2023 at 8:08 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It won't matter what muffler you run with it piped the way you have it it's resonating off the ground and is close enough to the cab that is what is causing most the noise.
    If you pipe it out the back in whatever way you want but so it's not pointed straight down at the ground but actually exits outside the body a bit it'll make a big difference.
    betterbuckleup likes this.
  5. May 13, 2023 at 12:06 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Yep, those are the ones. They aren't the same as the previous posted.
  6. May 13, 2023 at 12:10 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    Just did a bimonthly Elocker test, and the dang actuator seems toast again lol. 2nd OEM one in 2 years.. guess I’ll be cleaning/rebuilding this thing this weekend :)
  7. May 13, 2023 at 12:11 PM
    Wulf
    rock raisin
    Have you seen the chillkat cable conversion? I'm gonna go with that if I have another Elocker wiring problem
    Speedytech7 likes this.
  8. May 13, 2023 at 1:27 PM
    YotaBro
    YotaBro Well-Known Member
    98 Tacoma
    Replaced the battery. It had died while I was on vacation for a couple months. Glad to be back with the taco!
  9. May 13, 2023 at 1:44 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    what color is that? I like it!
    YotaBro[QUOTED] likes this.
  10. May 13, 2023 at 1:48 PM
    YotaBro
    98 Tacoma
    Cool steel metallic, only offered in 98, but there's a similar color offered in 97 called lavender steel metallic
  11. May 13, 2023 at 2:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    And before that Pewter Pearl. All good colors
  12. May 13, 2023 at 3:13 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I dig the bed decals
  13. May 13, 2023 at 3:16 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Picked these up today for free. Guy said they came out of a 2013 Lexus. No rails but they’re in pretty damn good shape. Gonna restore them as best I can and hopefully get them fabricated onto my rails somehow. And if they don’t work out, oh well, they were free.
    Phessor, Tour991, 03_taco_IN and 2 others like this.
  14. May 13, 2023 at 3:33 PM
    Speedytech7
    You write like poorly.programed AI
    eon_blue likes this.
  15. May 13, 2023 at 3:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Really? Again?
    Tour991 and eon_blue like this.
  16. May 13, 2023 at 3:48 PM
    1grntaco
    1grntaco Well-Known Member
    Sean
    1995 rg cab 2.7 4x4
    Installed the no name 11 1/2" long " 4" diameter resonator...... I'm actually much happier.... much much happier. The tone is perfect off idle and does not have the harsh Crack under load. Is it loud? Yes. But it's way closer to the tone I wanted
  17. May 13, 2023 at 4:22 PM
    Siege.
    Siege. Member
    Siege
    '97 Tacoma 3.4L V6 RWD Manual Transmission
    K&N cold air intake, Borla Catback exhaust, AirRaid throttle body spacer, lowered 2"
    Had to learn how to wire the halos and running lights, but I think they look pretty good. Gotta take care of some minor body work and clean her up...
  18. May 13, 2023 at 5:55 PM
    Rhodes
    Edmonton
    01 Dbl Cab
    I have not. Googling that now though. My issues never seem to be wiring.. I do a lot of river crossings so I’m guessing that’s my issue…
  19. May 13, 2023 at 6:08 PM
    Wulf
    rock raisin
    Ahhh that definitely doesn't help lol. Their kit replaces the e locker motor with a lever to activate it manually by cable
  20. May 13, 2023 at 7:00 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    That was a big project, but new front end is looking rad.
