  1. May 16, 2023 at 9:53 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Nope... More like boulders too big :thumbsup:
    Wulf[QUOTED] likes this.
  2. May 16, 2023 at 10:07 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Although... For the record...
    Now that it's not the daily driver any more. Once I get done with the rear axle and finish the front (with the Solo spindles and hybrid RCVs) it will be getting upscaled from 35s to 37s.
    37s are as big as this truck will get (but of course, that's what I said about 35s) :anonymous:
  3. May 16, 2023 at 11:21 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    There's gonna be no more fender let alone fender flare left after clearancing for those suckers
  4. May 16, 2023 at 11:21 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Silas did it years ago, there was barely a bottom door hinge left
    betterbuckleup[QUOTED] and Wulf like this.
  5. May 16, 2023 at 11:43 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Has anyone cut the IFS cradle off and moved everything forward 2" yet
  6. May 16, 2023 at 11:47 AM
    betterbuckleup
    Ian
    Concord, CA
    Sounds like a headache. Just some of the things that would get in the way of that off the top my head: Steering column extension, longer fluid lines, possible diff interference with oil pan, etc.
  7. May 16, 2023 at 11:49 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The stock flares will be eliminated. I'm trying to come up with an idea where I can do a tube, bent in a way that looks good, that either goes back to attach to the frame in front and back of the tire, or attaches from the bumper to the slider. I've seen some ideas that have come from the exoskeleton book that may be able to be worked in. Not sure about that yet.
    I do not want fiberglass, because I think it looks stupid.
    I don't want to go without some sort of flare because dust and mud.
  8. May 16, 2023 at 12:05 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    The Brownshirt guys dropped off some new Icon 2.0 rear shocks, and an AllPro tailgate table. I have no clue why I ordered it, but I did.. lol. Gonna have some projects goin down over the may long.
  9. May 16, 2023 at 2:04 PM
    DethSpork
    DethSpork Well-Known Member
    2001 Tacoma TRD
    Pulled my skid plates to clean some mud collection and saw a vacuum hose disconnected on my transfer case. Not very obvious where it should be connecting, so time to hit the tech manuals!
  10. May 16, 2023 at 4:21 PM
    betterbuckleup
    Ian
    Concord, CA
    I'm with you there on wanting some sort of flare for the mud
  11. May 16, 2023 at 8:45 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    100%. I want to be able to sleep in my RTT.
    And jesus... with LT right now WITH the stock flares... it's already a bit of a mess.
  12. May 16, 2023 at 8:54 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I just committed to the LT and stock fenders for the same reason. Stock flares barely did anything so I guess I'll just live with my consequences of having over half my tire stick out past the fenders :rofl:
    BrownMike and betterbuckleup like this.
  13. May 16, 2023 at 8:56 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lmfao... If I come up with a flare situation that helps, you'll see it here.
    For the record lve been running 3.5 LT with 1.25 spacers... so I'm pretty far out there.
  14. May 16, 2023 at 8:56 PM
    cbechtold
    Cory
    Pleasanton, CA
    30x12x10
    glwood6 and Phessor[QUOTED] like this.
  15. May 16, 2023 at 9:02 PM
    cbechtold
    Cory
    Pleasanton, CA
    Oh damn. I'm running a 1/4 inch spacer to have my wheels clear my brake calipers, but that's it. I'd have to measure again, but last I checked I was at 82 inches in overall width from outside of the tires.
  16. May 16, 2023 at 9:08 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I've got a lot torn apart right now. I think I may ditch the 1.25 and get some 1/4s when I put it back together. What 1/4s are you running? Just parts store?
    My wheels are 4.75. I'm worried about the UCA but have been too lazy to properly check clearance.
  17. May 16, 2023 at 9:13 PM
    cbechtold
    Cory
    Pleasanton, CA
    Just some cheap aluminum Amazon ones. My trail readys are 4" backspacing and I still have a decent amount of room between the UCA and spindle .
  18. May 16, 2023 at 9:18 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Did you change your lug studs?
  19. May 16, 2023 at 9:25 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Initial thought on the @TOTAL CHAOS Lower ball joints.
    The alignment sleeves have too much powder coat on them for them to easily fit in to the spindle.
    A special socket needed to install them? (top of Ball Joint)
    I guess I can look past the boojie bolt for clearance purposes... but for a grand, I'd expect the sleeves to sit in the spindle correctly. (those are the biggest source of LBJ failure after all)
    Am I being picky? Maybe. But those are my initial thoughts.
    Area51Runner and BrownMike like this.
  20. May 16, 2023 at 9:26 PM
    betterbuckleup
    Ian
    Concord, CA
    Looks like you have to add raptor lights now that you're over 80in wide according to the DOT ;)
