  1. May 24, 2023 at 8:48 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Can't say I've seen 98-00 headlight retrofits like that before. What's the story on those?
  2. May 24, 2023 at 3:14 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Another Amerilite/Anzo recruit
  3. May 24, 2023 at 3:14 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Just saw those on Amazon an hour ago haha
  4. May 25, 2023 at 7:12 PM
    1997tacomav6
    Denver
    Got the E locker switch installed made by trail gear,
    You can lock the axle in 2 wheel drive, 4 High and 4 low and not limited to a specific speed, doesn't use the ecu to control the use of it and installed the diff lock switch in the new switch panel with a USB port and 4 other switches
  5. May 25, 2023 at 7:53 PM
    andywear
    andywear Active Member
    Tulsa, OK
    '99 TRD manual
    did my CV axles,
    I purchased the wrong ones from rock auto and only realized after I pulled the old ones out so to Orielies and advanced for 1 each. since both stores only carried one each.
    Noticed some wear on the inside of this hub but sent it anyway
    both sides slid out and in easy enough. I will do again. Mainly because both stores offer life time warrenty on those axles o_O:bananadance:
  6. May 25, 2023 at 8:01 PM
    andywear
    Tulsa, OK
    '99 TRD manual
    next was my stiff as all get out struts. I went the cheap way and got some used ones off FB marketplace.
    I kept the Fox racing, in hopes to rebuild and reinstall but.... they rode so ruff, I probably will not.
    to get my lift back up front I got cheap spacers from Amazon. and could not get the LCA to drop enough to get my bolt in, I thought I could squeeze it together and shorten it.
    It worked, only could manage to get one compressor on due to all the hardware down there but it still worked, yay
  7. May 26, 2023 at 4:45 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Double check they don't bind at full droop. Might not be a big deal for you if you only drive on pavement but it doesn't take much to snap one if it's bound up.
  8. May 26, 2023 at 5:37 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Been chasing some front engine noises the last few months on my 95 5VZFE. It was a high pitched noise that was worst on cold starts. Almost sounded like a belt slipping, but not quite the same. Replaced the fan bracket and that went away.
    Then I could hear another dry bearing type noise.
    Stethoscope said the idler pulley on the AC was really dry. Had a bit of a wobble so, so I ordered this one ($24) and kept driving it.
    AFTER I got the new pulley/bearing, I removed the old one. DOH!, it has a replaceable bearing.
    Public Service Announcement over.
    Darrell942 and erice like this.
  9. May 26, 2023 at 10:22 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Damn those fabtech/fox coil overs are old! My truck had a set on it when I bought to cab swap, built it instead, and it rode like shit!!! They were slightly different lengths with a cracked rubber spacer on the top. Didn’t even try to sell ‘em. Think buddy gave em away to a guy and told him “you can have em but use at your own risk and you didn’t get them here” lol. My truck rides way better now lol
    Wulf likes this.
  10. May 26, 2023 at 1:00 PM
    erice
    erice Well-Known Member
    Eric
    San Diego
    Got my ebay metal door handles earlier than expected.
    Feel solid. Good weight. As others noted they have a plastic housing and metal handle.
    Some dissimilarities between the left and right (aside from the obvious one is right one is left)
    One came nicked. But I dont really care. I'm sure someone else would be annoyed but I can always just paint over it.
    One had something removed from the back also. Rotory tool marks. Thought that was odd.
    Will have to get some side by side shots when I get the oem ones out.
    20230526_124148.jpg 20230526_124231.jpg 20230526_124341.jpg 20230526_124412.jpg 20230526_124419.jpg 20230526_124537.jpg 20230526_124603.jpg 20230526_124609.jpg 20230526_124636.jpg
  11. May 26, 2023 at 1:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Isn't that plastic what everyone is trying to get away from? Had a handle break on me on my old Tacoma and it was the plastic that gave out right behind the handle.
  12. May 26, 2023 at 1:23 PM
    Darrell942
    Darrell942 Active Member
    Darrell
    Byron Georgia
    2000 Toyota Tacoma Prerunner Extra Cab 4cyl 2.7 Ltr
    None, why mess with a good thing
    I started by tracking down a misc wire, then decided to remove the multi-cd unit that has not worked properly in years, so when someone says "What have you done with your Tacoma today....." all I can say is....
    GoJo likes this.
  13. May 26, 2023 at 1:30 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I just installed the passenger side one yesterday, same brand, it might be my
    OCD but the new handle sits a little crooked when installed. It dips towards the front of the taco. I might try bending the mounting tabs inside the door to straighten it out. Thinking about spraying them with bedliner too.
    Also I sprayed all the linkages with dry lube. Works like melted butter now.
    erice[QUOTED] likes this.
  14. May 26, 2023 at 2:04 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Drove her to work today… now I can’t idle with ac on, bad move :rofl:
    2C20CDA1-A031-413C-AC9C-A44840C79362.jpg F517B37E-0806-4661-B0B4-810E7DF489EF.jpg 49B51D5E-7156-4BDD-8E25-5BB3DFFC8206.jpg
  15. May 26, 2023 at 3:59 PM
    1grntaco
    1grntaco Well-Known Member
    Sean
    1995 rg cab 2.7 4x4
    Not sure what it is, but that front bumper is awesome. Super simple. Like it.
    DIRT YOTA[QUOTED] likes this.
  16. May 26, 2023 at 4:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The entire handle is metal. Including the part right behind the pull tab. Its the bucket that sits in the door that is plastic.
    erice likes this.
  17. May 26, 2023 at 5:17 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Starting the new audio system. Need a dremel unfortunately before I continue.
    erice, CrustyTaco and Wulf like this.
  18. May 26, 2023 at 5:38 PM
    betterbuckleup
    Ian
    Concord, CA
    well, better to figure that out on a drive to work rather than on the trail or in the desert where you'll really want it
  19. May 26, 2023 at 6:26 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Got mine today too...
    The install is now on "the list" :rofl:
  20. May 26, 2023 at 6:28 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Speaking of "the list"
    Currently working on it.
    erice likes this.
