  1. Aug 8, 2023 at 3:20 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Moving to AZ in a few months, easy fix :)
  2. Aug 8, 2023 at 6:00 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Believe it or not, it does rain here...monsoon season is fun.
  3. Aug 8, 2023 at 6:51 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I might have a spare. They sent me one for a 16.5 gallon tank instead of the 18 gal tank and it's just chilling on the parts shelf
  4. Aug 8, 2023 at 6:54 PM
    unstpible
    Derek
    Cedar City, Utah
    How about some DT Headers, I just took them off for the turbo. They have a leak on the drivers side ball flange but I might have figured out a fairly easy solution for it
  5. Aug 8, 2023 at 6:57 PM
    unstpible
    Derek
    Cedar City, Utah
    Installed the 4runner air duct and vent
    :woot:
    jubei, det107, Tour991 and 2 others like this.
  6. Aug 8, 2023 at 6:58 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The JBA headers are already Inboud otherwise I would have taken You up on that lol
    Sadly I’ve got the larger tank
    and I believe my tanks different due to the year
    unstpible[QUOTED] likes this.
  7. Aug 8, 2023 at 6:58 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    My wife hated that in my 4runners, you know, chapped lips.
  8. Aug 8, 2023 at 6:59 PM
    unstpible
    Derek
    Cedar City, Utah
    Damn lol
    Empty_Lord[QUOTED] likes this.
  9. Aug 9, 2023 at 4:39 PM
    unstpible
    Derek
    Cedar City, Utah
  10. Aug 9, 2023 at 9:11 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    What're you all getting for charging voltage on a 3RZ? I have a secondary battery installed with an ML-ACR system and I noticed it would keep shutting off because the charging voltage dips below 12.9v (lowest I've seen is 12.3v)- the highest I ever see the alternator charge (with the secondary battery isolated) is 13.2v
    Not sure if this is a sign of a failing alternator, or maybe it's just not strong enough to be charging two batteries at once.
  11. Aug 9, 2023 at 9:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you should be at 14.1-14.4v with the truck running. I'd say the regulator on the alt is going out or the brushes.
  12. Aug 9, 2023 at 9:38 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Gotcha. I'm reading this battery voltage off my Alpine radio head so I'll have to confirm with my multimeter on the alternator itself - but it didn't seem right when I was monitoring it. The ACR kept switching off so it's most likely a low voltage issue.
    It's the original 1998 Alt with 148k miles on it, so might be time to do the Suzuki alt I think everyone upgrades these with.
    unstpible likes this.
  13. Aug 9, 2023 at 9:54 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I think mine was around 13 before I installed the voltage boosting fuse thing. I charge at between 14.2 and 14.8 now. Still OEM alt. Single red top optima battery that's like 8 years old
  14. Aug 9, 2023 at 10:01 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I have a Northstar AGM that's like 4 years old and sometimes the truck will have trouble starting in the morning, I'm trying to figure out if it's an alternator charging issue or a parasitic draw.
  15. Aug 9, 2023 at 10:25 PM
    betterbuckleup
    Ian
    Concord, CA
    considering you have an AGM, I would recommend one of those fuses to up the charge voltage. those batteries need more juice otherwise I've found they slowly lose charge over time.
    You can also achieve the same thing by just swapping the fuse with a diode into that circuit, but some argue that you're losing safety with that
  16. Aug 9, 2023 at 11:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Do you have 2 Northstar AGMs?
    That is what I have. They are almost 8 years old now. I've found they benefit from a desulfation cycle now and then or something similar to what you are describing happens. I use one of these:
    https://www.amazon.com/gp/product/B006G14FK8?ie=UTF8&th=1
    I have found the batteries will accept a charge much much better after running the desulfating cycle.
  17. Aug 10, 2023 at 5:59 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    14.4v is typically the max I see. If you have an obd reader you should be able to check voltage from that also. Meter is best for sure. Haven't heard of the zuk alternator. Cs144 from a jaguar is what I've heard. I should probably upgrade to that also now that I'm powering an accessory waterpump.
  18. Aug 10, 2023 at 6:07 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    My CS144 charges at 14.1-14.3 most of the time, or 13.9 when loaded down with lights and fridge. Highly recommend it for the AGM setup, especially dual AGM's. Upgraded harness helps too. (IE Big 3 which is more like the Big 5)
  19. Aug 10, 2023 at 8:53 AM
    betterbuckleup
    Ian
    Concord, CA
    unfortunately can't use the CS alt for the 3rz.
  20. Aug 10, 2023 at 9:13 AM
    m3bassman
    Green truck
    X2, great little chargers. Only thing I wish it did better was it'll sometimes fault out in a battery but it doesn't tell you why. A fault code would be handy.
    Digiratus[QUOTED] likes this.
