  1. Nov 2, 2012 at 4:32 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    Finished up the Power Steering cooler today / new Pump install. I just have to paint the brackets, noticed the reservoir is now not "extremely" hot to the touch after some driving. Hopefully this will prevent the seals from failing "again".
  2. Nov 2, 2012 at 5:06 PM
    Madjik_Man
    Colorado Front Range
    Cleaned all the contacts on my master switch assembly (trying to roll the driver's side window up was hit or miss)
    Before:
    After:
    Also put back in my passenger side rear quarter panel. Only a tiny bit of touch up is needed around the square trim panel around the rear most seat belt. Sorry for the real shitty and faded picture... it looks great flat black:
  3. Nov 2, 2012 at 5:08 PM
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    photo16_5f19dc381d0103f3d47dcdb2e98dda019c3eba4b.jpg[/QUOTE]
    Looks good man.
  4. Nov 2, 2012 at 6:28 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Looks like it was well worth the small issues you've had. Great job!
  5. Nov 2, 2012 at 7:18 PM
    Madjik_Man
    Don't jinx me yet!
    I still haven't gotten the rear wall or passenger side panel on (I know I'm going to have to trim a lot around the holes the clips go through).
    I learned a little before I did the driver's side, so all that should go on easy-peasy.
    Thanks for the compliment though... I'm really digging it. Can't wait to get new carpet.
  6. Nov 2, 2012 at 7:23 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Notice how I left out "Good luck with all the issues to come" :devil::devil:
    JK
  7. Nov 3, 2012 at 12:02 PM
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    does this make the steering more responsive? i feel like im driving a boat
    is anyone elses steering pretty loose? i changed the rack bushings and got an alignment and its still pretty loose. on the highway i can turn my steering wheel about 3/4 of an inch in each direction without the truck moving turning. i also have the sway bar off but it shouldnt make that big of a difference, right?
  8. Nov 3, 2012 at 12:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You need to weld the steering shaft bushing solid. Will fix it
  9. Nov 3, 2012 at 12:16 PM
    white toy taco
    Albuquerque, NM
    yea that makes sense. have you done it?
  10. Nov 3, 2012 at 12:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I havn't. Jace did though.
    no your thinking of where the shaft goes into the steering rack. LT guys do that to keep it a bit more solid.
    The mod Jace did and that im talking about is inside the cab. There is a bushing that connects the shaft to the wheel. You weld that and a lot of the play goes away. Wish i had done it when i had it pulled apart. Not really wanting to take it apart again hahaha
  11. Nov 3, 2012 at 12:29 PM
    white toy taco
    Albuquerque, NM
  12. Nov 3, 2012 at 4:17 PM
    97TacoRunner
    97TacoRunner Member
    edmonton,AB
    1997 tacoma 4x4 prerunner project
    3 inch lift/ pace setter header/K&N cold air intake/soon to be updated exhaust/soon to be Long traveled
    well today i cleaned and oiled my KN air filter and bought some vht night shade lets just say tommorow i will have some blacked out lights
  13. Nov 3, 2012 at 5:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  14. Nov 3, 2012 at 6:05 PM
    Slodgetto
    Slodgetto Ăśber Posre
    Silas
    :eek:
    Story???
  15. Nov 3, 2012 at 6:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Off my friends '97. Were are not certain why if broke yet. It is an Eibach from a 1st gen SAW. I've read on ttora about these red Eibach breaking before. These have seen about 10 years of hard wheeling.
  16. Nov 3, 2012 at 6:33 PM
    Slodgetto
    Silas
    10 years is a lot! Interesting that it seems the red ones are more prone to break.... :notsure:
  17. Nov 3, 2012 at 6:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow mike. That's crazy.
    Guess what I'm doing :spy:
  18. Nov 3, 2012 at 6:39 PM
    Madjik_Man
    You facker.
    From the thumbnail in the forum index, I thought you were adding heating elements to the back of the mirror. :mad:
    Something I'm trying to do... just can figure out how to disassemble the mirror(s)
  19. Nov 3, 2012 at 6:45 PM
    04Tacomabuild
    04Tacomabuild Well-Known Member
    Reese
    Kenora, ON, Canada
    04 Tacoma TRD SR5 3.4l V6
    Toytec/Billistein coilovers, allpro leafs, OME greasable shackles, allpro ubolt flip kit, Billistein 5100's in rear.
  20. Nov 3, 2012 at 6:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I got them apart..but not without breaking the glass. Sadly the clips holding in the outer ring face inwards. Very tricky to get apart right. Ill have to get glass later.
