  1. Sep 7, 2023 at 3:13 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Well you know what they say. If it's leaking oil it has oil
  2. Sep 7, 2023 at 3:24 PM
    mrschulte
    mrschulte Well-Known Member
    Indiana
    95 v6 Ext Cab Tacoma Dlx
    Which master cylinder/brake booster plays nicer with the tundra brake upgrade? Earlier yrs or 01-04? I remember reading about the differences somewhere, but my search skills are failing me. Might have been @Blackdawg?
  3. Sep 7, 2023 at 5:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    01-04.
    The 13/16ths one with a single diaphragm booster.
    mrschulte[QUOTED] likes this.
  4. Sep 7, 2023 at 5:41 PM
    betterbuckleup
    Ian
    Concord, CA
    Mine works well and is a 00
  5. Sep 7, 2023 at 6:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm sure it works fine. Just not quite as hard if a pedal feel is all with the dual diaphragm booster. I've tried both.
  6. Sep 7, 2023 at 8:53 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I’ve hit 220 before, max I’ve seen was 238. 175 +/- 25 is operating temp(which is were I operate 99% of the time with the cooler I’m currently running). +/- 50 I’d say is fine as longs as it’s not happening a lot. I started changing my tranny fluid on 2 year interval.
  7. Sep 7, 2023 at 10:09 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    It’s just a little odd because I have a very large transmission cooler installed. That being said, it does cool down VERY quick not going uphill. That being said, I was completely unloaded. I had no weight or anything.
  8. Sep 7, 2023 at 10:17 PM
    Dan8906
    Daniel
    Concord, California
    I have found that trying to find an explanation isn’t always that easy, long pulls, ambient temps, air flow through your cooler etc is all variable. I wouldn’t be worried about it. Make sure your fluid isn’t low and change it if it’s been a while.
  9. Sep 8, 2023 at 4:10 AM
    betterbuckleup
    Ian
    Concord, CA
    Hm. Would be curious to compare to see what kind of difference there is. I've always thought it's had a pretty solid pedal feel in my truck.
  10. Sep 8, 2023 at 5:37 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Are you 4WD? If so just put it in 4-Lo and crawl about. That's what I've done in Atlanta and honestly I think Cali and Atlanta have very similar traffic and I've never had a problem
    BrownMike and SwampYota like this.
  11. Sep 8, 2023 at 5:43 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    have you checked the color of the transmission fluid?
  12. Sep 8, 2023 at 5:44 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    what welder is that?
  13. Sep 8, 2023 at 6:34 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
  14. Sep 8, 2023 at 6:39 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    :thumbsup::thumbsup:
    ok thanks
  15. Sep 8, 2023 at 7:43 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Never thought of that haha.
    BYJOSHCOOK[QUOTED] likes this.
  16. Sep 8, 2023 at 7:43 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I’ll have to check it soon, I’ve been putting off replacing it. What fluid do y’all run?
  17. Sep 8, 2023 at 7:59 AM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I use Toyota type 4, I get it for $7 a quart at the local stealership. Gonna do a drain & refill today after a long road trip this past weekend
  18. Sep 8, 2023 at 8:44 AM
    betterbuckleup
    Ian
    Concord, CA
    I used to do that, but problem is then having to come to a stop and shift out of 4lo when traffic speeds up.
  19. Sep 8, 2023 at 8:45 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Only have to stop to go into 4low... just push clutch in an yank out of 4low while moving.
    BrownMike, Reh5108 and BYJOSHCOOK like this.
  20. Sep 8, 2023 at 9:17 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I've seen over 260 I believe and I have a HUUUUGE Hayden, I'm talking like a 679.
    Oddly what I've seen is temperature spiking even faster when engine breaking a lot going down hill. Maybe I have something wrong in the trans.
    I want to try a trick my AutoX buddy swears by, and that is to not have the trans cooler mounted on brackets with lots of free space front and back, but to use the radiator tie straps most kits come with and actually sandwich the cooler onto the radiator. Seems that makes air actually go THROUGH the cooler rather than around it, as it leverages the OEM design of high/low pressures front/rear of the radiator. After reading about F1 development and how they setup their coolers to not have air go around but actually through coolers (think of the dead air in front of your tailgate while going down the freeway) it stands to reason. Could likely get lots more 'umph' out of our coolers by installing it the way I initially scoffed at haha.
    betterbuckleup and m3bassman like this.
