  1. Sep 8, 2023 at 8:45 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Only have to stop to go into 4low... just push clutch in an yank out of 4low while moving.
    BrownMike, Reh5108 and BYJOSHCOOK like this.
  2. Sep 8, 2023 at 9:17 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I've seen over 260 I believe and I have a HUUUUGE Hayden, I'm talking like a 679.
    Oddly what I've seen is temperature spiking even faster when engine breaking a lot going down hill. Maybe I have something wrong in the trans.
    I want to try a trick my AutoX buddy swears by, and that is to not have the trans cooler mounted on brackets with lots of free space front and back, but to use the radiator tie straps most kits come with and actually sandwich the cooler onto the radiator. Seems that makes air actually go THROUGH the cooler rather than around it, as it leverages the OEM design of high/low pressures front/rear of the radiator. After reading about F1 development and how they setup their coolers to not have air go around but actually through coolers (think of the dead air in front of your tailgate while going down the freeway) it stands to reason. Could likely get lots more 'umph' out of our coolers by installing it the way I initially scoffed at haha.
    betterbuckleup and m3bassman like this.
  3. Sep 8, 2023 at 9:18 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    oh hm didn't know that. I was under the impression you should be stopped to shift int AND out of 4low
  4. Sep 8, 2023 at 10:23 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I could get all the way until about 30mph in 4-lo 5th gear before I had to take it out. But Zane is correct per usual, just push the clutch in and then throw it back it 2-hi
  5. Sep 8, 2023 at 2:51 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I've always been afraid to do this too. And I got 2 low so I end up crawling in 2 in traffic.
    betterbuckleup likes this.
  6. Sep 8, 2023 at 5:36 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The 1998s exhaust showed up. Well part of it $450 TRD headers might be road worthy again soon
  7. Sep 8, 2023 at 6:31 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    You’ll need these donut gaskets where the collectors meet the crossover pipe.
  8. Sep 8, 2023 at 6:55 PM
    Empty_Lord
    Dan
    yup, got one coming tomorrow. time allowing i'll be tossing them on tomorrow night. but we'll see
  9. Sep 8, 2023 at 8:53 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    With a manual sure. But with an auto? Think you'd be okay but you need to consciously put it in neutral first.
    That's an interesting idea.
  10. Sep 8, 2023 at 9:26 PM
    betterbuckleup
    Ian
    Concord, CA
    That's some sound ass logic.
    My power steering staying pretty fresh, I think thanks for that mageline cooler tied up to the factory cooler.
    Do most people mount them with space like that? Between the rad and cooler?
  11. Sep 8, 2023 at 9:35 PM
    Speedytech7
    I mounted my intercooler heat exchanger right up on the AC condenser because that's the closest it could get and you can feel even at idle a nice breeze being pulled through it by the engine fan. Keeps my intake air temperature low even when just idling
  12. Sep 8, 2023 at 10:17 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    As someone who’s been to both ATL and LA this year - LA still has them beat but it ain’t by much. With the CA exodus and the southern invasion, I wouldn’t be surprised if Atlanta surpasses Los Angeles for tip top of the garbage heaps soon.
    BYJOSHCOOK[QUOTED] likes this.
  13. Sep 9, 2023 at 12:05 AM
    BlackSportD
    Los Angeles
    Most setups I've seen here guys whip up custom brackets and have pretty big gaps.
    I don't know if the autox scene had the sandwich style being very common but i respect my buddies tribal knowledge on it
  14. Sep 10, 2023 at 8:17 AM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    I put my fourth set of Michelin Defenders on the 99 this last week. Love that tire!New tires.jpg
    SwampYota, Canadian Caber and Wulf like this.
  15. Sep 10, 2023 at 11:45 AM
    YotaBro
    YotaBro Well-Known Member
    98 Tacoma
    BYJOSHCOOK, Phessor, ztwatson and 3 others like this.
  16. Sep 10, 2023 at 12:19 PM
    Michael05
    Michael05 Not-Known Member
    2003 Prerunner
    Driver Skill Mod
    New Led cluster lights. I prefer this so much more than that ugly orange.
  17. Sep 10, 2023 at 3:01 PM
    Rhodes
    Rhodes Well-Known Member
    Edmonton
    01 Dbl Cab
    Dealing with some serious drivers side floor rust… I thought I sealed the leak in the firewall but the proof is here.. luckily the cab mount is solid. Just gonna have to put a bigass plate in there..
    Question. What would the best route be for treating the underside of this? The plate will mostly be accessible to paint/coat. But by the frame might be tough. Would a couple coats of a weld thru primer be sufficient?
  18. Sep 10, 2023 at 3:03 PM
    Rhodes
    Edmonton
    01 Dbl Cab
    Love the led’s. been on my todo list for some time now. How long did it take for you?
    Michael05[QUOTED] likes this.
  19. Sep 10, 2023 at 3:29 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Do they dim nicely? I'm guessing all 74 style bulbs?
  20. Sep 10, 2023 at 4:20 PM
    Michael05
    2003 Prerunner
    Driver Skill Mod
    Honestly not bad at all. Did it all in around an hour.
    They dim relatively well until about the last 10% were they drop below the minimum voltage. But no they’re all 194 bulbs from superbrightleds. All in all cost me like 20 bucks and was totally worth it.
    Also I went with the natural white. I didn’t want the heartless cold white or the warm white which would look like the orange it was originally. Natural white for the win.
