  1. Oct 5, 2023 at 10:49 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    That's a great response
    I just sent the email and included a picture of the very first failure that happened 3 days after the install
  2. Oct 6, 2023 at 5:18 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    damn that’s crazy, def sounds like a production defect in that scenario
    unstpible[QUOTED] likes this.
  3. Oct 6, 2023 at 5:27 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Looks good, and be Glad you have one to clean up and work on your truck in. I do most of my work in the drive way, and that sucks big time.
  4. Oct 6, 2023 at 5:34 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Wow, you must have "Deep" pockets and a hell of a lot of free time :), to work on all these trucks. How do you decide which one to drive on any given day. That decision alone would drive me nuts. But my hats off to you for keeping them out of the car crusher and the junk yards. One is enough for me, I'll spend my extra money on guns and reloading supplies.
  5. Oct 6, 2023 at 8:02 AM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    That's a great question. I would imagine yes. Looks like it may be slightly inconvenient. I'll lyk when I get back to town and check lol
    Not enough time served with it at this time to confidently say. I will say that the picture quality is incredible/day and night. Switching between the two cameras is also easy and convenient (but I just leave it on the rearview as my cap is not transparent. It's all a kit from wolfbox. Chinesium stuff, I'll update you later as per quality and how it holds up.
    The 6 bay switch bank was a wild nightmare of a project. Totally worth it. I need to redo it a with a new plate as i botched the job at the end, and was fed up with doing the work.
    So I bought a 6switch plate/ switches off of Amazon, used a micrometer to spec it out and 3D printed one with a .25" Thickness on the body (important for backspacing) and then I printed a back plate same dimensions, just big open hole, still .25" thick. I piloted holes through the back plate. cut out the headliner only enough for the switches and sandwiched the head liner between the two plates with some screws to assemble. after that it was wiring HELL to get all 6 switches plumbed up to the panel. If I did it again I'd do a little thicker .3 or .4" on the face plate.
    Michael05 and 1blink[QUOTED] like this.
  6. Oct 6, 2023 at 9:49 AM
    BroTaco8008
    BroTaco8008 Well-Known Member
    01 TRD sport
    Snagged a pic when the sun was getting low after cleaning all my tools finally out of it7B3C3FC7-DFC5-4391-9804-D3B4FBA21741.jpg
  7. Oct 6, 2023 at 4:43 PM
    vtroot
    vtroot Mistakes Were Made
    Eric
    Bay Village, OH
    1995 Toyota Tacoma 4x4 2.7 Manual Standard Cab
    New bilsteins, new tires, new air cleaner, new oil.
    Truck sits ridiculously high now... might have to look into an AAL or new leaf packs.
    Drove it around a little. The springs might still settle a little, but I did some measurements from fender flare to tire:
    Passenger Front - 9 1/8"
    Driver Front - 8 1/2"
    Passenger Rear - 7"
    Driver Rear - 6 1/4"
    m3bassman and SwampYota like this.
  8. Oct 7, 2023 at 2:39 PM
    Svridge
    Svridge Well-Known Member
    Ventura, California
    '99 Tacoma Extended Cab, 3.4l Pre-Runner
    Can anyone confirm that this blue wire under the driver door sill is the power wire for the fuel pump? I want to splice in a kill switch but I want to be absolutely sure this is the right wire before cutting anything
  9. Oct 7, 2023 at 2:50 PM
    ChrisL72
    ChrisL72 Well-Known Member
    Westchester, NY
    95 v6, manual extra cab TRD
    None
  10. Oct 7, 2023 at 8:00 PM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
    Thanks, looking forward to an update when you have one.
    I have access to a 3D printer at the local library on Estes Park. Need to take their tutorial class before I can use it. This may be one of my first projects. I'm hoping the outer spacing plate could go thick enough to make room for switchbacks to fit behind without looking silly.
  11. Oct 7, 2023 at 8:04 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Resized_Resized_20231007_111403(1).jpg Resized_Resized_20231007_131251.jpg Resized_Resized_20231007_151115.jpg
    Fun times :sawzall::welder:
    det107, vtroot and unstpible like this.
  12. Oct 7, 2023 at 9:49 PM
    unstpible
    Derek
    Cedar City, Utah
    I feel like removing the sway bar after the lift made a lot of that "Taco lean" go away. I'm hoping it stays that with endend links
    vtroot[QUOTED] likes this.
  13. Oct 8, 2023 at 7:38 AM
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    While waiting for my sway bar poly bushings to arrive, I drove up I35 for a 25 mile trip each way without the front sway bar connected and it was not an inspiring front end feeling at the highway speeds and dips in the highway.
    I was very glad to get the bushings and the sway bar reconnected.
    unstpible and ztwatson like this.
  14. Oct 8, 2023 at 9:22 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    These trucks can give unnerving body roll even with the sway bar connected. Can’t imagine it without.
    semco-inc[QUOTED] likes this.
  15. Oct 8, 2023 at 9:29 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I buy cheap, and other than the 98 and 01, I assemble them cheap. I had the 2021 taco frame… leftover from an insurance job because of slightly bent arm mounts that’s already fixed
    parts hunting is just a thing which makes things take longer. But it makes it affordable
    unstpible likes this.
  16. Oct 8, 2023 at 12:58 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @Empty_Lord You know I'm just pushing your buttons, correct!!! you know how it is on TW.
  17. Oct 8, 2023 at 1:02 PM
    Empty_Lord
    Dan
    Oh lol, I know I’m not being defensive lol
  18. Oct 8, 2023 at 2:49 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Installed my new upper ball joints today. Odometer was 150038. I noticed the boot was leaking grease the other day when it was up on a lift, while we were greasing the drive shaft. So glad to have this behind me before winter get's here. Looks like a front brake job is next. Maybe start on it come Tuesday or Wednesday. My back and hands will have to rest up a couple of days. So Glad I have a neighbor willing to do the heavy lifting for me. He did 90% of the work, I just lend a hand and grab tools when needed. I honestly think the hardest part of this job is getting the boots on, what a pain.
    vtroot, taco terror and m3bassman like this.
  19. Oct 8, 2023 at 4:24 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    I had 9 years on my original KO's, and figured they were getting too old for me to feel safe riding on.
    So fresh new KO2's as of yesterday, and I went white letters out this time!
  20. Oct 8, 2023 at 7:55 PM
    Empty_Lord
    Dan
    used the 98 for hauling shit today. father was also hauling shit.. so another group photo but with 4 this time! (i aint doing much right now to the first gens.. i have to get the 2nd gen done now)
    zlakin, SwampYota, CrustyTaco and 2 others like this.
