  1. Oct 18, 2023 at 9:05 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    bypasses make it more complicated but not impossible. But you can end up chasing your tail with them. Best way to tune those is to close all the tubes and get the valving in a good place, then start opening tubes.
    That and you want the bypass doing most the work not the coilover(for the front).
  2. Oct 18, 2023 at 9:07 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you sure it's not just your bushings? the OEM ones are jello. TC makes the best steering rack bushings.
    and then theres the steering wheel joint mod, that helps a lot.
  3. Oct 18, 2023 at 10:22 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Mine looked exactly the same in box.
    Haven't been able to check play yet, but I think it IS in the gear/rack.
  4. Oct 18, 2023 at 10:23 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    in the last 2 weeks I've done everything.
    even went to a poly rag joint which is a bit stiffer.
  5. Oct 18, 2023 at 10:24 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Got a part number for the rag joint, that sounds like it would be nice to replace
  6. Oct 18, 2023 at 10:26 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    link
  7. Oct 18, 2023 at 10:32 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Did you get ES steering rack bushings? Because IMO those things are worthless. Super soft. The TC ones are much better.
    That said, a quick thing to try is to just tighten up the guide, could be loose.
    Reh5108 likes this.
  8. Oct 18, 2023 at 10:35 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    its the "stiffer" ES bushing, but no the play is not from the bushing flex.
    the "red" compound ES bushing is a stock equivalent durometer
    and yeah I tightened up the rack guide more than recommended, and it helped but did not resolve, which I found very concerning.... but now I know its a rebuilt rack not new, so there may have been an issue from "the factory"
  9. Oct 18, 2023 at 11:02 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    and checking back thru my order history, they have both red and black offerings of the "60A" part and the "80A" part at energy suspension, I couldn't quickly find the TC durometer, but whiteline lists there offering as "85A"
  10. Oct 18, 2023 at 11:03 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    the "60A" ES poly bushing is about the same or softer as OEM, and thus not really an upgrade as you say.
  11. Oct 18, 2023 at 11:41 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah not sure what the TC ones are. But they are damn stiff. Which I like.
  12. Oct 18, 2023 at 3:36 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Got dem Hellas
  13. Oct 18, 2023 at 4:58 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Huh? Every rack I’ve gotten was brand new. The remans have different part numbers
  14. Oct 18, 2023 at 4:59 PM
    Empty_Lord
    Dan
    The one I bought last November was brand new.
  15. Oct 18, 2023 at 5:06 PM
    Speedytech7
    Can you still get em, I only see the one part avail
  16. Oct 18, 2023 at 5:07 PM
    Empty_Lord
    Dan
    Anything -84 is reman. Without -84 at the end of the number is new.
  17. Oct 18, 2023 at 5:12 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I'm hearing "they're all rebuilds" from several master techs and spare parts suppliers.
    I didn't believe it either, but can't explain my rack
  18. Oct 18, 2023 at 5:19 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    mine for sure was without the -84
    44250-35042
  19. Oct 18, 2023 at 6:17 PM
    Svridge
    Svridge Well-Known Member
    Ventura, California
    '99 Tacoma Extended Cab, 3.4l Pre-Runner
    Anybody know how do disable the "key in ignition, door open" chime without also disabling the "headlights on, door open" alarm? I was just going to bypass the door sensor but I don't want to lose the headlight alarm
  20. Oct 18, 2023 at 8:05 PM
    Empty_Lord
    Dan
    [​IMG] Did it look like this? All the factory reman racks are covered in that god awful grey paint. New looks nice and shiny
