  1. Oct 24, 2023 at 6:36 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What's the advantage of the T center? Wouldn't you be running on the coast side of the gears if it was in the front?
  2. Oct 24, 2023 at 6:43 AM
    02hilux
    Planet: EARTH
    The ability to swap third member on the trail, nearly centered pinion, and the tapered 36s it use. Will be sick to get a matching rear t10.5 too. But nothing is in the work as the 9.5 is sturdy strong for what I do.
    Speedytech7[QUOTED] likes this.
  3. Oct 24, 2023 at 7:40 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Custom housing is going to cost relatively the same whether you go 9 inch or 9.5.
    It would have been, pretty much the same price to set up a Ruff Stuff 9 inch housing. Everything would have basically been the same (spindles, hubs, seals, Drotor backer, brakes, flanges etc). It just would have been on a 9 inch housing instead of a 9.5 housing (but the 9 and 9.5 housings are the same price)
    I'm not even sure you could get a 9 inch axle or 3rd member cheaper than a 9.5. Because the 9 inch is more known and desirable in the Jeep offroad builds.
    The advantages on the 9 are there are more of them, might make them easier to find. The 9 inch is easier to put a pinion guard on. Might be a little smaller for better clearance, and lighter (but I doubt that difference is actually enough to make a difference).
    The disadvantage... and the reason I decided to go with a LC 9.5 is, they don't make a Eaton/Harrop for 9 inch.
    The only selectable locker option for a 9 inch (that I could find) was an ARB... I'm not putting that trash in my truck.
  4. Oct 24, 2023 at 8:27 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Look at yotashop.com
    That being said I made a mistake when replacing my head gaskets and had no other option but to replace them again with Felpro head gaskets. Almost a year in and so far so good. This is my dd too.
    ShiftyShank likes this.
  5. Oct 24, 2023 at 8:28 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Looks like I'm going the 9.5 route too cause I agree, too many ARB failures in the rear.
  6. Oct 24, 2023 at 8:38 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    It's gotten to the point (and I hate to admit it, but it's true) that when I'm on the trail with people and they start having trouble with their ARB lockers, it kind of annoys me.
    I, literally, have never met anyone in person that has ARBs that hasn't had problems with the locker themselves, or all the bullshit associated with them. (air lines, compressor, wiring, etc) there is WAY to much to go wrong with them. ALONG WITH the quality of ARB in general seems to be going down to a degree , to make it even worse... 0% chance I'll ever run an ARB locker.
  7. Oct 24, 2023 at 10:40 AM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    I'm 2 years in on a felpro kit and also have no problems
    Logans2001[QUOTED] likes this.
  8. Oct 24, 2023 at 5:35 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Sure it's not the airbag control module? Mine went out
  9. Oct 24, 2023 at 8:37 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    To give you an idea of the Ford 9" I'm planning on building for my truck. Parts alone, it's roughly 5600 before tax going with a 609 axle. I'd be going with a Diamond Axle, Solid Axle Dana 60 outers, RCV axle shafts, and a full Yukon/Strange 3rd member. I plan on building everything myself to save money where I can. With all the miscellanous stuff and tax and shipping, it's probably closer to 6500 when all is said and done.
    jubei likes this.
  10. Oct 25, 2023 at 5:16 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Thankfully my front seems to be good so far but I do wish I went Harrop when I did it. Was saving up for a trip to Moab simultaneously and had to cut corners. But I agree I also am at that point. We did a run 2 years ago where almost EVERYONE'S lockers were leaking and either not engaging at all or engaging when it felt like it. Half the guys needed to winch way more than they needed because of it. What annoyed me more is it was all known issues to the guys but they didn't bother to fix it before the trip.
    :spending: Alright well looks like my road to 37's will take me a lot longer than I expect especially with the Ferd I am paying off in the driveway. Think I'll just buy a new set of 35's, install the NWF box that's collecting dust and run it like that for now.
    cbechtold[QUOTED], Bandido and jubei like this.
  11. Oct 25, 2023 at 6:45 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    You have a g1 sequoia axle in there now, right? Just committing to making sure its not the weak link?
  12. Oct 25, 2023 at 7:38 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ya, I get what you're saying about things taking longer than you want. I've had the 63 swap kit and leaf springs sitting in the garage for 2 years now lol... finally getting them in. I got most of the axle housing pieces on Black Friday last year.
    Now that I'm pulling the old stuff out I'm hoping I can clean it up and get some sort of return to put back in to some of what I need to complete this project. (To at least dull the blow on the rest of the shit I need to buy).
  13. Oct 25, 2023 at 8:42 AM
    cbechtold
    Cory
    Pleasanton, CA
    Yep. That's my thought process with linking my truck right now. I might as well just wait and do it right later compared to do it this winter and rush it before King of the Hammers. Also turning into possibly a bad thing since I'm considering bypasses as well now haha
    Yep. One less thing to worry about when I'm romping on this thing when it comes to making it home. It's also on less thing for me to part together if I ever decide to SAS later down the road. 37s would also be fun on IFS, but I'd need to retire the truck from daily driver duties first and fix a few week points as well on the truck with the front end. Mainly the stock steering setup and the intermediate shaft on the diff. Once that's done, maybe RCV axle shafts up front, but that's awhile from now.
    betterbuckleup likes this.
  14. Oct 25, 2023 at 8:45 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I guess everyone's installing axles this month
  15. Oct 25, 2023 at 8:48 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Nice! :thumbsup:
  16. Oct 25, 2023 at 9:28 AM
    AssQuake
    AssQuake Unknown Member
    A.J.
    Washington
    4runner
    Made in Japan
    Weird, me too but with my 4Runner. Nothing as fancy as you all but i keep it clean! haha
    ztwatson, treyus30, SwampYota and 4 others like this.
  17. Oct 25, 2023 at 9:32 AM
    ShiftyShank
    ShiftyShank Oof
    Pat
    Northern Colorado
    02' BestGen 5VZFET
    :eek::thumbsup:
    AssQuake[QUOTED] likes this.
  18. Oct 25, 2023 at 10:23 AM
    betterbuckleup
    Ian
    Concord, CA
    Minty fresh
  19. Oct 25, 2023 at 10:39 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Fortunately my truck is retired from the daily drive life. My plan is to have the rear axle done and be on 37s by King of Hammers.
    I'm hoping to also have the fully fabbed spindles and RCV CVs by Hammers, but it wont be a deal breaker if I don't get there. That's going to depend on how good or bad my bonus is this year.
    cbechtold[QUOTED] likes this.
  20. Oct 25, 2023 at 11:03 AM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Moved my oil catch can closer to the air filter to see of it helps with the smell a little.
    ordered a set of Perry Parts bump stops to replace the Durobumps since they never responded to my customer service email
    Hopefully they arrive before veterans day so and I can consider it a Birthday present for the Marines birthday celebration
    I also ordered some Planted seat brackets...
