  1. Jan 3, 2024 at 10:50 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
  2. Jan 3, 2024 at 11:39 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Or is the sum of it's parts better than the original? haha That's what I told myself. Mostly was true, in the right circumstances.
    and that's literally what I did was go back to my build :laugh:
  3. Jan 3, 2024 at 11:41 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Speaking of "its parts" I'm surprised you needing a wheel bearing hasn't cost Frank one of his spindles haha
    m3bassman likes this.
  4. Jan 3, 2024 at 11:56 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah you'd think that would be the way to go. However, Igor has spindle gussets and Frank's are still naked for now. So I'd like to keep the gusseted spindle. Otherwise yeah it's just still over in the garage haha
  5. Jan 3, 2024 at 12:21 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I mean the Bronco I am def going to try to keep as the pretty one, but I already got some tube to make some legit sliders on it. I want to take it into some technical rocky stuff to learn it's wheel base and limits.
    On the bright side, from far away and good photo editing the shitbox looks aight. :p
    It's all the little rust spots I see when I get close that really nag me.
    [​IMG]Untitled by Michael Halat, on Flickr
    jubei, nbscooters and BYJOSHCOOK like this.
  6. Jan 3, 2024 at 1:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If this isn't ironic...I don't know what is.
  7. Jan 3, 2024 at 7:52 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ha I'm not going to buy a truck with 35's and lockers and not use it :p besides I need to learn it's limits so if I take the family wheeling in Moab or CO I'll be able to more confidently choose my line.
  8. Jan 4, 2024 at 5:18 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Finding the limits of the cam phasers is more likely?
    JK I actually think the Bronco is super neat.
  9. Jan 4, 2024 at 7:00 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Oof. I think the bronco turned out to be really cool and a nice medium ground for street comfort and off-road capability. In many ways they followed the footsteps of first gen Tacomas in that regard, IFS, rear locker and not trying to copy the Jeeps. I just wish they were like 5-10% smaller.
    And as devils advocate we are over her exploring the limits of our lower ball joints and rusty frames lol
  10. Jan 4, 2024 at 7:06 AM
    Speedytech7
    And they can explore their waterpump bearings/seals and tie rods too. Cam phasers will fail no doubt about it on a Ford, but who cares that's normal ford ownership and they're a couple hundo to repair. But when that ecoboost water pump dumps coolant into the oil, that's a bad day. If it's the 4 banger though, no problem there.
  11. Jan 4, 2024 at 11:25 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    They can be if you get the 2 door. It's funny you say that they aren't trying to copy jeeps because so much is similar that it basically feels like an IFS jeep. There is so many similarities in the tops/cage/interior layout. But I agree I think they nailed the best you can get for offroad capability from the factory.
    Thankfully my Wildtrak's got Braptor tie rods. I'm going to ignore the engine stuff you mentioned :lalala:
    Spent most of my morning researching what's needed to to install a hidden winch. Lot's of shit in the way with the intercooler and oil cooler.
    Truck stuff:
    Speedytech7[QUOTED] likes this.
  12. Jan 4, 2024 at 6:19 PM
    wnckeith
    wnckeith Member
    Installed a Marketplace find... New in Box Softtopper on the single cab!
  13. Jan 4, 2024 at 6:24 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Just a couple rust spots… :bananadead:
  14. Jan 4, 2024 at 6:27 PM
    Speedytech7
    Do you think it's all from your feet or did it get trapped behind your sealer somehow?
  15. Jan 4, 2024 at 6:33 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I think that peeled back piece of metal is a potentially a piece that was never sealed too well and it came in that way. That was a welded piece that peeled right off.
  16. Jan 4, 2024 at 7:39 PM
    Double Deuce
    Double Deuce Well-Known Member
    JJ
    Sioux Falls South Dakota
    Double Cab 02 TRD
    Decided it was time for another refresh and knocked out all of the below over Christmas PTO:
    • CV axle reboot kit on one side that had a tear (had one oem kit on shelf as backup-thank god as the new kits I ordered in September are STILL on back order) Can never have too many.
    • replaced side mirrors (went from chrome to black since I hate chrome)
    • replaced all exterior window trim as it was looking old and worn
    • new lower ball joints (upper ball joints were replaced last year along with tie rods)
    • removed overload leaf from OME kit to eliminate the rake and replaced spring aligner bushings. (kings all the way around will be rebuilt over the summer)
    • greased shackles
    • replaced brake pads front (has the tundra upgrade up front)
    • axel was leaking on rear brakes so replaced axle shaft oil seals
    • rear brakes replaced including new shoes, cylinders, and drums (resurfaced the drums)
    • 100% fresh fluids throughout the truck including brake fluid flush, power steering flush, oil and filter, transmission fluid and filter, front and rear differentials and transfer case (drain and refill), drain and refill coolant
    • new spark plugs and wires
    • replaced timing belt/water pump, thermostat, ac belt, alternator belt, power steering belt, camshaft seal, etc (full kit from cabin airman)
    • cleaned throttle body and mass air flow
    • new fuel filter
    • replaced upstream and downstream Oxygen sensors (pain in the ass getting the rusted retaining nuts off)
    • new exhaust gasket (behind the Cat)
    • replaced the battery and cable ends
    • replaced a bulb for rear license plate
    • lubricated propeller shaft, retorque propeller shaft bolt
    • fluid filmed the truck for rust prevention
    • checked steering gearbox, brake lines, vacuum hoses, steering rack, U Joints, Rack & Pinion, (all good)
    I am sure there are other things I am missing/forgetting but the bottom line is this truck should be good to roll for a while.
    OpenYota, Winkle99, Bolt Head and 6 others like this.
  17. Jan 4, 2024 at 10:43 PM
    Neal4x4
    Neal4x4 Well-Known Member
    Southern California
    Truck.
    Grabbed a softopper off OfferUp. Said it was for a 3rd gen but almost certain it was a 1st or 2nd gen. Anyways fits pretty well. Just need some snap closure buttons and that seal tape, going to try a fabric store tomorrow.
    Also finally got the rear view camera wired in.
  18. Jan 5, 2024 at 12:50 PM
    6P4
    Colorado Springs
    My check engine light turned off and I'm scared.
  19. Jan 5, 2024 at 5:50 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Okay, that's just straight up impressive.
  20. Jan 5, 2024 at 5:51 PM
    LanceRN
    Lance
    Bulb burned out.
    unstpible, ORRN and Neal4x4 like this.
