  1. Jan 6, 2024 at 5:09 AM
    schnack
    schnack 1997 DLX 5pd 5VZ Creme
    Hello TW: Sharing some photos of my 1st gen which I have had since 2016. The journey with this truck has been an interesting one. DM me with questions. I have been a member here since 2016 and this is my first post.
    1997, DLX, 5VZ, 5spd, 243k mi, Creme 557 paint, custom graphics by B.L.Vinyl, '92 pickup wheels, leveling kit/General Spring HD leafs, Ranchos, IS300 ST Whl/Rav4 airbag cover. Full engine overhaul by Toy House, Tampa in 2022 with a used 5VZ w/114k mi.
    The inspiration for the design is based on the beloved 80-early 90's pickups. I wanted to pay homage to that style truck.
  2. Jan 6, 2024 at 8:02 AM
    Phessor
    Phessor Well-Known Member
    Very nice, and retro
    OG.Taco-95.5 likes this.
  3. Jan 6, 2024 at 1:06 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    My check engine light has turned back on, and P0420 brought its friend P0115. Oh well, it was fun while it lasted.
  4. Jan 6, 2024 at 1:46 PM
    OG.Taco-95.5
    OG.Taco-95.5 Well-Known Member
    1995.5 Toyota Tacoma 2rz
    Totally digging your setup !
  5. Jan 6, 2024 at 1:48 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    don’t those two together narrow down for you?
  6. Jan 6, 2024 at 3:45 PM
    6P4
    Colorado Springs
    I don't think they're related.
    P0420 is exhaust/emissions related. Failed catalytic converter, exhaust leak, failed oxygen sensor. I've been living with that code for a long time. Already tried replacing the oxygen sensor (no change). Tried cleaning the MAF (code went away for a few days then came back). I know I have some exhaust leaks and the parts to fix them arrived at my doorstep today so fingers crossed that'll take care of it.
    P0115 is a coolant temperature sensor malfunction. After letting the engine cool down (the sensor is somewhat buried on the back of the head of a 3RZ) I checked and found that its connector was loose. The retaining clip on the harness side is broken. Fingers crossed that'll take care of it and maybe I can find a replacement connector at the junkyard.
  7. Jan 6, 2024 at 4:51 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Anyone know what this half ass attached resistor I found in the driver kick panel might be for?
    unstpible likes this.
  8. Jan 6, 2024 at 5:08 PM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Should be to isolate door lock trigger wire from an alarm or remote start. Get me a few pictures I can look that up at work tomorrow if you need more help.
  9. Jan 6, 2024 at 7:31 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Think that's a diode not a resistor.
    jubei likes this.
  10. Jan 7, 2024 at 4:38 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Oh shit... could I have maybe found why my remote's stopped working a while back?! I found another wire near it that was a little bare too. I'll text you.
    Google says you are correct.
  11. Jan 7, 2024 at 11:48 AM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
    Moved one of the horns to the driver side and moved the condenser line to in front of the vertical support to get ready for the trans cooler install some time between now and summer.
  12. Jan 7, 2024 at 1:11 PM
    02hilux
    Planet: EARTH
    Run a big AF cooler for both the PS and ATF :eek:
    Everything fit like a charm from factory
    unstpible and semco-inc like this.
  13. Jan 7, 2024 at 4:20 PM
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    Installed engine oil pan and transmission oil pan pad heaters in anticipation of Wisconsin deep freeze temps.
    Added the battery maintainer/charger to a triple plug block for simple plug in.
    unstpible, ztwatson and Bolt Head like this.
  14. Jan 7, 2024 at 4:43 PM
    Bolt Head
    Colorado
    Wow Dude! Nice! Does the factory grill even fit over all that?
  15. Jan 7, 2024 at 6:00 PM
    02hilux
    Planet: EARTH
    Like a charm. No cutting at all and utilized all the factory clips
    Laxtoy, jubei, Burro and 6 others like this.
  16. Jan 7, 2024 at 10:32 PM
    phoenixmalanga
    phoenixmalanga Member
    Phoenix
    1996 2.7L 4x4
    American Racing 7x9 -12 with Nitto grapplers 267/75/17 no lift. Had to do some trimming and pinch weld mod.
    unstpible, Phessor, ztwatson and 4 others like this.
  17. Jan 8, 2024 at 6:10 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Finished wiring the rear winch this weekend.
    Got the rear hubs packed, ebrake shoes installed, calipers and rotors installed, the rear brake lines finished, and bled the brakes... Will need to bleed them again, as we found a couple leakers but it was already getting dark and cold, so we quit lol.
    We were able to run the new ebrake cables towards the front, to figure out where the bracket/splitter will go and how much room I was working with. Ordered the bracket/splitter, I think will work, last night.
    Also drilled all the heads of the bolts on the Ubolt eliminator plates for safety wire.
  18. Jan 8, 2024 at 7:13 PM
    firemaniac
    firemaniac Well-Known Member
    Northwest corner of Montana, Troy/Yaak area
    04 DC 4x4, Flatbed, auto, teardrop tugboat.
    Flatbed, Bilstein/OME 883 lifted, ARB bumper, Warn M8000, Onboard air, Onboard water system, Lights, Lights, Lights
    Nice, with that large supply wire for the winch, do you have any plans to add an Anderson plug at the rear of the truck for jumper cables? They come in handy at times.
  19. Jan 8, 2024 at 7:19 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I could actually just clamp to the connector posts. But I hadn't thought of that.
    unstpible and firemaniac[QUOTED] like this.
  20. Jan 8, 2024 at 7:28 PM
    firemaniac
    That's true.
    A plug will prevent you from having to crawl under the truck to get to the posts in a wet muddy section, plus if you add some protective covers to the posts to prevent unexpectedly letting the magic blue smoke out.
