  1. Jan 20, 2024 at 1:39 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Supercross in San Diego :cheers:
    T’was a rainy one.
  2. Jan 21, 2024 at 4:44 PM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    Picked up a snugtop for the taco today, now to get it painted or just leave it black
    SoutheastTaco334 and Bandido like this.
  3. Jan 21, 2024 at 5:06 PM
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    Installed these APS iBoard Running Boards https://www.amazon.com/dp/B01N9QDJG2
    Install went smoothly, however, to achieve reasonable level of the boards had to use some spacer washers (3-4) in the support arms as well as longer bolts through the pinch weld. The supplied M8x1.25x20mm needed another 10mm to function well for my install. Had to buy 8 bolts and about 26 washers to fit out all 8 support arms.
    My goal is to protect the lower rocker panels from the wicked Wisconsin salt. I noticed that the factory running boards on my 3rd Gen 4Runner have provided excellent protection of the lower rocker and lower door panels and want to achieve the same thing for my Cali body & frame.
    For added protection I sprayed CorBan 35 on the freshly drilled pinch weld holes and the self tapping screw holes.
    IMG_1722.jpg IMG_1723.jpg IMG_1724.jpg IMG_1725.jpg IMG_1727.jpg IMG_1728.jpg
    ztwatson likes this.
  4. Jan 21, 2024 at 6:27 PM
    GuavaRoad
    GuavaRoad Well-Known Member
    Leave it black imo. How much did that set you back? I'm looking for a top for my double cab as well
  5. Jan 21, 2024 at 6:33 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    One side finally done.
    turbodb, BYJOSHCOOK and jubei like this.
  6. Jan 21, 2024 at 7:06 PM
    Cheap Taco
    700 but you never find a old snugtop this far across the Mississippi
  7. Jan 21, 2024 at 9:45 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Started designing a headache rack for the truck, I’m thinking 2 antenna mounts, 2 side lights, possibly reverse lights. I think I can use the factory tie down points to bolt it into the bed and then have 3 bolts through the bottom tube through the lip of the bed.
  8. Jan 22, 2024 at 9:18 AM
    SoutheastTaco334
    SoutheastTaco334 Member
    Alejandro
    Dothan, Alabama
    2004 Double Cab Taco
    leave it black! I’ve always loved the mismatched camper tops. I’ve got a silver Snugtop on my red Tacoma.
  9. Jan 22, 2024 at 9:51 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    With the paint in that good of condition still I’d leave it black. If the paint was bad I’d say go ahead and paint it. I’ve had three black campers, two of which I painted black. My truck is white. Easier to paint it black than worry about paint matching white or any other color.
  10. Jan 22, 2024 at 10:46 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Installed a third brake light for softopper
  11. Jan 22, 2024 at 11:50 AM
    LiftedOn35s
    LiftedOn35s Graduated!
    Noah
    Northeast FL
    Shadow Grey Met. 2004 Tacoma V6 5MT TRD OR
    1" level, 16" American Racing wheels, 32" M/Ts
    2023 was mostly what I DIDN'T do to my truck :rofl:.. pulled my bike a couple times and a beach trip or 2 with a few instances of daily driving when it was cold or rainy. Totaled 1,570 miles for the year. 40mi for 2024 so far.
    BuelltonTacoma likes this.
  12. Jan 22, 2024 at 5:33 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Finally got my seatbelt sent in for replacement webbing. It's been fraying for a decade and haven't been successful in buying an OEM replacement. Looks like Safety Restore did a solid job.
    unstpible, TacoVio, ireymon and 4 others like this.
  13. Jan 22, 2024 at 9:29 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    I installed LCE headers a month or two ago on my 2000 with the 3RZ and today I installed their cat back exhaust. Freekin' sweet and at $600 delivered I can't complain one bit on the cost. What surprised me was they every one of the 24 year old exhaust hangers were still totally fine. I had a couple aftermarket hangers in the Toyota pattern if I needed them...but nope. The 24 year old ones looked like they have another decade. Crazy. But with the LCE headers and their exhaust the little truck barks pretty well when asked. And since it's a single cab no cutting, just bolt it up, and I liked they they put the ceramic coating on the clamps and nuts. Ha.
    semco-inc and Bandido like this.
  14. Jan 23, 2024 at 7:31 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Those that have changed or removed headers, any issues with breaking studs/off in the block? I broke the studs on the flange and need to pull th headers to drill them out but worried about breaking them off in the block
    ChargedSHOTaco likes this.
  15. Jan 23, 2024 at 7:34 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They come off pretty easy on the V6, they won't snap I don't think, but you may pull a whole stud out of the head. A few of mine did that, no biggie to put them back.
    malburg114[QUOTED] likes this.
  16. Jan 23, 2024 at 7:55 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Non-issue. Maybe break the nuts free with a socket first before zipping them off.
    MadNachos and malburg114[QUOTED] like this.
  17. Jan 23, 2024 at 8:59 PM
    MadNachos
    The flange on the headers is nice and thick. If something breaks ya did it wrong.
  18. Jan 24, 2024 at 1:22 AM
    ScaredDeer
    ScaredDeer Member
    BC, Canada
    03 Taco Pre-Runner 4WD
    PreRunner to 4x4, Tranny oil cooler, RA Motorsport skid plates, Custom front hitch
    Just got a 3D printer the other week and since I never got a transfercase shift knob when doing my Prerunner 4x4 conversion ended up 3D Printed a J-shift knob that a friend made the model for! :D
  19. Jan 24, 2024 at 7:34 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Does anyone elses E-Brake handle not require pressing the button to turn and unlock? My E Brake clicks and locks in fine, but when I go to disengage it doesnt require pressing the button on the handle to turn it and disengage the brake. Is that pretty normal? Never seen anyone address it.
  20. Jan 24, 2024 at 8:27 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    She finally passed smog. :taco:
    Only took both O2 sensors, both catalytic converters, new gas cap, a transmission temperature sensor, and driving it over 130 miles to get the ECU monitors to be ready for test.
    But no check engine light... We'll see what happens in a year and a half when I need to get the next smog.
