  1. Feb 7, 2024 at 1:33 PM
    mrcyan
    mrcyan Member
    JC
    Saint David, AZ
    1996 xcab V6
    Around 250,000 miles.
    I replaced the brushes, because I am cheap. The holder with the brushes is not much more expensive, and you should use insulating varnish over the exposed solder joints. If you don't have the paint, you spend more time and money soldering new brushes than just buying the complete assembly.
    These were the retail prices at the time I did it:
    HOLDER ASSEMBLY, ALTERNATOR BRUSH 2737035060 $23.37
    BRUSH, ALTERNATOR 2737170300 $5.29
    This is the varnish:
    https://www.mouser.com/ProductDetai...s=sbrGYOVz3Hc8SKiYz4AnOg==&mgh=1&gad_source=1
    My bearings were fine, and I don't think it would be worth the trouble to replace them. The rotor has copper or brass on it were the brushes rub against it. Mine had groves ground into it. If it needed more than brushes, I think that I would just buy a new one or try the GM alternator that I have seen people use.
  2. Feb 7, 2024 at 10:57 PM
    SpokeWench
    SpokeWench Well-Known Member
    Paula
    1998 Tacoma SR5 4x4, Super Pacific X1
    Mystic Purple Mica, Super Pacific X1 (bld 359)
    Well, not really a mechanical, "today", but ...
    I put a couple bikes on my DIY, swing arm, 2-bike carrier and a friend and I went riding - east of Portland, OR where there was more sun.
    This was the first on-road, shake-down of the carrier. Very happy with this creation.
  3. Feb 9, 2024 at 1:56 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Fresh wires going in. Hoping it resolves my hiccup at idle.
    Fantastic11 and Area51Runner like this.
  4. Feb 10, 2024 at 7:45 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Hello smooth-mostly idle, haven’t seen you in a while
    ztwatson and Fantastic11 like this.
  5. Feb 11, 2024 at 5:20 AM
    457taco
    457taco Active Member
    Toby
    Brooklet, GA
    2001 Tacoma pre runner
    Installed new kendwood doubledin!
    0xDEADBEEF likes this.
  6. Feb 11, 2024 at 6:00 AM
    Kimp
    Kimp Well-Known Member
    Jeff
    Northern Illinois
    Supercharged ‘02 Double Cab
    Finally got a full sized spare since I moved up to 33’s, and also got the matching rim for when I go to the swing out rear bumper. Now it’s time to get the tire mounted!
  7. Feb 11, 2024 at 3:20 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
  8. Feb 11, 2024 at 4:50 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Redline Goods custom shift boot installed.
  9. Feb 11, 2024 at 4:57 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    :101010:
  10. Feb 12, 2024 at 5:45 AM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    Went out to fine a bit of snow, it's was the perfect depth to just have a bit of fun but some drifts were 3-4' and required some back and forth.
    PXL_20240211_203730002.jpg PXL_20240212_001928246.jpg PXL_20240211_203849015_exported_22841.jpg
  11. Feb 12, 2024 at 10:04 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Who here has done oil filter relocation. I remember someone had but can't for the life of me remember who..
    I'm wanting to do this on my DD, not my offroader. Just sick of doing oil changes every 3-6 months and making a mess.
  12. Feb 12, 2024 at 10:05 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    pretty sure that was @Phessor
    jubei likes this.
  13. Feb 12, 2024 at 10:06 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Phessor
  14. Feb 12, 2024 at 10:06 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm not crazy then, I almost tagged him thinking it was him.
  15. Feb 12, 2024 at 12:45 PM
    schnack
    schnack 1997 DLX 5pd 5VZ Creme
    Finally got one of the shots/angles of my list that has been there for a while @heritagetacoma on IG20240210_162004.jpg
  16. Feb 12, 2024 at 2:13 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    https://www.batinc.net/#OURPRODUCTS
    I found another spot that had some good relocation kits more custom can’t seem that link I’ll come across it .
  17. Feb 12, 2024 at 3:00 PM
    Pscdouglas
    Pscdouglas Wish you weren't so awkward Darry.
    Stu
    Glens Falls, NY
    2004 black Tacoma Xtracab 4WD TRD AT, 2020 Black Tacoma ACLB 4WD Sport MT
    THOSE RIMS :bananadance:
  18. Feb 12, 2024 at 4:59 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Looks so damn good
  19. Feb 12, 2024 at 5:19 PM
    Phessor
    Phessor Well-Known Member
    I used a Holley filter adapter and filter relocation mount. Then I had a local shop build some high pressure hoses and mounted it in the fender well under the battery. It worked great for awhile, until the adapter on the block loosened up.
    EARL'S SPIN ON ADAPTER
    https://www.holley.com/products/plu...ing_systems/oil_filter_adapters/parts/1119ERL
    EARL'S BILLET REMOTE OIL FILTER MOUNT
    https://www.holley.com/products/plu...oling_systems/oil_filter_mounts/parts/2077ERL
    unstpible, Jase and Speedytech7 like this.
  20. Feb 12, 2024 at 5:28 PM
    Phessor
    Looks fun, let me tag along next time!
    CoWj[QUOTED] likes this.
