  1. Mar 27, 2024 at 6:21 PM
    Reyrey88
    Reyrey88 Active Member
    It's
    Just look up generic one podofo should put in the right pathway
  2. Mar 28, 2024 at 9:12 AM
    WackGrandpa
    WackGrandpa New Member
    2001 White Tacoma SR5
    This old girl just went through a lot of much needed work.
    Timing belt, tensioner, water pump and thermostat ✔
    Valve cover gaskets ✔
    Intake gaskets ✔
    Cam plugs and seals ✔
    Spark plugs and wires ✔
    Center support bearing ✔
    She's at 405,000km and I'm jut trying to get her to last another 405. Here's hoping!
    JPinFL, Fernando, unstpible and 10 others like this.
  3. Mar 28, 2024 at 10:34 AM
    Altenater
    Altenater Member
    Gabe
    2002 Tacoma TRD. Double Cab.
    Been working on a custom OEM looking gauge pod that rests on the dash. Still a work in progress and final color will be grey or black. Thinking of also making a 2 pod version.
    ireymon, semco-inc, Jiveydude and 4 others like this.
  4. Mar 28, 2024 at 10:44 AM
    beeboptaco
    beeboptaco high schooler
    2001 Army Green Tacoma SR5
    What's that in miles here we are American
  5. Mar 28, 2024 at 10:50 AM
    WackGrandpa
    Funny enough, my tach is in miles. It's sitting at 252 right now!
  6. Mar 28, 2024 at 2:14 PM
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    Does anyone know if I have to buy the full power steering high pressure hose if I just need the return part of the hard line? It looks like it's included in the same part # diagram and can't be bought separately?
    This is the part I'm talking about:
    44410-04030
    My high pressure hose is fine, but there's a kink in the other hard line that returns fluid back to the PS pump.
    Any help is much appreciated.
  7. Mar 28, 2024 at 8:43 PM
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    I like it, I'd be down for double pod
  8. Mar 29, 2024 at 9:39 AM
    The gold standard
    The gold standard Well-Known Member
    Western mass
    Green 03 v6
    Played hooky and got new shocks on all 4 corners. Went with KYB mononax, rockautos finest. For the rears used ones specd for a t100 bc of the extra height ive got from my bastard leaf pack. If you go for t100 rears get ready to get creative on install. It goes but was a fight. Shocking results! 3 out of 4 of the old shocks were totally busted.20240329_122918.jpg 20240329_122934.jpg 20240329_123037.jpg
    Two from a chevy 3/4ton under the old main and full length second yota leaf. The pack is working great, but will be getting some more fine tuning. Likely replacing the full length yota leaf with a 1/2 ton chev, and tweaking the 3/4ton to soften it up a little. Near future will be new tires, after giving the cheepo american racing wheels a scuff n spray.
  9. Mar 29, 2024 at 1:50 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Well, at 302k miles my injectors had issues unbeknownst to me. Headgasket blew and decided why not have them cleaned. Truck ran just fine.
    Pink 3rz 23250-75080 are indeed 325cc injectors. Seems to be a variation across different forums to what they are.
  10. Mar 29, 2024 at 2:35 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Found some dirt in my frame while installing Chevy 63s...
    Huh, where'd that pile of dirt come from?
    Well, that can't be good for frame rust.
    Ignore the axle housing, I've not mentioned that yet. :wink:
  11. Mar 29, 2024 at 3:46 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Noticeable difference after the cleaning? or do you not have it back together yet?
  12. Mar 29, 2024 at 4:14 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Too late, you mentioned it in an earlier post...
  13. Mar 29, 2024 at 6:46 PM
    Texas-Gorilla
    Texas-Gorilla Well-Known Member
    Thomas
    2016 Tacoma TRD OR
    Got the Tacoma back from the repair shop today and brought home a 2015 4Runner to replace the 2011 Xterra my son wrecked earlier in the week. Needless to say my insurance company is not really loving me at the moment with 2 wreck claims in the month of March! Let's hope April is a better month.
  14. Mar 29, 2024 at 9:33 PM
    Reh5108
    Idaho
    Still putting things back together. Would be difficult to pinpoint if clean injectors made a difference with having a whole new head on. Who knows how long it's been running with small issues. Hoping to start it tomorrow.
  15. Mar 29, 2024 at 10:54 PM
    Captkitts
    Captkitts New Member
    Christopher
    2004 silver Tacoma TRD
    None
  16. Mar 29, 2024 at 10:54 PM
    Captkitts
    Christopher
    None
    Just bought this.
  17. Mar 30, 2024 at 1:56 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Trying to get my clutch back in tip top shape. Hoping that new bushings and master cylinder rod adjustment will get me there. Might end up needing a new spring and pedal due to the wear :spending:
  18. Mar 30, 2024 at 2:36 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    An old mod many of us have done is to replace the torsion spring with a linear one. Do some searching here and you'll find what you need. It eliminates the bushings, so no squeaking and there's already a tab under the dash to hook to. Cheap and easy.
    Gyrkin and ztwatson[QUOTED] like this.
  19. Mar 30, 2024 at 2:40 PM
    The gold standard
    Western mass
    Green 03 v6
    Gonna find that. Currently have the original (317k) spring in there and its loaded up w dry lube bc the squeak was driving me crazy.
    Edit:
    https://www.tacomaworld.com/threads/clutch-pedal-truffle-shuffle.499079/
    End of page 2 has some nice pics of the linear setup
  20. Mar 31, 2024 at 3:23 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks bro! i wanted black ones. But i guess they look ok
