  1. Apr 2, 2024 at 6:39 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Thank you for the info, new uncut key is on the way to replace this tired old girl
    Laxtoy and alexswords like this.
  2. Apr 2, 2024 at 6:55 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    it def potentially is. My key can turn my doors and ignition but I had to get a key cut from my vin to actually turn off the airbag in the dash. And that key will go into the ignition but can’t turn it.
  3. Apr 3, 2024 at 10:25 PM
    time623
    James
    AZ
    Put in new LBJs tonight
    Wasn’t too bad with the right tools. Tried last night without a pitman puller just a hammer, that was a failure.
  4. Apr 3, 2024 at 10:35 PM
    Spirohydra
    Spirohydra Member
    Jake
    2004 Toyota Tacoma Crewcab Silver TRD
    Thanks for the Ebay link to Toyota original keys! Just ordered myself 2 keys. Beats the damaged ones I've been using.
    alexswords likes this.
  5. Apr 4, 2024 at 7:08 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Just had to post this
    alexswords, Area51Runner and time623 like this.
  6. Apr 4, 2024 at 7:41 PM
    time623
    James
    AZ
  7. Apr 5, 2024 at 8:10 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Good riddance.
    I don't know what I was doing wrong but J59s with a regular cab was too much spring.
    Area51Runner and Speedytech7 like this.
  8. Apr 5, 2024 at 8:33 PM
    Brewtactical
    Brewtactical New Member
    2019 Tacoma Midnight Black TRD OR 4x4 / 1999 Tacoma White Reg Cab 4x4
    Not the most exciting mod but new tires for my 1st gen today! PO had put on some ling longs that were way too small. Went back to the factory size of 265/75R15 in Toyo Open Country A/T3. IMG_4300.jpg
  9. Apr 5, 2024 at 8:33 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
  10. Apr 5, 2024 at 8:52 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Any mod or pic of a reg cab first gen is always welcome!!
    Brewtactical[QUOTED] likes this.
  11. Apr 5, 2024 at 9:04 PM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Got this from another tw member. Stoked to use it this weekend camping. Kinda wished it filled the corners a little better but it’ll do.
    DenverMoto, SamSpade, ireymon and 6 others like this.
  12. Apr 5, 2024 at 10:01 PM
    6P4
    Colorado Springs
    Overthinking out loud...
    Since I tinkered with my leaf springs I need new u-bolts. I re-used the bolts for test-driving but I want to put fresh ones on before long. The bolts I have now came with 7/8in nuts (but I use a 22mm socket because most of my tools are metric). They're the only fasteners of that size on the truck. If I remember correctly, the original Toyota u-bolts had 19mm nuts. There are lots of 19mm fasteners on the truck.
    The 7/8 fasteners are for a 9/16 u-bolt. I assume the OE bolt was 1/2in (or a comparable metric size). I'm tempted to go back to OE so I can take the 22mm socket out of my tool kit. A 21mm-drive nut would be ideal so I could keep an oversized bolt and use my mid-depth lug nut socket, but it seems that 21mm nuts don't really exist outside of lug nuts. The 19mm standard-depth should do just fine as long as I cut the bolts short enough.
  13. Apr 6, 2024 at 2:09 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nope, stay with the 9/16'' U bolts. 1/2'' will bend. At least that's been my experience. And they youll shear your center pin and be up shit creek some where.
    the 9/16 ones I used I think use a 3/4''/19mm nut I thought..
    El Taco Diablo likes this.
  14. Apr 6, 2024 at 10:16 AM
    Wulf
    rock raisin
    anyone running alignment octagons on a 2-3" lift willing to share photos of your alignment settings? hoping to get a baseline to get me by til I can go out of town for a proper alignment.
    tried to get mine aligned but the local guys were mystified and handed my keys back.
    wrapped up new LCAs with whiteline bushings, new ball joints, TREs, and alignment octagons...
  15. Apr 6, 2024 at 10:18 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That might be hard to do, what are your uppers?
  16. Apr 6, 2024 at 10:18 AM
    Wulf
    rock raisin
    stock
  17. Apr 6, 2024 at 10:19 AM
    Wulf
    rock raisin
    numbers don't have to be great I just don't want to eat tires running around town or on the road between trail heads.
    might have to eyeball it myself and call it good. I can trailer it to the dirt til I can get a 4x4 shop to poke at it
  18. Apr 6, 2024 at 10:21 AM
    Speedytech7
    I'd just toss a digital angle finder on it and tape measure align the toe after you get the camber and caster half ass close
  19. Apr 6, 2024 at 10:43 AM
    Wulf
    rock raisin
    I'll probably just set camber and toe and call it good enough for a trail toy
  20. Apr 6, 2024 at 4:57 PM
    6P4
    Colorado Springs
    If you have 9/16 with a a 3/4 nut, do you remember where you got them? None of the online vendors list what size nut they include.
    There's a leaf spring shop in town I can call on Monday and see what they say, too.
