  1. Jun 4, 2024 at 7:13 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Cleaned it.
    Found a small screw I lost a month ago. I heard it rattling through the shop vac hose from underneath the passenger floor matt.
    Lucky for me I recently cleaned it out and put a new filter in. That's the second time if found that screw in the bottom of the shop vac.
    jubei, DenverMoto and Black97v6MT like this.
  2. Jun 4, 2024 at 7:36 PM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    Know that one all too well!
    SpokeWench[QUOTED] likes this.
  3. Jun 5, 2024 at 8:44 AM
    semco-inc
    semco-inc Well-Known Member
    DFW & ATW
    1995 Tacoma 4x4 Extended Cab 3.4L
    Tundra Front Calipers & Rotors, Bilstein Shocks, 2DIN Head Unit, JBL Front Speakers, Tweeters in 4Runner Dome Pods, Transmission Oil Cooler, 16” Tacoma OEM Alloy Wheels
    OK Thanks,
    I have the old style sliding switches so this would be a No-Go for me unless the later round knob system can be retrofitted.
  4. Jun 5, 2024 at 8:45 AM
    semco-inc
    DFW & ATW
    Nice upgrade!
    Do you have a link for the metal ones you sourced?
    Thanks,
    Black97v6MT likes this.
  5. Jun 5, 2024 at 8:46 AM
    SpokeWench
    SpokeWench Well-Known Member
    Paula
    1998 Tacoma SR5 4x4, Super Pacific X1
    Mystic Purple Mica, Super Pacific X1 (bld 359)
  6. Jun 5, 2024 at 12:16 PM
    dannybubbles
    dannybubbles yada yada
    Daniel
    Chico, CA
    01 3.4 auto 4x
    Someone with more knowledge than me would have to answer that, but sorry to hear its not plug and play in your instance:(
  7. Jun 5, 2024 at 12:23 PM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Installed a new genuine OEM accelerator cable clamp on the 5VZFE
    Can't seem to find the other clamp available :notsure: that would make a sharp pair fit
    Is vulcanizing new rubber cushion a possible to do?
  8. Jun 5, 2024 at 12:33 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Earlier HVAC controls (at least thru 1998, I'd assume thru 2000) use push-pull cables to manipulate the various valves and vent doors in the system. Later controls (2001+) use electronic controls and servos. I'm not aware of anyone trying to swap. I doubt it would be easy.
  9. Jun 5, 2024 at 2:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ton of wiring and full center HVAC swap out. be a ton of work for...not much change Id say. But hey, if its worth it to you its worth it. Lot of work though!
    The gold standard likes this.
  10. Jun 5, 2024 at 7:06 PM
    Phessor
    Phessor Well-Known Member
    Finally rhino lined my bed.
    CoWj, GuavaRoad and semco-inc like this.
  11. Jun 5, 2024 at 7:10 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Didn’t know it was possible, but always thought swapping the radio and climate controls that this guy did was awesome, I’d love to have the radio at eye level like modern vehicles https://www.tacomaworld.com/threads/2001-2004-radio-climate-control-relocation.670700/
  12. Jun 6, 2024 at 8:58 AM
    Diy2k
    Diy2k Well-Known Member
    MG
    02 Tacoma, 2.7
    Softopper, shocks
    Did you spray or roll?
  13. Jun 6, 2024 at 12:13 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
  14. Jun 7, 2024 at 7:15 AM
    semco-inc
    DFW & ATW
    Doesn't sound like that "juice" is worth the squeeze for me! :)
  15. Jun 7, 2024 at 8:06 AM
    semco-inc
    DFW & ATW
    Took the truck to the local Dairy Queen for a Blizzard break after reno activities.
  16. Jun 7, 2024 at 8:52 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
  17. Jun 7, 2024 at 10:22 AM
    semco-inc
    DFW & ATW
  18. Jun 7, 2024 at 11:32 PM
    Toyota Dude
    Toyota Dude Well-Known Member
    2004 Tacoma 4WD 6-CYL DC
  19. Jun 8, 2024 at 9:53 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Swapped out a busted steering rack. I messed up the steering wheel alignment but otherwise was a pretty straightforward job.
  20. Jun 8, 2024 at 10:48 AM
    GuavaRoad
    GuavaRoad Well-Known Member
    Finally took my drop in bed liner out, expecting to find some rust and other goodies. Unfortunately, I wasn't surprised.
